Sorry but every time i try to make the code shorter, it works:
I have two modules with abstract classes
First module:
module m_transformation_base
implicit none
type :: t_mesh
integer :: num_cells1
integer :: num_cells2
real(8) :: eta1_min
real(8) :: eta1_max
real(8) :: eta2_min
real(8) :: eta2_max
real(8) :: delta_eta1
real(8) :: delta_eta2
end type t_mesh
type, abstract :: c_transformation_base
type(t_mesh), pointer :: mesh => null()
contains
procedure(geometry_function), deferred, pass :: x1
procedure(geometry_function), deferred, pass :: x2
end type c_transformation_base
abstract interface
function geometry_function( this, eta1, eta2 )
import c_transformation_base
class(c_transformation_base) :: this
real(8) :: eta1
real(8) :: eta2
real(8) :: geometry_function
end function geometry_function
end interface
end module m_transformation_base
use m_transformation_base
implicit none
interface
function i_transformation_function( eta1, eta2 ) result(res)
real(8) :: eta1
real(8) :: eta2
real(8) :: res
end function i_transformation_function
end interface
type, extends(c_transformation_base) :: t_transformation
procedure(i_transformation_function), pointer, nopass :: x1_func
procedure(i_transformation_function), pointer, nopass :: x2_func
contains
procedure, pass(this) :: x1 => x1_analytic
procedure, pass(this) :: x2 => x2_analytic
end type t_transformation
contains
function f_new_mesh(num_cells1, num_cells2, eta1_min, eta1_max, &
eta2_min, eta2_max ) result(mesh)
integer :: num_cells1, num_cells2
real(8) :: eta1_min, eta1_max, eta2_min, eta2_max
allocate(mesh)
mesh%num_cells1 = num_cells1
mesh%num_cells2 = num_cells2
mesh%eta1_min = eta1_min
mesh%eta1_max = eta1_max
mesh%eta2_min = eta2_min
mesh%eta2_max = eta2_max
mesh%delta_eta1 = (eta1_max - eta1_min)/real(num_cells1,8)
mesh%delta_eta2 = (eta2_max - eta2_min)/real(num_cells2,8)
end function f_new_mesh
function f_new_transformation( mesh, x1_func, x2_func) result(T)
type(t_transformation), pointer :: T
procedure(i_transformation_function) :: x1_func
procedure(i_transformation_function) :: x2_func
allocate(T)
T%mesh => mesh
T%x1_func => x1_func
T%x2_func => x2_func
end function f_new_transformation
function x1_analytic( this, eta1, eta2 ) result(val)
class(t_transformation) :: this
real(8) :: eta1
real(8) :: eta2
real(8) :: val
val = this%x1_func(eta1, eta2)
end function x1_analytic
function x2_analytic( this, eta1, eta2 ) result(val)
real(8) :: val
real(8) :: eta1
real(8) :: eta2
val = this%x2_func(eta1, eta2)
end function x2_analytic
Second module
module m_field_base
implicit none
type, abstract :: c_field_base
class(c_transformation_base), pointer :: t
contains
procedure(function_evaluation_real), deferred, pass :: value_at_point
end type c_field_base
abstract interface
function function_evaluation_real( field, eta1, eta2 )
import c_field_base
class(c_field_base), intent(in) :: field
real(8) :: eta1
real(8) :: eta2
real(8) :: function_evaluation_real
end function function_evaluation_real
end interface
end module m_field_base
module m_field
use m_field_base
implicit none
interface
function i_two_var_function( eta1, eta2 )
real(8) :: eta1
real(8) :: eta2
real(8) :: i_two_var_function
end function i_two_var_function
end interface
type, extends(c_field_base) :: t_field
procedure(i_two_var_function), pointer, nopass :: func
contains
procedure, pass(field) :: value_at_point => value_at_pt_analytic
end type t_field
contains
function f_new_field( func, t ) result(field)
procedure(i_two_var_function), pointer :: func
class(c_transformation_base), pointer :: T
type(t_field), pointer :: field
allocate(field)
field%T => T
field%func => func
end function f_new_field
function value_at_pt_analytic( field, eta1, eta2 )
class(t_field), intent(in) :: field
real(8) :: eta1
real(8) :: eta2
real(8) :: value_at_pt_analytic
value_at_pt_analytic = field%func(eta1,eta2)
end function value_at_pt_analytic
end module m_field
main program
module m_functions
implicit none
contains
function f_identity_x1 ( eta1, eta2 )
real(8) :: f_identity_x1
real(8) :: eta1
real(8) :: eta2
f_identity_x1 = eta1
end function f_identity_x1
function f_identity_x2 ( eta1, eta2 )
real(8) :: f_identity_x2
real(8) :: eta1
real(8) :: eta2
f_identity_x2 = eta2
end function f_identity_x2
function test_function( eta1, eta2 )
real(8) :: eta1
real(8) :: eta2
real(8) :: test_function
test_function = (eta1/0.25_8)*10+eta2/0.25_8 +11_8
end function test_function
end module m_functions
program test_scalar_field_2d
use m_functions
use m_field_base
use m_field
implicit none
class(c_field_base), pointer :: field
integer :: nptsx1
integer :: nptsx2
real(8), dimension(:,:), allocatable :: x1coords
real(8), dimension(:,:), allocatable :: x2coords
real(8), dimension(:,:), allocatable :: values
real(8) :: eta1
real(8) :: eta2
integer :: i
integer :: j
procedure(i_transformation_function), pointer :: x1
procedure(i_transformation_function), pointer :: x2
x1 => f_identity_x1
x2 => f_identity_x2
f => test_function
mesh => f_new_mesh( 4, 4, 0.0_8, 1.0_8, 0.0_8, 1.0_8 )
T => f_new_transformation( mesh, x1, x2)
field => f_new_field( f, T)
nptsx1 = mesh%num_cells1 + 1
nptsx2 = mesh%num_cells2 + 1
allocate(x1coords(nptsx1,nptsx2))
allocate(x2coords(nptsx1,nptsx2))
allocate(values(nptsx1,nptsx2))
! Fill the arrays with the needed information.
do j=1, nptsx2
eta2 = field%T%mesh%eta2_min + real(j-1,8)*field%T%mesh%delta_eta2
do i=1, nptsx1
eta1 = field%T%mesh%eta1_min + real(i-1,8)*field%T%mesh%delta_eta1
x1coords(i,j) = field%T%x1(eta1,eta2)
x2coords(i,j) = field%T%x2(eta1,eta2)
values(i,j) = field%value_at_point(eta1,eta2)
end do
end do
do i = 1, nptsx1
print"(5f5.0)", values(i,:)
end do
deallocate(x1coords)
deallocate(x2coords)
deallocate(values)
end program test_scalar_field_2d
Result must be:
./run
11. 12. 13. 14. 15.
21. 22. 23. 24. 25.
31. 32. 33. 34. 35.
41. 42. 43. 44. 45.
51. 52. 53. 54. 55.
But i got a segmentation fault with pgi compiler.
Sorry for this very long code, i am keep looking the error.
Pierre
