I am customizing the deepstream_test3_app source code and I want to print the performance data (FPS) for each output stream in the terminal. I couldn’t find any implementation of that in the sample apps
you can refer to deepstream-app.c (sources/apps/sample_apps/deepstream-app/deepstream_app.c), it have one boolean enable_perf_measurement to enable perf measurement called, which is from sources/apps/apps-common/src/deepstream_perf.c
That works! Thanks
