hi,
I’m using a usb camera on Jetson Xavier with opencv,but the fps is too low, it’s only 5, my code is like this
cv::VideoCapture cap;
cv::Mat img;
cap.open(0);
while(true)
cap >> img;
cv::imshow(“ret”, img);
and I get warning “cap_gstreamer.cpp (933) open OpenCV | GStreamer warning: Cannot query video position: status=0, value=-1, duration=-1”
Please run with sudo jetson_clocks to enable high cpu clk and then run your app again.
You may also try adding :
cv::waitKey(1);
after cv::imshow, so that opencv drawing thread can be scheduled.
hi,
thanks for your reply,
It seems that jetson_clocks doesn’t work,I still get 5 fps when I run sudo jetson_clocks,
when I set CAP_PROP_FRAME_WIDTH and CAP_PROP_FRAME_HEIGHT as 640x480, it looks like faster
but when I print CAP_PROP_FPS it’s still 5
I have cv::waitKey(200) in loop, fps is still 5
If you wait for 200ms for each frame, you cannot get more than 5 fps. I’d suggest to use 1ms for now.
You may check the available modes for your sensor with:
v4l2-ctl -d0 --list-formats-ext
and post these for better advice. (v4l2-ctl is provided by apt package v4l-utils)
You may be able to set width, height and fps according to the mode you want after cap.open().
Also note that you may have to perform a read for fps value read from CAP_PROP_FPS to be updated.
Also note that imshow is not very fast on jetson for high resolutions. You may try a videoWriter with a gstreamer pipeline to nvoverlaysink instead:
cv::VideoWriter gst_testsink;
gst_testsink.open("appsrc ! queue ! videoconvert ! video/x-raw, format=RGBA ! nvvidconv ! nvoverlaysink ", cv::CAP_GSTREAMER, 0, fps, cv::Size(width, height));
in the loop, you would remove imshow and waitKey and use instead:
while(1)
if (!cap.read(img)) {
std::cout<<"Capture read error"<<std::endl;
break;
gst_testsink.write(img);
gst_testsink.release();
cap.release();
hi, thanks for your reply, here is what I got from v4l2-ctl
ioctl: VIDIOC_ENUM_FMT
Index : 0
Type : Video Capture
Pixel Format: 'MJPG' (compressed)
Size: Discrete 1920x1080
Interval: Discrete 0.033s (30.000 fps)
Interval: Discrete 0.032s (31.000 fps)
Index : 1
Pixel Format: 'YUYV'
Interval: Discrete 0.200s (5.000 fps)
Interval: Discrete 0.048s (21.000 fps)
Interval: Discrete 0.091s (11.000 fps)
Interval: Discrete 0.077s (13.000 fps)
Interval: Discrete 0.111s (9.000 fps)
Interval: Discrete 0.167s (6.000 fps)
I also modified my code like this
int main()
VideoCapture cap(0);
gst_testsink.open("appsrc ! queue ! videoconvert ! video/x-raw, format=RGBA ! nvvidconv ! nvoverlaysink ", cv::CAP_GSTREAMER, 0, 3, cv::Size(640, 480));
cv::Mat img;
double fps=0;
cap.set(cv::CAP_PROP_FRAME_WIDTH,640);
cap.set(cv::CAP_PROP_FRAME_HEIGHT,480);
cap.set(cv::CAP_PROP_FPS,30);
while(true)
break;
//imshow("CamShow",frame);
fps = cap.get(cv::CAP_PROP_FPS);
cout<<"FPS:"<<fps<<endl;
waitKey(1);
cap.release();
return 0;
when I ran the code, the output is
xavier2@xavier2-desktop:~/code/videoCapture/build$ ./videoCapture
[ WARN:0] global /home/nvidia/host/build_opencv/nv_opencv/modules/videoio/src/cap_gstreamer.cpp (933) open OpenCV | GStreamer warning: Cannot query video position: status=0, value=-1, duration=-1
FPS:5
FPS:5
FPS:5
FPS:5
FPS:5
FPS:5
FPS:5
FPS:5
FPS:5
FPS:5
when I set width and height as 640x480 and used gstreamer pipeline I still got 5 fps,
but when I used imshow instead, it became much faster, the print of CAP_PROP_FPS was always 5,
It seemed that cap.set(cv::CAP_PROP_FPS,30) didn’t work
You may try a gstreamer pipeline for capture as well.
First check this works:
gst-launch-1.0 v4l2src device=/dev/video0 ! video/x-raw, format=YUY2, width=640, height=480, framerate=30/1 ! videoconvert ! xvimagesink
If ok for opencv you would make a pipeline into BGR format for appsink
VideoCapture cap("v4l2src device=/dev/video0 ! video/x-raw, format=YUY2, width=640, height=480, framerate=30/1 ! videoconvert ! video/x-raw, format=BGR ! appsink", cv::CAP_GSTREAMER);
For higher resolutions, videoconvert may be slow, so you could also try to perform YUV->BGR conversion with HW:
VideoCapture cap("v4l2src device=/dev/video0 ! video/x-raw, format=YUY2, width=640, height=480, framerate=30/1 ! nvvidconv ! video/x-raw(memory:NVMM) ! nvvidconv ! video/x-raw, format=BGRx ! videoconvert ! video/x-raw, format=BGR ! appsink", cv::CAP_GSTREAMER);
