I met an error when building nvgstcapture-1.0:
ubuntu@tegra-ubuntu:~/nvgstapp/v27.1/nvgstapps_src/nvgst_sample_apps/nvgstcapture-1.0$ gcc nvgstcapture.c -o nvgstcapture-1.0 $(pkg-config --cflags --libs gstreamer-1.0 gstreamer-plugins-base-1.0 gstreamer-pbutils-1.0)
In file included from nvgstcapture.c:25:0:
nvgstcapture.h:38:21: fatal error: EGL/egl.h: No such file or directory
compilation terminated.
I thought maybe OpenGL should be installed first, but after I installed OpenGL the error is still there.
The source code nvgstapps_src.tbz2 is got from r27.1.0_sources.tbz2 which is downloaded from Jetson Download Center | NVIDIA Developer.
Please tell me how to fix this issue.
BTW, the same issue happened on jetson tx2 too.
