im planning on designing a security system with the jetson Tx2 and wanted to use the camera below.
https://www.e-consystems.com/three-synchronized-4k-cameras-for-nvidia-jetson-tx2.asp#key-features
will i be able to just plug this into the Tx2 and then implement some facial recognition?
Also will i be able to turn off 2 cameras and put all power into just one camera?
Please consult with e-con should be able get more detail information.
The Cameras drivers are V4L2 compliance and the camera can be operated by any standard V4L2 based application. So you can run your facial recognition algorithm.
Can you elaborate “put all power into one camera”?
There are no power constraints in the existing system. You can operate one camera or all the three at the same time.
Also, you can drop a mail to our sales@e-consystems.com. Our Camera solution experts will porivide you more details.
