Caffe to TensorRT on Jetson TX2 Permute custom layer implementation
Hi I am trying to run caffe SSDMobileNet (GitHub - chuanqi305/MobileNet-SSD: Caffe implementation of Google MobileNet SSD detection network, with pretrained weights on VOC0712 and mAP=0.727.) in TensorRT environment on Jetson TX2 to do this I took sampleFasterRcnn code from usr/src/tensorrt/samples and just changed parameters in CaffetoGIEModel function withh SSDMobileNet prototext and model file namely “MobileNetSSD_deploy.prototxt” and “MobileNetSSD_deploy.caffemodel” and kept these file in corresponding data folder now after make when I am running it the error I am getting is
Begin parsing model…
[libprotobuf ERROR google/protobuf/text_format.cc:298] Error parsing text-format ditcaffe.NetParameter: 1177:17: Message type “ditcaffe.LayerParameter” has no field named “permute_param”.
Could not parse deploy file
End parsing model…
I think there are some layer like permute missing in TensorRT now when I went through TensorRT doc I came to know we can implement our own custom layer using plugin api but I dont know how to do that and can not find any tutorial or documentation which explain how to do that… I am new to TensorRT any kind of help is really appreciated
Permute is a non-supported layer. Please implement it with Plugin API.
Here is the information about how to implement a custom layer for your reference:
Document:
/usr/share/doc/tensorrt/
3.8. SamplePlugin - Implementing a Custom Layer
Samples:
Native sample:
/usr/src/tensorrt/samples/samplePlugin/samplePlugin.cpp
/usr/src/tensorrt/samples/sampleCharRNN/sampleCharRNN.cpp
/usr/src/tensorrt/samples/sampleFasterRCNN/sampleFasterRCNN.cpp
TX2 sample:
