I got errors after running ./calibration-graph-cli for calibration with 5 cameras.
The following contents are part of the outputs from ./calibration-graph-cli for one of the 5 cameras, “camera-2”. camera-2 is a fisheye camera with 200 degree FOV.
Initializing intrinsics for camera camera-2
OcamCalib: initial calib
Closed form result: 960,604,748.143,0,0.00116037,-1.39637e-06,1.12313e-09, error: 1.78853e+12
OcamCalib: refine center
OcamCalib: new calib
OcamCalib: non-linear
OcamCalib: find inv poly
Final result: 1467.63,1173.37,1.23936,-0.195392,-0.0533503
: ,994.278,0,0.000497471,-4.4493e-07,7.50014e-11
: ,21843.8,-147760,470171,-841610,916638,-624321,260892,-61389.3,6244.63
Closed-form camera initialization:
center=1467.63,1173.37
affine=1.23936,-0.195392,-0.0533503
poly=[994.278,0,0.000497471,-4.4493e-07,7.50014e-11,]
inv poly=21843.8,-147760,470171,-841610,916638,-624321,260892,-61389.3,6244.63,]
reprojection error (libintrcalib)=19.2994
FOV: 132.716
Initializing poses for intrinsic constraints for camera camera-2
ERROR: reprojection error for intrinsic constraint is too large.
Stats: Median=nan, mean=15.2641, var=153, std dev=12.3693, sample count=16804, min=0.0226805, max=231.829
and
Refining intriniscs for camera camera-2
Error before: Median=nan, mean=15.2641, var=153, std dev=12.3693, sample count=16804, min=0.0226805, max=231.829
Note: fixing principal point, D, and E for ocam camera
Can anyone help with solving those errors? What are the causes of those errors? I followed the steps from the tutorial in the document.
