I tried to run 10_camera_recording on tx2.
After several minutes, the applications quit with a lot of error dumped.
Could any help give some suggestion?
https://wiki.nvidia.com/wmpwiki/index.php/Camera_Debugging cannot be opened.
create vidoe converter return true
CONSUMER: Waiting until producer is connected...
PRODUCER: Starting repeat capture requests.
CONSUMER: Producer has connected; continuing.
SCF: Error InvalidState: NonFatal ISO BW requested not set. Requested = 2147483647 Set = 4687500 (in src/services/power/PowerServiceCore.cpp, function setCameraBw(), line 653)
PRODUCER: Creating output stream
PRODUCER: Launching consumer thread
Failed to query video capabilities: Inappropriate ioctl for device
libv4l2_nvvidconv (0):(792) (INFO) : Allocating (3) OUTPUT PLANE BUFFERS Layout=1
libv4l2_nvvidconv (0):(808) (INFO) : Allocating (3) CAPTURE PLANE BUFFERS Layout=0
SCF: Error InvalidState: NonFatal ISO BW requested not set. Requested = 2147892848 Set = 4687500 (in src/services/power/PowerServiceCore.cpp, function setCameraBw(), line 653)
SCF: Error InvalidState: NonFatal ISO BW requested not set. Requested = 2147729740 Set = 4687500 (in src/services/power/PowerServiceCore.cpp, function setCameraBw(), line 653)
SCF: Error InvalidState: NonFatal ISO BW requested not set. Requested = 2147975833 Set = 4687500 (in src/services/power/PowerServiceCore.cpp, function setCameraBw(), line 653)
NvViErrorDecode Stream 0.0 failed: ts 1628544827072 frame 178 error 7 data 0x00000001
NvViErrorDecode CaptureError: ChanselShortFrame (7)
NvViErrorDecode See https://wiki.nvidia.com/wmpwiki/index.php/Camera_Debugging/CaptureError_debugging for more information and links to documents.
ChanselShortFrame : 0x00000001
Channels with PIXEL_INCOMPLETE [11: 0]:
Channels 0
This can happen for three reasons: PIXEL_SHORT_FRAME: FE packet arrives before last expected pixel of the uncropped image; EMPTY_FRAME: FE packet arrives before cropped pixels other embedded data been received; PIXEL_OPEN_LINE: A pixel line has been opened with line start but FE packet arrives before line end ever arrives.
SCF: Error Timeout: (propagating from src/services/capture/CaptureServiceDevice.cpp, function issueCaptures(), line 1066)
captureErrorCallback Stream 0.0 capture 9489 failed: ts 1628544827072 frame 178 error 7 data 0x00000001
SCF: Error Timeout: (propagating from src/common/Utils.cpp, function workerThread(), line 114)
SCF: Error Timeout: Worker thread CaptureScheduler frameStart failed (in src/common/Utils.cpp, function workerThread(), line 131)
SCF: Error InvalidState: Capture Scheduler not running (in src/services/capture/CaptureServiceDevice.cpp, function addNewItemToSchedule(), line 841)
SCF: Error InvalidState: (propagating from src/services/capture/CaptureService.cpp, function addRequest(), line 739)
SCF: Error InvalidState: (propagating from src/components/stages/MemoryToISPCaptureStage.cpp, function doHandleRequest(), line 129)
SCF: Error InvalidState: (propagating from src/components/stages/OrderedStage.cpp, function doExecute(), line 158)
SCF: Error InvalidState: Sending critical error event (in src/api/Session.cpp, function sendErrorEvent(), line 992)
SCF: Error Timeout: (propagating from src/api/Buffer.cpp, function waitForUnlock(), line 591)
