camera:
YUV422-8bit, UYVY, 1920*1280, csi2-4 lanes
I have a camera with isp , which works fine on Jetpack-4.4.1. The interface is FPD-link. So my configure in device tree works OK.
Now I need to upgrade the system to Jetpack-5.0.1-DP and I recompile the kernel modules of camera driver, but the camera can’t work.
when I change the configure about pix_clk_hz as follow:
pix_clk_hz = "74250000";
serdes_pix_clk_hz = "100000000";
the debug com output:
[ 117.399165] tegra-camrtc-capture-vi tegra-capture-vi: corr_err: discarding frame 0, flags: 0, err_data 131072
[ 117.432499] tegra-camrtc-capture-vi tegra-capture-vi: corr_err: discarding frame 0, flags: 0, err_data 131072
[ 117.465832] tegra-camrtc-capture-vi tegra-capture-vi: corr_err: discarding frame 0, flags: 0, err_data 131072
serdes_pix_clk_hz = "74250000";
[ 118.904410] tegra-camrtc-capture-vi tegra-capture-vi: corr_err: discarding frame 0, flags: 0, err_data 512
[ 119.104421] tegra-camrtc-capture-vi tegra-capture-vi: corr_err: discarding frame 0, flags: 0, err_data 512
[ 119.137650] tegra-camrtc-capture-vi tegra-capture-vi: corr_err: discarding frame 0, flags: 0, err_data 512
the picture from cheese:
the strange thing is that the camera can work when I use these commands which I get in other topics.
echo 1 > /sys/kernel/debug/bpmp/debug/clk/vi/mrq_rate_locked
echo 1 > /sys/kernel/debug/bpmp/debug/clk/isp/mrq_rate_locked
echo 1 > /sys/kernel/debug/bpmp/debug/clk/nvcsi/mrq_rate_locked
echo 1 > /sys/kernel/debug/bpmp/debug/clk/emc/mrq_rate_locked
some debug info:
root@nvidia:~# cat /sys/kernel/debug/bpmp/debug/clk/vi/max_rate |tee /sys/kernel/debug/bpmp/debug/clk/vi/rate
998400000
root@nvidia:~# cat /sys/kernel/debug/bpmp/debug/clk/isp/max_rate | tee /sys/kernel/debug/bpmp/debug/clk/isp/rate
1190400000
root@nvidia:~# cat /sys/kernel/debug/bpmp/debug/clk/nvcsi/max_rate | tee /sys/kernel/debug/bpmp/debug/clk/nvcsi/rate
400000000
root@nvidia:~# cat /sys/kernel/debug/bpmp/debug/clk/emc/max_rate | tee /sys/kernel/debug/bpmp/debug/clk/emc/rate
2133000000
