I saw in DeepStream app, that it’s previewing FPS of each stream:
**PERF: FPS 0 (Avg) FPS 1 (Avg) FPS 2 (Avg) FPS 3 (Avg)
**PERF: 30.86 (30.86) 31.20 (31.20) 30.70 (30.70) 31.20 (31.20)
**PERF: 30.00 (30.41) 30.00 (30.58) 30.00 (30.34) 30.00 (30.58)
Which plugin supporting it? and how to enable it?
I would like to test my costume pipe with that.
Thanks,
Hi robertpfjq08,
It is built in deepstream-app in binaries.tbz2
/usr/bin/deepstream-app
You can enable/disable it by setting enable-perf-measurement
How to enable it in deepstream-infer-tensor-meta-test sample?
Hi sathiez,
Do you use DS2.0 or DS4.0?
It is implemented in deepstream-app. You may check the code:
deepstream_sdk_v4.0_jetson\sources\apps\apps-common\src\deepstream_perf.c
And adapt it to deepstream-infer-tensor-meta-test
