hi,guys:
system:ubuntu 16.04
nvidia driver 384.90
cuda 8.0
I run caffe samples /01-learning-lenet.ipynb with jupyter notebook,
while running the followwing sentence,the jupyter python kernel is broken and restart
caffe.set_device(0)
caffe.set_mode_gpu()
load the solver and create train and test nets
solver = None # ignore this workaround for lmdb data (can’t instantiate two solvers on the same data)
solver = caffe.SGDSolver(‘mnist/lenet_auto_solver.prototxt’)
[W 19:00:45.337 NotebookApp] Notebook examples/01-learning-lenet.ipynb is not trusted
WARNING: Logging before InitGoogleLogging() is written to STDERR
E1203 19:02:41.299633 12443 common.cpp:114] Cannot create Cublas handle. Cublas won’t be available.
F1203 19:02:41.361006 12443 benchmark.cpp:112] Check failed: error == cudaSuccess (30 vs. 0) unknown error
*** Check failure stack trace: ***
