Please refer the attached nvcc_virtual_method_bug.zip
- Attempts to use C++ virtual methods results in
Cuda Error ( 718 ): invalid program counter - There is a strange work-around involving adding a kernel
__global__ void create_function_local()that is never used (note the suffix_local)
To expose the bug, run: build_and_run.sh
$ ./out/t_with_globals.exe
Getting started … 5 1
Doing something … @t.cu::43::main()::cudaDeviceSynchronize():
[…]$ cuda-gdb ./out/t_with_globals.exe
CUDA Exception: Warp Invalid PC
The exception was triggered at PC 0x555555bd8aa0Thread 1 “t_with_globals.” received signal CUDA_EXCEPTION_8, Warp Invalid PC.
nvcc_virtual_method_bug.zip (5.7 KB)
