Hi, Im looking into purchasing a TX2 dev Kit. I will be doing some research, basically with how a high viscosity fluid (oils) spills out of a container. I currently have some basler ace cameras (acA1300-30gm, acA2000-50gc, acA2500-14gc) and wanted to know if I can use any of those with the TX2. I have tried to research it but I´ve read posts that say I should be able to and posts that say I can´t.
If not, which ones are some good cameras to work with? I saw a list of the e-con Systems cameras that are compatible for the TX1, but I also saw a post
https://devtalk.nvidia.com/default/topic/1009401/?comment=5150521
where it says that they don´t have compatible kernels for the TX2
I´m looking for a color USB3 camera for the simplicity. I dont need that high frame rate. somewhere between 15-30fps. and at 720p at 1.5-2Mpixels.
