hi,
We have a Bright way vision camera(https://www.brightwayvision.com/wp-content/uploads/2016/09/System.pdf) which has two video outputs, HDMI(30FPS) and Camera-link(120FPS) ,The output from HDMI is not in standard format, so am planning to use Camera-link… i want to connect the camera to NVIDIA-TX2 board using a video converter card from Camera-link to USB…Please suggest me a capture card which has compatibility with NVIDIA-TX2 board.
Regards,
Niranjan B
              Hi Niranjan, have you seen the Pleora CameraLink to USB3 series of converters?
[url]http://www.pleora.com/our-products/frame-grabbers/iport-cl-u3[/url]
Their SDK for interfacing with the devices has support for arm64/aarch64 architecture, although I haven’t personally tried it on Jetson.  You may also be interested in their variant that converts CameraLink to Gigabit Ethernet:
[url]http://www.pleora.com/our-products/frame-grabbers/iport-cl-gige[/url]
              The Pleora eBUS SDK does support the Jetson platform and we are an NVIDIA Jetson partner.
              For those interested in linking a CameraLink camera to a JetsonTX2: https://www.epixinc.com/products/pixci_e4tx2.htm
Epix has a solution that might meets your needs.
