On Jeston TX2, I need the camera to produce HD video, and need these video can be stored to my specified location.
Which cameras have you tested and performance is good on TX2?
Which camera interface (CSI or USB) is better for my situation?
I am using the logitech USB webcam as my project
There are C9XX series and if you do some research, you can find out that C920 is actually widely used for the computer vision project.
Here are the list of cameras that I would recommend and has been tested on the Jetson TX2 board that can serve your purpose made by e-con systems.
3.4 MP AF AR0330 MIPI Jetson TX2 Camera - e-CAM31_TX2 - 3.4 MP NVIDIA Jetson TX2/TX1 Camera Board
3.4 MP AR0330 MIPI Jetson TX2 Camera - e-CAM30_CUTX1 - 3.4 MP NVIDIA Jetson TX2/TX1 Camera Board
13MP AR1335 MIPI Jetson TX2 Camera - 13MP NVIDIA Jetson TX2 Camera Board - e-CAM131_CUTX2
13MP AR1820 MIPI Jetson TX2 Camera - 13MP NVIDIA Jetson TX1 Camera Module - e-CAM130_CUTX1
For details refer Jetson TX2 - eLinux.org
To recommend on the usage of USB or CSI camera interface, we must first know your application in detail to help you choose. Generally MIPI interface is recommended for optimal CPU processing and better performance.
Please, would you know which camera are compatible with TX1/TX2, with a maximum resolution (at less 12 MP) and with global shutter mode?
I am using the default devkit onboard ov5693 and that works quite well
Thanks Andrey, but it seems ov5693 is a Rolling shutter camera. I’m looking ofr a global shutter camera
