I’m currently developing with R38.4.1 system version and JetPack 7.1.
I’m compiling the miniUEFI for Thor. Due to network issues, the build environment keeps failing to set up. Could you please directly share a compiled miniUEFI image for Thor for our temporary use?
To flash miniUEFI to the Jetson AGX Thor, replace Linux_for_Tegra/bootloader/uefi_bins/uefi_t26x_general.bin with the generated miniUEFI binary. Put the device into recovery mode.
Run the following command to flash the entire device:
$ sudo ADDITIONAL_DTB_OVERLAY_OPT="BootOrderNvme.dtbo" ./l4t_initrd_flash.sh jnternal
