EVN: Debian 12 (uname= 6.1.0-11-amd64)
VPI Card: Mellanox Technologies MT27520 Family [ConnectX-3 Pro]
Use Driver: MLNX_OFED_LINUX-4.9-7.1.0.0-debian10.0-x86_64.iso
Pls Help. or update driver for debian12 officially
Error:
- IN Command status: (./mlnx_add_kernel_support.sh -m /mnt -v)
ERROR: Failed executing “MLNX_OFED_SRC-4.9-7.1.0.0/install.pl --tmpdir /tmp/mlnx_iso.571824_logs --kernel-only --kernel 6.1.0-11-amd64 --kernel-sources /lib/modules/6.1.0-11-amd64/build/ --builddir /tmp/mlnx_iso.571824 --without-dkms --build-only”
ERROR log2: See /tmp/mlnx_iso.571824_logs/mlnx_ofed_iso.571824.log
ERROR log: ( /tmp/mlnx_iso.571824_logs/mlnx_ofed_iso.571824.log)
1 Logs dir: /tmp/mlnx_iso.571824_logs/OFED.572164.logs
2 General log file: /tmp/mlnx_iso.571824_logs/OFED.572164.logs/general.log
3
4 Below is the list of OFED packages that you have chosen
(some may have been added by the installer due to package dependencies):
6
7 ofed-scripts
8 mlnx-ofed-kernel-utils
9 mlnx-ofed-kernel-modules
10 rshim-modules
11 iser-modules
12 isert-modules
13 srp-modules
14 mlnx-nvme-modules
15 kernel-mft-modules
16 knem-modules
17
18 Checking SW Requirements…
19 One or more required packages for installing OFED-internal are missing.
20 Attempting to install the following missing packages:
21 dh-autoreconf gcc make build-essential quilt debhelper bzip2 pkg-config
22 This program will install the OFED package on your machine.
23 Note that all other Mellanox, OEM, OFED, RDMA or Distribution IB packages will be removed.
24 Those packages are removed due to conflicts with OFED, do not reinstall them.
25
26 Installing new packages
27 Building DEB for ofed-scripts-4.9 (ofed-scripts)…
28 Running /usr/bin/dpkg-buildpackage -us -uc
29 Building DEB for mlnx-ofed-kernel-utils-4.9 (mlnx-ofed-kernel)…
30
31 -W- --with-mlx5-ipsec is enabled
32 Running /usr/bin/dpkg-buildpackage -us -uc
33 Failed to build mlnx-ofed-kernel DEB
34 Collecting debug info…
35 See /tmp/mlnx_iso.571824_logs/OFED.572164.logs/mlnx-ofed-kernel.debbuild.log -
ERROR log3
file upload:
mlnx-ofed-kernel.debbuild.log (508.8 KB)
