i want put some sample code together with lane/object/sign/freespace/etc. detector.
But failed to build the simple helloworld example on SDK Reference. I also tried to create this project in Nsight Eclipse and end up with the same error
cannot convert ‘dwContextObject**’ to ‘dwContextHandle_t {aka dwContextObject*}’ for argument ‘1’ to ‘dwStatus dwRelease(dwContextHandle_t)’
Another try to build the laneDetection sample in Nsight Eclipse was after setting up all includes
recipe for target ‘helloDriver’ failed makefile
and
Warning: undefined reference to »dw_samples::common::DriveWorksSample::~DriveWorksSample()«
For me it look like something is wrong with the linker
Hope somebody knows how to build some own samples for the host system.
Cheers
Is following the doc (file:///usr/local/driveworks/doc/nvsdk_html/dwx_samples_building.html ; please open it with your host system browser) to build the sample applications working well on your side?
Hi @VickNV
thanks for the tip with cmake. I import, build and run a sample in Nsight Eclipse successfully. If i find time, i will post the steps i did.
