Available Cameras on TX2?
Hello Everyone,
What is the available cameras supports on TX1/TX2?
Also I’m looking for a camera that covers 360 degrees view?
Hi Abdullah-Kamel,
NVIDIA enables camera partner Leopard Imaging to provide support for our platform.
Here is more info for your reference:
[url]https://developer.nvidia.com/embedded/community/partners[/url]
Hi Abdullah,
 Some questions to help you better:
 1) Could you provide more details about the system that you are trying to develop?
 2)Do you want to use the 6 camera inputs?
 3) What is the field of view per sensor that you need?
 4) What is the resolution required and framerate?
 5) If you are trying to create panoramas I suppose that you need to capture all the images at the same time, are you creating hardware considering that all the sensors should be trigger at the same time?
  6) or in your specs it is okay to trigger the sensors at different moments? Which is the time tolerance?
You can get some tips from here:
RidgeRun is a software only company, we can help you from the software side, please feel free to contact us,
-David
E-con systems has a list of MIPI and USB cameras that have been successfully tested and are known to be supported on the Jetson TX1/TX2. You can choose any one of the camera modules for your use.
USB 3.0 webcams known to be working:
See3CAM_CU135 - 4K USB Camera board | 13MP 4K board camera
See3CAM_130 - 13MP Autofocus USB Camera | High Resolution Camera
See3CAM_CU30 - Low Light USB Camera Board | AR0330 Xilinx's Box Camera
See3CAM_30 - 3.4 MP USB autofocus Liquid lens camera board
See3CAM_81 - 13MP Autofocus USB Camera | High Resolution Camera
TARA STEREO CAMERA - Tara – 3D Stereo Camera for Depth Sensing
CSI - 2 MIPI cameras known to be working:
4K Autofocus MIPI NVIDIA® Jetson TX2/TX1 Camera - 13MP 4K Autofocus MIPI NVIDIA® Jetson TX2 Camera Board
13MP AR1335 MIPI Jetson TX2/TX1 Camera - 13MP NVIDIA Jetson TX2 Camera Board - e-CAM131_CUTX2
3.4 MP AR0330 MIPI Jetson TX2/TX1 Camera(Autofocus) - e-CAM31_TX2 - 3.4 MP NVIDIA Jetson TX2/TX1 Camera Board
13MP AR1820 MIPI Jetson TX2/TX1 Camera - 13MP NVIDIA Jetson TX1 Camera Module - e-CAM130_CUTX1
3.4 MP AR0330 MIPI Jetson TX2/TX1 Camera - e-CAM30_CUTX1 - 3.4 MP NVIDIA Jetson TX2/TX1 Camera Board
2MP Sony Ultra-low light Jetson TX2/TX1 Camera - 2MP Sony STARVIS IMX290 Ultra-low light Jetson TX2 Camera
2MP HDR Jetson TX2/TX1 Camera Board - 2MP HDR Jetson TX2/TX1 Camera Board
Multi-Camera System:
Six Synchronized Full HD Cameras for NVIDIA® Jetson TX1/TX2 - Multiple MIPI CSI-2 Cameras for NVIDIA Jetson AGX Xavier/TX2
Three Synchronized 4K Multi-Camera System - Three Synchronized 4K Cameras for NVIDIA Jetson TX2
GMSL Camera:
NileCAM30_TX2 - 3.4 MP GMSL camera (supports upto 15 meters) - 3.4 MP GMSL Camera for NVIDIA Jetson TX2
Stereo Camera:
TaraXL - USB Stereo Camera for NVIDIA GPU - 3D USB Stereo Camera for NVIDIA® GPU
