Hello, while building Morpheus on Jetson AGX Orin container build fail with following messages:
#26 384.4 Leaving build/test directories:
#26 384.4 Work:
#26 384.4 /opt/conda/conda-bld/work
#26 384.4 Test:
#26 384.4 /opt/conda/conda-bld/test_tmp
#26 384.4 Leaving build/test environments:
#26 384.4 Test:
#26 384.4 source activate /opt/conda/conda-bld/_test_env_placehold_placehold_placehold_placehold_placehold_placehold_placehold_placehold_placehold_placehold_placehold_placehold_placehold_placehold_placehold_placehold_placehold_placehold_placehold_placehold_placehold_placehold_pl
#26 384.4 Build:
#26 384.4 source activate /opt/conda/conda-bld/_build_env
#26 384.4
#26 384.4
#26 384.4 solution = solver.solve_for_action(_specs, prefix)
#26 384.4 File "/opt/conda/lib/python3.10/site-packages/boa/core/solver.py", line 244, in solve_for_action
#26 384.4 t = self.solve(specs)
#26 384.4 File "/opt/conda/lib/python3.10/site-packages/boa/core/solver.py", line 234, in solve
#26 384.4 raise RuntimeError("Solver could not find solution." + error_string)
#26 384.4 RuntimeError: Solver could not find solution.Mamba failed to solve:
#26 384.4 - versioneer-518
#26 384.4 - pyarrow * *_cuda
#26 384.4 - cudf 23.06.*
#26 384.4 - mrc 23.11.*
#26 384.4 - cuda-toolkit 11.8.*
#26 384.4 - libcudf 23.06.*
#26 384.4 - librdkafka 1.9.2.*
#26 384.4 - pybind11-stubgen 0.10.5.*
#26 384.4 - scikit-build 0.17.1.*
#26 384.4 - cython >=0.29,<0.30
#26 384.4 - python 3.10.*
#26 384.4 - rapidjson 1.1.*
#26 384.4 - pip
#26 384.4
#26 384.4 with channels:
#26 384.4 - rapidsai
#26 384.4 - nvidia
#26 384.4 - nvidia/label/dev
#26 384.4 - pytorch
#26 384.4 - conda-forge
#26 384.4
#26 384.4 The reported errors are:
#26 384.4 - Encountered problems while solving:
#26 384.4 - - nothing provides requested mrc 23.11.*
#26 384.4 -
#26 384.4
#26 384.4 During handling of the above exception, another exception occurred:
#26 384.4
#26 384.4 Traceback (most recent call last):
#26 384.4 File "/opt/conda/bin/conda-mambabuild", line 10, in <module>
#26 384.4 sys.exit(main())
#26 384.4 File "/opt/conda/lib/python3.10/site-packages/boa/cli/mambabuild.py", line 256, in main
#26 384.4 call_conda_build(action, config)
#26 384.4 File "/opt/conda/lib/python3.10/site-packages/boa/cli/mambabuild.py", line 228, in call_conda_build
#26 384.4 result = api.build(
#26 384.4 File "/opt/conda/lib/python3.10/site-packages/conda_build/api.py", line 253, in build
#26 384.4 return build_tree(
#26 384.4 File "/opt/conda/lib/python3.10/site-packages/conda_build/build.py", line 3799, in build_tree
#26 384.4 packages_from_this = build(
#26 384.4 File "/opt/conda/lib/python3.10/site-packages/conda_build/build.py", line 2469, in build
#26 384.4 output_metas = expand_outputs([(m, need_source_download, need_reparse_in_env)])
#26 384.4 File "/opt/conda/lib/python3.10/site-packages/conda_build/render.py", line 923, in expand_outputs
#26 384.4 for output_dict, m in deepcopy(_m).get_output_metadata_set(
#26 384.4 File "/opt/conda/lib/python3.10/site-packages/conda_build/metadata.py", line 2565, in get_output_metadata_set
#26 384.4 conda_packages = finalize_outputs_pass(
#26 384.4 File "/opt/conda/lib/python3.10/site-packages/conda_build/metadata.py", line 909, in finalize_outputs_pass
#26 384.4 fm = finalize_metadata(
#26 384.4 File "/opt/conda/lib/python3.10/site-packages/conda_build/render.py", line 636, in finalize_metadata
#26 384.4 m = parent_metadata.get_output_metadata(m.get_rendered_output(m.name()))
#26 384.4 File "/opt/conda/lib/python3.10/site-packages/conda_build/metadata.py", line 2656, in get_rendered_output
#26 384.4 for output_ in self.get_rendered_outputs_section(
#26 384.4 File "/opt/conda/lib/python3.10/site-packages/conda_build/metadata.py", line 2638, in get_rendered_outputs_section
#26 384.4 self._get_contents(
#26 384.4 File "/opt/conda/lib/python3.10/site-packages/conda_build/metadata.py", line 1904, in _get_contents
#26 384.4 rendered = template.render(environment=env)
#26 384.4 File "/opt/conda/lib/python3.10/site-packages/jinja2/environment.py", line 1301, in render
#26 384.4 self.environment.handle_exception()
#26 384.4 File "/opt/conda/lib/python3.10/site-packages/jinja2/environment.py", line 936, in handle_exception
#26 384.4 raise rewrite_traceback_stack(source=source)
#26 384.4 File "<template>", line 45, in top-level template code
#26 384.4 File "/opt/conda/lib/python3.10/site-packages/conda_build/jinja_context.py", line 336, in pin_compatible
#26 384.4 pins, _, _ = get_env_dependencies(m, "host", m.config.variant)
#26 384.4 File "/opt/conda/lib/python3.10/site-packages/conda_build/render.py", line 151, in get_env_dependencies
#26 384.4 actions = environ.get_install_actions(
#26 384.4 File "/opt/conda/lib/python3.10/site-packages/boa/cli/mambabuild.py", line 150, in mamba_get_install_actions
#26 384.4 raise err
#26 384.4 conda_build.exceptions.DependencyNeedsBuildingError: Unsatisfiable dependencies for platform linux-aarch64: {MatchSpec("mrc=23.11")}
#26 ERROR: executor failed running [/bin/bash -c /opt/conda/bin/mamba install -y -n base -c conda-forge "git-lfs" && source activate base && git lfs install && git config --global --add safe.directory "*" && cd ${MORPHEUS_ROOT_HOST} && MORPHEUS_PYTHON_BUILD_STUBS=OFF CONDA_BLD_PATH=/opt/conda/conda-bld ./ci/conda/recipes/run_conda_build.sh morpheus]: exit code: 1
> [conda_bld_morpheus 3/3] RUN --mount=type=cache,id=workspace_cache,target=/workspace/.cache,sharing=locked --mount=type=cache,id=conda_pkgs,target=/opt/conda/pkgs,sharing=locked /opt/conda/bin/mamba install -y -n base -c conda-forge "git-lfs" && source activate base && git lfs install && git config --global --add safe.directory "*" && cd . && MORPHEUS_PYTHON_BUILD_STUBS=OFF CONDA_BLD_PATH=/opt/conda/conda-bld ./ci/conda/recipes/run_conda_build.sh morpheus:
Build info:
Building morpheus: with args...
CUDA_MAJOR_VER : 11
CUDA_MINOR_VER : 8
CUDA_REV_VER : 0
DOCA_ARTIFACTS_HOST :
DOCA_REPO_HOST :
FROM_IMAGE : nvidia/cuda
LINUX_DISTRO : ubuntu
LINUX_VER : 22.04
MORPHEUS_ROOT_HOST : .
MORPHEUS_SUPPORT_DOCA: OFF
PYTHON_VER : 3.10
RAPIDS_VER : 23.06
TENSORRT_VERSION : 8.2.1.3
Can you assist? I looked at forums but found no solution.
