I have a SerDes camera. I can use the gst-launch-1.0 nvarguscamerasrc to open the camera once time. But after i close the camera, I can’t open the camera again. Even I restart the nvargus-daemon or hot reboot the system, it is the same. Only i shut down the Xavier Power do the cold reboot system, the camera can be open one time, the other open will fail.
The open camera command:
gst-launch-1.0 nvarguscamerasrc sensor-id=0 ! 'video/x-raw(memory:NVMM), width=(int)1920, height=(int)1080, format=(string)NV12, framerate=(fraction)30/1' ! nvvidconv ! 'video/x-raw, width=(int)960, height=(int)540, format=(string)I420' ! xvimagesink -e
Setting pipeline to PAUSED ...
Pipeline is live and does not need PREROLL ...
Setting pipeline to PLAYING ...
New clock: GstSystemClock
GST_ARGUS: Creating output stream
CONSUMER: Waiting until producer is connected...
GST_ARGUS: Available Sensor modes :
GST_ARGUS: 1920 x 1080 FR = 29.999999 fps Duration = 33333334 ; Analog Gain range min 1.000000, max 12.000000; Exposure Range min 33000, max 660000000;
GST_ARGUS: Running with following settings:
Camera index = 0
Camera mode = 0
Output Stream W = 1920 H = 1080
seconds to Run = 0
Frame Rate = 29.999999
GST_ARGUS: PowerService: requested_clock_Hz=27216000
GST_ARGUS: Setup Complete, Starting captures for 0 seconds
GST_ARGUS: Starting repeat capture requests.
CONSUMER: Producer has connected; continuing.
<b>(Wait here, no preview image...)</b>
^Chandling interrupt.
Interrupt: Stopping pipeline ...
EOS on shutdown enabled -- Forcing EOS on the pipeline
The kernel log:
Jun 4 21:22:45 nvidia-desktop kernel: [ 355.458538] ov2775 2-0010: ov2775_set_gain: Enter.
Jun 4 21:22:45 nvidia-desktop kernel: [ 355.471392] ov2775 2-0010: ov2775_set_gain: Set LCG WB Gain!!!
Jun 4 21:22:45 nvidia-desktop kernel: [ 355.471420] ov2775 2-0010: ov2775_set_gain: val 0x00000100(256) gain: 0x0000(0)
Jun 4 21:22:45 nvidia-desktop kernel: [ 355.471443] ov2775 2-0010: ov2775_set_exposure: set val: 33333, actual: 1126
Jun 4 21:22:45 nvidia-desktop kernel: [ 355.476797] ov2775 2-0010: ov2775_set_exposure: set val: 33330, actual: 1126
Jun 4 21:22:45 nvidia-desktop kernel: [ 355.484917] ov2775 2-0010: ov2775_set_mode: Enter.
Jun 4 21:22:45 nvidia-desktop kernel: [ 355.793929] ov2775 2-0010: ov2775_set_gain: Enter.
Jun 4 21:22:45 nvidia-desktop kernel: [ 355.795042] ov2775 2-0010: ov2775_set_gain: val 0x00000100(256) gain: 0x0000(0)
Jun 4 21:22:45 nvidia-desktop kernel: [ 355.795050] ov2775 2-0010: ov2775_set_exposure: set val: 33330, actual: 1126
Jun 4 21:22:45 nvidia-desktop kernel: [ 355.796146] ov2775 2-0010: ov2775_set_frame_rate: set val: 30000000, actual: 1126
Jun 4 21:22:45 nvidia-desktop kernel: [ 355.799815] ov2775 2-0010: ov2775_update_ctrl_range: Enter.
Jun 4 21:22:45 nvidia-desktop kernel: [ 355.799862] ov2775 2-0010: ov2775_set_exposure: set val: 32765, actual: 1107
Jun 4 21:22:45 nvidia-desktop kernel: [ 355.802363] ov2775 2-0010: ov2775_start_streaming: Enter.
Jun 4 21:22:47 nvidia-desktop kernel: [ 357.316360] fence timeout on [ffffffc37f9089c0] after 1500ms
Jun 4 21:22:47 nvidia-desktop kernel: [ 357.316376] name=[nvhost_sync:35], current value=0 waiting value=1
Jun 4 21:22:47 nvidia-desktop kernel: [ 357.316385] ---- mlocks ----
Jun 4 21:22:47 nvidia-desktop kernel: [ 357.316404] tegra194-vi5 15c10000.vi: no reply from camera processor
Jun 4 21:22:47 nvidia-desktop kernel: [ 357.316471]
Jun 4 21:22:47 nvidia-desktop kernel: [ 357.316474] ---- syncpts ----
Jun 4 21:22:47 nvidia-desktop kernel: [ 357.316481] id 2 (disp_a) min 3045 max 3045 refs 1 (previous client : )
Jun 4 21:22:47 nvidia-desktop kernel: [ 357.316485] id 3 (disp_b) min 2 max 2 refs 1 (previous client : )
Jun 4 21:22:47 nvidia-desktop kernel: [ 357.316493] id 8 (vblank0) min 20363 max -4 refs 1 (previous client : )
Jun 4 21:22:47 nvidia-desktop kernel: [ 357.316501] id 16 (gv11b_511) min 37038 max 37038 refs 1 (previous client : )
Jun 4 21:22:47 nvidia-desktop kernel: [ 357.316505] id 17 (gv11b_510) min 7 max 7 refs 1 (previous client : )
Jun 4 21:22:47 nvidia-desktop kernel: [ 357.316511] id 18 (gv11b_509) min 7698 max 7698 refs 1 (previous client : gv11b_509)
Jun 4 21:22:47 nvidia-desktop kernel: [ 357.316515] id 19 (15340000.vic_gst-launch-1.0_0) min 2781 max 2781 refs 1 (previous client : 15340000.vic_gst-launch-1.0_0)
Jun 4 21:22:47 nvidia-desktop kernel: [ 357.316519] id 20 (15340000.vic_gst-launch-1.0_0) min 2775 max 2775 refs 1 (previous client : 15340000.vic_gst-launch-1.0_0)
Jun 4 21:22:47 nvidia-desktop kernel: [ 357.316558] id 37 (gv11b_500) min 3 max 3 refs 1 (previous client : 15340000.vic_nvargus-daemon_0)
Jun 4 21:22:47 nvidia-desktop kernel: [ 357.316563] id 38 (15340000.vic_nvargus-daemon_0) min 12 max 12 refs 1 (previous client : gv11b_502)
Jun 4 21:22:47 nvidia-desktop kernel: [ 357.316567] id 39 (gv11b_499) min 15 max 15 refs 1 (previous client : gv11b_499)
Jun 4 21:22:47 nvidia-desktop kernel: [ 357.316571] id 40 (gv11b_503) min 16 max 16 refs 1 (previous client : gv11b_500)
Jun 4 21:22:47 nvidia-desktop kernel: [ 357.316574] id 41 (gv11b_501) min 15 max 15 refs 1 (previous client : gv11b_503)
Jun 4 21:22:47 nvidia-desktop kernel: [ 357.316579] id 42 (gv11b_502) min 15 max 15 refs 1 (previous client : gv11b_501)
Jun 4 21:22:47 nvidia-desktop kernel: [ 357.316678] tegra194-vi5 15c10000.vi: vi capture get status failed
Jun 4 21:22:47 nvidia-desktop kernel: [ 357.317036]
Jun 4 21:22:47 nvidia-desktop kernel: [ 357.317040] ---- channels ----
Jun 4 21:22:47 nvidia-desktop kernel: [ 357.317094]
Jun 4 21:22:47 nvidia-desktop kernel: [ 357.317094] channel 2 - 15820000.se
Jun 4 21:22:47 nvidia-desktop kernel: [ 357.317098] NvHost basic channel registers:
Jun 4 21:22:47 nvidia-desktop kernel: [ 357.317106] CMDFIFO_STAT_0: 00002040
Jun 4 21:22:47 nvidia-desktop kernel: [ 357.317109] CMDFIFO_RDATA_0: 0020920c
Jun 4 21:22:47 nvidia-desktop kernel: [ 357.317114] CMDP_OFFSET_0: 00000000
Jun 4 21:22:47 nvidia-desktop kernel: [ 357.317118] CMDP_CLASS_0: 00000000
Jun 4 21:22:47 nvidia-desktop kernel: [ 357.317129] CHANNELSTAT_0: 00000000
Jun 4 21:22:47 nvidia-desktop kernel: [ 357.317132] The CDMA sync queue is empty.
Jun 4 21:22:47 nvidia-desktop kernel: [ 357.317134]
Jun 4 21:22:47 nvidia-desktop kernel: [ 357.317142]
Jun 4 21:22:47 nvidia-desktop kernel: [ 357.317142] channel 3 - 15830000.se
Jun 4 21:22:47 nvidia-desktop kernel: [ 357.317145] NvHost basic channel registers:
Jun 4 21:22:47 nvidia-desktop kernel: [ 357.317148] CMDFIFO_STAT_0: 00002040
Jun 4 21:22:47 nvidia-desktop kernel: [ 357.317152] CMDFIFO_RDATA_0: 0010d80a
Jun 4 21:22:47 nvidia-desktop kernel: [ 357.317156] CMDP_OFFSET_0: 00000000
Jun 4 21:22:47 nvidia-desktop kernel: [ 357.317160] CMDP_CLASS_0: 00000000
Jun 4 21:22:47 nvidia-desktop kernel: [ 357.317163] CHANNELSTAT_0: 00000000
Jun 4 21:22:47 nvidia-desktop kernel: [ 357.317166] The CDMA sync queue is empty.
Jun 4 21:22:47 nvidia-desktop kernel: [ 357.317168]
Jun 4 21:22:47 nvidia-desktop kernel: [ 357.317173]
Jun 4 21:22:47 nvidia-desktop kernel: [ 357.317173] channel 4 - 15840000.se
Jun 4 21:22:47 nvidia-desktop kernel: [ 357.317175] NvHost basic channel registers:
Jun 4 21:22:47 nvidia-desktop kernel: [ 357.317179] CMDFIFO_STAT_0: 00002040
Jun 4 21:22:47 nvidia-desktop kernel: [ 357.317182] CMDFIFO_RDATA_0: 00000000
Jun 4 21:22:47 nvidia-desktop kernel: [ 357.317186] CMDP_OFFSET_0: 00000000
Jun 4 21:22:47 nvidia-desktop kernel: [ 357.317190] CMDP_CLASS_0: 00000000
Jun 4 21:22:47 nvidia-desktop kernel: [ 357.317193] CHANNELSTAT_0: 00000000
Jun 4 21:22:47 nvidia-desktop kernel: [ 357.317196] The CDMA sync queue is empty.
Jun 4 21:22:47 nvidia-desktop kernel: [ 357.317198]
Jun 4 21:22:47 nvidia-desktop kernel: [ 357.317205]
Jun 4 21:22:47 nvidia-desktop kernel: [ 357.317205] ---- host general irq ----
Jun 4 21:22:47 nvidia-desktop kernel: [ 357.317209] sync_intc0mask = 0x00000001
Jun 4 21:22:47 nvidia-desktop kernel: [ 357.317213] sync_intmask = 0x50000003
Jun 4 21:22:47 nvidia-desktop kernel: [ 357.317215]
Jun 4 21:22:47 nvidia-desktop kernel: [ 357.317215] ---- host syncpt irq mask ----
Jun 4 21:22:47 nvidia-desktop kernel: [ 357.317218]
Jun 4 21:22:47 nvidia-desktop kernel: [ 357.317218] ---- host syncpt irq status ----
Jun 4 21:22:47 nvidia-desktop kernel: [ 357.317223] syncpt_thresh_cpu0_int_status(0) = 0x00000000
Jun 4 21:22:47 nvidia-desktop kernel: [ 357.317252] syncpt_thresh_cpu0_int_status(1) = 0x00000000
Jun 4 21:22:47 nvidia-desktop kernel: [ 357.317256] syncpt_thresh_cpu0_int_status(2) = 0x00000000
Jun 4 21:22:47 nvidia-desktop kernel: [ 357.317260] syncpt_thresh_cpu0_int_status(3) = 0x00000000
Jun 4 21:22:47 nvidia-desktop kernel: [ 357.317264] syncpt_thresh_cpu0_int_status(4) = 0x00000000
Jun 4 21:22:47 nvidia-desktop kernel: [ 357.317267] syncpt_thresh_cpu0_int_status(5) = 0x00000000
Jun 4 21:22:47 nvidia-desktop kernel: [ 357.317271] syncpt_thresh_cpu0_int_status(6) = 0x00000000
Jun 4 21:22:47 nvidia-desktop kernel: [ 357.317275] syncpt_thresh_cpu0_int_status(7) = 0x00000000
Jun 4 21:22:47 nvidia-desktop kernel: [ 357.317278] syncpt_thresh_cpu0_int_status(8) = 0x00000000
Jun 4 21:22:47 nvidia-desktop kernel: [ 357.317309] syncpt_thresh_cpu0_int_status(9) = 0x00000000
Jun 4 21:22:47 nvidia-desktop kernel: [ 357.317313] syncpt_thresh_cpu0_int_status(10) = 0x00000000
Jun 4 21:22:47 nvidia-desktop kernel: [ 357.317317] syncpt_thresh_cpu0_int_status(11) = 0x00000000
Jun 4 21:22:47 nvidia-desktop kernel: [ 357.317321] syncpt_thresh_cpu0_int_status(12) = 0x00000000
Jun 4 21:22:47 nvidia-desktop kernel: [ 357.317324] syncpt_thresh_cpu0_int_status(13) = 0x00000000
Jun 4 21:22:47 nvidia-desktop kernel: [ 357.317328] syncpt_thresh_cpu0_int_status(14) = 0x00000000
Jun 4 21:22:47 nvidia-desktop kernel: [ 357.317332] syncpt_thresh_cpu0_int_status(15) = 0x00000000
Jun 4 21:22:47 nvidia-desktop kernel: [ 357.317336] syncpt_thresh_cpu0_int_status(16) = 0x00000000
Jun 4 21:22:47 nvidia-desktop kernel: [ 357.317339] syncpt_thresh_cpu0_int_status(17) = 0x00000000
Jun 4 21:22:47 nvidia-desktop kernel: [ 357.317343] syncpt_thresh_cpu0_int_status(18) = 0x00000000
Jun 4 21:22:47 nvidia-desktop kernel: [ 357.317347] syncpt_thresh_cpu0_int_status(19) = 0x00000000
Jun 4 21:22:47 nvidia-desktop kernel: [ 357.317351] syncpt_thresh_cpu0_int_status(20) = 0x00000000
Jun 4 21:22:47 nvidia-desktop kernel: [ 357.317355] syncpt_thresh_cpu0_int_status(21) = 0x00000000
Jun 4 21:22:48 nvidia-desktop kernel: [ 358.820353] fence timeout on [ffffffc37f921b40] after 1500ms
Jun 4 21:22:48 nvidia-desktop kernel: [ 358.820370] name=[nvhost_sync:35], current value=0 waiting value=9
Jun 4 21:22:48 nvidia-desktop kernel: [ 358.820382] ---- mlocks ----
Jun 4 21:22:48 nvidia-desktop kernel: [ 358.820454]
Jun 4 21:22:48 nvidia-desktop kernel: [ 358.820457] ---- syncpts ----
Jun 4 21:22:48 nvidia-desktop kernel: [ 358.820520] id 2 (disp_a) min 3045 max 3045 refs 1 (previous client : )
Jun 4 21:22:48 nvidia-desktop kernel: [ 358.820526] id 3 (disp_b) min 2 max 2 refs 1 (previous client : )
Jun 4 21:22:48 nvidia-desktop kernel: [ 358.820538] id 8 (vblank0) min 20453 max -4 refs 1 (previous client : )
Jun 4 21:22:48 nvidia-desktop kernel: [ 358.820581] id 16 (gv11b_511) min 37038 max 37038 refs 1 (previous client : )
Jun 4 21:22:48 nvidia-desktop kernel: [ 358.820586] id 17 (gv11b_510) min 7 max 7 refs 1 (previous client : )
Jun 4 21:22:48 nvidia-desktop kernel: [ 358.820592] id 18 (gv11b_509) min 7698 max 7698 refs 1 (previous client : gv11b_509)
Jun 4 21:22:48 nvidia-desktop kernel: [ 358.820599] id 19 (15340000.vic_gst-launch-1.0_0) min 2781 max 2781 refs 1 (previous client : 15340000.vic_gst-launch-1.0_0)
Jun 4 21:22:48 nvidia-desktop kernel: [ 358.820604] id 20 (15340000.vic_gst-launch-1.0_0) min 2775 max 2775 refs 1 (previous client : 15340000.vic_gst-launch-1.0_0)
Jun 4 21:22:48 nvidia-desktop kernel: [ 358.820621] id 37 (gv11b_500) min 3 max 3 refs 1 (previous client : 15340000.vic_nvargus-daemon_0)
Jun 4 21:22:48 nvidia-desktop kernel: [ 358.820626] id 38 (15340000.vic_nvargus-daemon_0) min 12 max 12 refs 1 (previous client : gv11b_502)
Jun 4 21:22:48 nvidia-desktop kernel: [ 358.820631] id 39 (gv11b_499) min 15 max 15 refs 1 (previous client : gv11b_499)
Jun 4 21:22:48 nvidia-desktop kernel: [ 358.820635] id 40 (gv11b_503) min 16 max 16 refs 1 (previous client : gv11b_500)
Jun 4 21:22:48 nvidia-desktop kernel: [ 358.820641] id 41 (gv11b_501) min 15 max 15 refs 1 (previous client : gv11b_503)
Jun 4 21:22:48 nvidia-desktop kernel: [ 358.820645] id 42 (gv11b_502) min 15 max 15 refs 1 (previous client : gv11b_501)
Jun 4 21:22:48 nvidia-desktop kernel: [ 358.821072]
Jun 4 21:22:48 nvidia-desktop kernel: [ 358.821074] ---- channels ----
Jun 4 21:22:48 nvidia-desktop kernel: [ 358.821114]
Jun 4 21:22:48 nvidia-desktop kernel: [ 358.821114] channel 2 - 15820000.se
Jun 4 21:22:48 nvidia-desktop kernel: [ 358.821117] NvHost basic channel registers:
Jun 4 21:22:48 nvidia-desktop kernel: [ 358.821136] CMDFIFO_STAT_0: 00002040
Jun 4 21:22:48 nvidia-desktop kernel: [ 358.821142] CMDFIFO_RDATA_0: 0020920c
Jun 4 21:22:48 nvidia-desktop kernel: [ 358.821148] CMDP_OFFSET_0: 00000000
Jun 4 21:22:48 nvidia-desktop kernel: [ 358.821152] CMDP_CLASS_0: 00000000
Jun 4 21:22:48 nvidia-desktop kernel: [ 358.821156] CHANNELSTAT_0: 00000000
Jun 4 21:22:48 nvidia-desktop kernel: [ 358.821159] The CDMA sync queue is empty.
Jun 4 21:22:48 nvidia-desktop kernel: [ 358.821162]
Jun 4 21:22:48 nvidia-desktop kernel: [ 358.821168]
Jun 4 21:22:48 nvidia-desktop kernel: [ 358.821168] channel 3 - 15830000.se
Jun 4 21:22:48 nvidia-desktop kernel: [ 358.821170] NvHost basic channel registers:
Jun 4 21:22:48 nvidia-desktop kernel: [ 358.821174] CMDFIFO_STAT_0: 00002040
Jun 4 21:22:48 nvidia-desktop kernel: [ 358.821179] CMDFIFO_RDATA_0: 0010d80a
Jun 4 21:22:48 nvidia-desktop kernel: [ 358.821184] CMDP_OFFSET_0: 00000000
Jun 4 21:22:48 nvidia-desktop kernel: [ 358.821188] CMDP_CLASS_0: 00000000
Jun 4 21:22:48 nvidia-desktop kernel: [ 358.821191] CHANNELSTAT_0: 00000000
Jun 4 21:22:48 nvidia-desktop kernel: [ 358.821220] The CDMA sync queue is empty.
Jun 4 21:22:48 nvidia-desktop kernel: [ 358.821222]
Jun 4 21:22:48 nvidia-desktop kernel: [ 358.821228]
Jun 4 21:22:48 nvidia-desktop kernel: [ 358.821228] channel 4 - 15840000.se
Jun 4 21:22:48 nvidia-desktop kernel: [ 358.821231] NvHost basic channel registers:
Jun 4 21:22:48 nvidia-desktop kernel: [ 358.821234] CMDFIFO_STAT_0: 00002040
Jun 4 21:22:48 nvidia-desktop kernel: [ 358.821238] CMDFIFO_RDATA_0: 00000000
Jun 4 21:22:48 nvidia-desktop kernel: [ 358.821242] CMDP_OFFSET_0: 00000000
Jun 4 21:22:48 nvidia-desktop kernel: [ 358.821245] CMDP_CLASS_0: 00000000
Jun 4 21:22:48 nvidia-desktop kernel: [ 358.821260] CHANNELSTAT_0: 00000000
Jun 4 21:22:48 nvidia-desktop kernel: [ 358.821263] The CDMA sync queue is empty.
Jun 4 21:22:48 nvidia-desktop kernel: [ 358.821265]
Jun 4 21:22:48 nvidia-desktop kernel: [ 358.821272]
Jun 4 21:22:48 nvidia-desktop kernel: [ 358.821272] ---- host general irq ----
Jun 4 21:22:48 nvidia-desktop kernel: [ 358.821277] sync_intc0mask = 0x00000001
Jun 4 21:22:48 nvidia-desktop kernel: [ 358.821281] sync_intmask = 0x50000003
Jun 4 21:22:48 nvidia-desktop kernel: [ 358.821283]
Jun 4 21:22:48 nvidia-desktop kernel: [ 358.821283] ---- host syncpt irq mask ----
Jun 4 21:22:48 nvidia-desktop kernel: [ 358.821286]
Jun 4 21:22:48 nvidia-desktop kernel: [ 358.821286] ---- host syncpt irq status ----
Jun 4 21:22:48 nvidia-desktop kernel: [ 358.821291] syncpt_thresh_cpu0_int_status(0) = 0x00000000
Jun 4 21:22:48 nvidia-desktop kernel: [ 358.821295] syncpt_thresh_cpu0_int_status(1) = 0x00000000
Jun 4 21:22:48 nvidia-desktop kernel: [ 358.821300] syncpt_thresh_cpu0_int_status(2) = 0x00000000
Jun 4 21:22:48 nvidia-desktop kernel: [ 358.821304] syncpt_thresh_cpu0_int_status(3) = 0x00000000
Jun 4 21:22:48 nvidia-desktop kernel: [ 358.821308] syncpt_thresh_cpu0_int_status(4) = 0x00000000
Jun 4 21:22:48 nvidia-desktop kernel: [ 358.821313] syncpt_thresh_cpu0_int_status(5) = 0x00000000
Jun 4 21:22:48 nvidia-desktop kernel: [ 358.821317] syncpt_thresh_cpu0_int_status(6) = 0x00000000
Jun 4 21:22:48 nvidia-desktop kernel: [ 358.821321] syncpt_thresh_cpu0_int_status(7) = 0x00000000
Jun 4 21:22:48 nvidia-desktop kernel: [ 358.821325] syncpt_thresh_cpu0_int_status(8) = 0x00000000
Jun 4 21:22:48 nvidia-desktop kernel: [ 358.821329] syncpt_thresh_cpu0_int_status(9) = 0x00000000
Jun 4 21:22:48 nvidia-desktop kernel: [ 358.821332] syncpt_thresh_cpu0_int_status(10) = 0x00000000
Jun 4 21:22:48 nvidia-desktop kernel: [ 358.821362] syncpt_thresh_cpu0_int_status(11) = 0x00000000
Jun 4 21:22:48 nvidia-desktop kernel: [ 358.821379] syncpt_thresh_cpu0_int_status(12) = 0x00000000
Jun 4 21:22:48 nvidia-desktop kernel: [ 358.821384] syncpt_thresh_cpu0_int_status(13) = 0x00000000
Jun 4 21:22:48 nvidia-desktop kernel: [ 358.821387] syncpt_thresh_cpu0_int_status(14) = 0x00000000
Jun 4 21:22:48 nvidia-desktop kernel: [ 358.821391] syncpt_thresh_cpu0_int_status(15) = 0x00000000
Jun 4 21:22:48 nvidia-desktop kernel: [ 358.821395] syncpt_thresh_cpu0_int_status(16) = 0x00000000
Jun 4 21:22:48 nvidia-desktop kernel: [ 358.821398] syncpt_thresh_cpu0_int_status(17) = 0x00000000
Jun 4 21:22:48 nvidia-desktop kernel: [ 358.821412] syncpt_thresh_cpu0_int_status(18) = 0x00000000
Jun 4 21:22:48 nvidia-desktop kernel: [ 358.821417] syncpt_thresh_cpu0_int_status(19) = 0x00000000
Jun 4 21:22:48 nvidia-desktop kernel: [ 358.821420] syncpt_thresh_cpu0_int_status(20) = 0x00000000
Jun 4 21:22:48 nvidia-desktop kernel: [ 358.821424] syncpt_thresh_cpu0_int_status(21) = 0x00000000
How can i analyze this issue?
Environment: Xavier, R32.1, Ti954/953 SerDes Camera.
Thinks.
