Hi, All
I’m testing custom image sensor with SerDes.
An error similar to the previous error occurred when connecting only the camera without the serdes system.
- Serial Log message
[ 93.899983] tegra194-vi5 15c10000.vi: no reply from camera processor
[ 93.900144] tegra194-vi5 15c10000.vi: uncorr_err: request timed out after 2500 ms
[ 93.900275] tegra194-vi5 15c10000.vi: err_rec: attempting to reset the capture channel
[ 93.902342] tegra-capture-ivc ivc-bc00000.rtcpu:ivccontrol@3: No callback found for msg id: 0x39
[ 93.902509] tegra-capture-ivc ivc-bc00000.rtcpu:ivccontrol@3: No callback found for msg id: 0x41
[ 93.902655] tegra-capture-ivc ivc-bc00000.rtcpu:ivccontrol@3: No callback found for msg id: 0x37
[ 93.902820] tegra194-vi5 15c10000.vi: err_rec: successfully reset the capture channel
[ 96.459995] tegra194-vi5 15c10000.vi: no reply from camera processor
[ 96.460146] tegra194-vi5 15c10000.vi: uncorr_err: request timed out after 2500 ms
[ 96.460289] tegra194-vi5 15c10000.vi: err_rec: attempting to reset the capture channel
[ 96.462316] tegra194-vi5 15c10000.vi: err_rec: successfully reset the capture channel
[ 99.019902] tegra194-vi5 15c10000.vi: no reply from camera processor
[ 99.020070] tegra194-vi5 15c10000.vi: uncorr_err: request timed out after 2500 ms
[ 99.020219] tegra194-vi5 15c10000.vi: err_rec: attempting to reset the capture channel
[ 99.023358] tegra194-vi5 15c10000.vi: err_rec: successfully reset the capture channel
- Trace Log Message
kworker/0:0-4 [000] .... 98.945757: rtcpu_nvcsi_intr: tstamp:3408266328 class:CORRECTABLE_ERR type:PHY_INTR phy:1 cil:1 st:0 vc:0 status:0x00000600
kworker/0:0-4 [000] .... 98.945757: rtcpu_nvcsi_intr: tstamp:3408272186 class:GLOBAL type:PHY_INTR0 phy:1 cil:0 st:0 vc:0 status:0x0e000000
kworker/0:0-4 [000] .... 98.945758: rtcpu_nvcsi_intr: tstamp:3408272186 class:GLOBAL type:PHY_INTR0 phy:1 cil:1 st:0 vc:0 status:0x06000000
kworker/0:0-4 [000] .... 98.945758: rtcpu_nvcsi_intr: tstamp:3408272186 class:CORRECTABLE_ERR type:PHY_INTR phy:1 cil:0 st:0 vc:0 status:0x00000e00
kworker/0:0-4 [000] .... 98.945758: rtcpu_nvcsi_intr: tstamp:3408272186 class:CORRECTABLE_ERR type:PHY_INTR phy:1 cil:1 st:0 vc:0 status:0x00000600
kworker/0:0-4 [000] .... 98.945759: rtcpu_nvcsi_intr: tstamp:3408830855 class:GLOBAL type:PHY_INTR0 phy:1 cil:0 st:0 vc:0 status:0x0e000000
kworker/0:0-4 [000] .... 98.945759: rtcpu_nvcsi_intr: tstamp:3408830855 class:GLOBAL type:PHY_INTR0 phy:1 cil:1 st:0 vc:0 status:0x06000000
kworker/0:0-4 [000] .... 98.945759: rtcpu_nvcsi_intr: tstamp:3408830855 class:CORRECTABLE_ERR type:PHY_INTR phy:1 cil:0 st:0 vc:0 status:0x00000e00
kworker/0:0-4 [000] .... 98.945760: rtcpu_nvcsi_intr: tstamp:3408830855 class:CORRECTABLE_ERR type:PHY_INTR phy:1 cil:1 st:0 vc:0 status:0x00000600
kworker/0:0-4 [000] .... 98.945760: rtcpu_nvcsi_intr: tstamp:3408836710 class:GLOBAL type:PHY_INTR0 phy:1 cil:0 st:0 vc:0 status:0x0e000000
kworker/0:0-4 [000] .... 98.945760: rtcpu_nvcsi_intr: tstamp:3408836710 class:GLOBAL type:PHY_INTR0 phy:1 cil:1 st:0 vc:0 status:0x06000000
kworker/0:0-4 [000] .... 98.945761: rtcpu_nvcsi_intr: tstamp:3408836710 class:CORRECTABLE_ERR type:PHY_INTR phy:1 cil:0 st:0 vc:0 status:0x00000e00
kworker/0:0-4 [000] .... 98.945761: rtcpu_nvcsi_intr: tstamp:3408836710 class:CORRECTABLE_ERR type:PHY_INTR phy:1 cil:1 st:0 vc:0 status:0x00000600
vi-output, imx4-8572 [000] .... 98.992952: tegra_channel_capture_setup: vnc_id 0 W 3840 H 2160 fmt c4
v4l2-ctl-8570 [001] .... 98.993539: tegra_channel_set_stream: enable : 0x0
v4l2-ctl-8570 [001] .... 98.993546: tegra_channel_set_stream: imx415 2-001a : 0x0
v4l2-ctl-8570 [000] .... 98.995964: tegra_channel_set_stream: 15a00000.nvcsi--1 : 0x0
v4l2-ctl-8570 [000] .... 98.995967: csi_s_stream: enable : 0x0
kworker/0:0-4 [000] .... 99.001720: rtcpu_nvcsi_intr: tstamp:3409395381 class:GLOBAL type:PHY_INTR0 phy:1 cil:0 st:0 vc:0 status:0x0e000000
kworker/0:0-4 [000] .... 99.001721: rtcpu_nvcsi_intr: tstamp:3409395381 class:GLOBAL type:PHY_INTR0 phy:1 cil:1 st:0 vc:0 status:0x06000000
kworker/0:0-4 [000] .... 99.001721: rtcpu_nvcsi_intr: tstamp:3409395381 class:CORRECTABLE_ERR type:PHY_INTR phy:1 cil:0 st:0 vc:0 status:0x00000e00
kworker/0:0-4 [000] .... 99.001722: rtcpu_nvcsi_intr: tstamp:3409395381 class:CORRECTABLE_ERR type:PHY_INTR phy:1 cil:1 st:0 vc:0 status:0x00000600
kworker/0:0-4 [000] .... 99.001722: rtcpu_nvcsi_intr: tstamp:3409401239 class:GLOBAL type:PHY_INTR0 phy:1 cil:0 st:0 vc:0 status:0x0e000000
kworker/0:0-4 [000] .... 99.001722: rtcpu_nvcsi_intr: tstamp:3409401239 class:GLOBAL type:PHY_INTR0 phy:1 cil:1 st:0 vc:0 status:0x06000000
kworker/0:0-4 [000] .... 99.001723: rtcpu_nvcsi_intr: tstamp:3409401239 class:CORRECTABLE_ERR type:PHY_INTR phy:1 cil:0 st:0 vc:0 status:0x00000e00
kworker/0:0-4 [000] .... 99.001723: rtcpu_nvcsi_intr: tstamp:3409401239 class:CORRECTABLE_ERR type:PHY_INTR phy:1 cil:1 st:0 vc:0 status:0x00000600
kworker/0:0-4 [000] .... 99.001723: rtcpu_nvcsi_intr: tstamp:3409959903 class:GLOBAL type:PHY_INTR0 phy:1 cil:0 st:0 vc:0 status:0x0e000000
kworker/0:0-4 [000] .... 99.001724: rtcpu_nvcsi_intr: tstamp:3409959903 class:GLOBAL type:PHY_INTR0 phy:1 cil:1 st:0 vc:0 status:0x06000000
kworker/0:0-4 [000] .... 99.001724: rtcpu_nvcsi_intr: tstamp:3409959903 class:CORRECTABLE_ERR type:PHY_INTR phy:1 cil:0 st:0 vc:0 status:0x00000e00
kworker/0:0-4 [000] .... 99.001724: rtcpu_nvcsi_intr: tstamp:3409959903 class:CORRECTABLE_ERR type:PHY_INTR phy:1 cil:1 st:0 vc:0 status:0x00000600
kworker/0:0-4 [000] .... 99.001725: rtcpu_nvcsi_intr: tstamp:3409965763 class:GLOBAL type:PHY_INTR0 phy:1 cil:0 st:0 vc:0 status:0x0e000000
kworker/0:0-4 [000] .... 99.001725: rtcpu_nvcsi_intr: tstamp:3409965763 class:GLOBAL type:PHY_INTR0 phy:1 cil:1 st:0 vc:0 status:0x06000000
kworker/0:0-4 [000] .... 99.001725: rtcpu_nvcsi_intr: tstamp:3409965763 class:CORRECTABLE_ERR type:PHY_INTR phy:1 cil:0 st:0 vc:0 status:0x00000e00
kworker/0:0-4 [000] .... 99.001726: rtcpu_nvcsi_intr: tstamp:3409965763 class:CORRECTABLE_ERR type:PHY_INTR phy:1 cil:1 st:0 vc:0 status:0x00000600
kworker/0:0-4 [000] .... 99.001730: rtos_queue_send_from_isr_failed: tstamp:3410413644 queue:0x0bcb41f8
kworker/0:0-4 [000] .... 99.001774: rtos_queue_send_from_isr_failed: tstamp:3410413809 queue:0x0bcb8a60
kworker/0:0-4 [000] .... 99.001775: rtos_queue_send_from_isr_failed: tstamp:3410413971 queue:0x0bcba5e0
kworker/0:0-4 [000] .... 99.001776: rtos_queue_send_from_isr_failed: tstamp:3410414128 queue:0x0bcbb3a0
kworker/0:0-4 [000] .... 99.001777: rtos_queue_send_from_isr_failed: tstamp:3410414285 queue:0x0bcbc160
kworker/0:0-4 [000] .... 99.001778: rtos_queue_send_from_isr_failed: tstamp:3410495785 queue:0x0bcb41f8
kworker/0:0-4 [000] .... 99.001779: rtos_queue_send_from_isr_failed: tstamp:3410495947 queue:0x0bcb8a60
kworker/0:0-4 [000] .... 99.001780: rtos_queue_send_from_isr_failed: tstamp:3410496108 queue:0x0bcba5e0
kworker/0:0-4 [000] .... 99.001780: rtos_queue_send_from_isr_failed: tstamp:3410496265 queue:0x0bcbb3a0
kworker/0:0-4 [000] .... 99.001781: rtos_queue_send_from_isr_failed: tstamp:3410496420 queue:0x0bcbc160
kworker/0:0-4 [000] .... 99.001782: rtcpu_nvcsi_intr: tstamp:3410503373 class:GLOBAL type:PHY_INTR0 phy:1 cil:0 st:0 vc:0 status:0x00000110
kworker/0:0-4 [000] .... 99.001782: rtcpu_nvcsi_intr: tstamp:3410503373 class:GLOBAL type:PHY_INTR0 phy:1 cil:1 st:0 vc:0 status:0x00000110
kworker/0:0-4 [000] .... 99.001783: rtcpu_nvcsi_intr: tstamp:3410503373 class:CORRECTABLE_ERR type:PHY_INTR phy:1 cil:0 st:0 vc:0 status:0x00000110
kworker/0:0-4 [000] .... 99.001783: rtcpu_nvcsi_intr: tstamp:3410503373 class:CORRECTABLE_ERR type:PHY_INTR phy:1 cil:1 st:0 vc:0 status:0x00000110
kworker/0:0-4 [000] .... 99.001787: rtcpu_string: tstamp:3410504871 id:0x04010000 str:"Configuring VI GoS.
kworker/0:0-4 [000] .... 99.001811: rtcpu_string: tstamp:3410505062 id:0x04010000 str:"VM GOS[#0] addr=0xc2100000
kworker/0:0-4 [000] .... 99.001818: rtcpu_string: tstamp:3410505329 id:0x04010000 str:"VM GOS[#1] addr=0xc2101000
kworker/0:0-4 [000] .... 99.001824: rtcpu_string: tstamp:3410505624 id:0x04010000 str:"VM GOS[#2] addr=0xc2102000
kworker/0:0-4 [000] .... 99.001830: rtcpu_string: tstamp:3410505867 id:0x04010000 str:"VM GOS[#3] addr=0xc2103000
kworker/0:0-4 [000] .... 99.001837: rtcpu_string: tstamp:3410506109 id:0x04010000 str:"VM GOS[#4] addr=0xc2104000
kworker/0:0-4 [000] .... 99.001871: rtcpu_string: tstamp:3410506350 id:0x04010000 str:"VM GOS[#5] addr=0xc2105000
kworker/0:0-4 [000] .... 99.001876: rtcpu_nvcsi_intr: tstamp:3410524430 class:GLOBAL type:PHY_INTR0 phy:1 cil:0 st:0 vc:0 status:0x0e000000
kworker/0:0-4 [000] .... 99.001876: rtcpu_nvcsi_intr: tstamp:3410524430 class:GLOBAL type:PHY_INTR0 phy:1 cil:1 st:0 vc:0 status:0x06000000
kworker/0:0-4 [000] .... 99.001877: rtcpu_nvcsi_intr: tstamp:3410524430 class:CORRECTABLE_ERR type:PHY_INTR phy:1 cil:0 st:0 vc:0 status:0x00000e00
kworker/0:0-4 [000] .... 99.001877: rtcpu_nvcsi_intr: tstamp:3410524430 class:CORRECTABLE_ERR type:PHY_INTR phy:1 cil:1 st:0 vc:0 status:0x00000600
kworker/0:0-4 [000] .... 99.001878: rtos_queue_send_from_isr_failed: tstamp:3410592316 queue:0x0bcb41f8
kworker/0:0-4 [000] .... 99.001879: rtos_queue_send_from_isr_failed: tstamp:3410592480 queue:0x0bcb8a60
kworker/0:0-4 [000] .... 99.001880: rtos_queue_send_from_isr_failed: tstamp:3410592641 queue:0x0bcba5e0
kworker/0:0-4 [000] .... 99.001881: rtos_queue_send_from_isr_failed: tstamp:3410592800 queue:0x0bcbb3a0
kworker/0:0-4 [000] .... 99.001882: rtos_queue_send_from_isr_failed: tstamp:3410592957 queue:0x0bcbc160
kworker/0:0-4 [000] .... 99.001882: rtos_queue_send_from_isr_failed: tstamp:3410768753 queue:0x0bcb41f8
kworker/0:0-4 [000] .... 99.001883: rtos_queue_send_from_isr_failed: tstamp:3410768980 queue:0x0bcb8a60
kworker/0:0-4 [000] .... 99.001884: rtos_queue_send_from_isr_failed: tstamp:3410769203 queue:0x0bcba5e0
kworker/0:0-4 [000] .... 99.001884: rtos_queue_send_from_isr_failed: tstamp:3410769422 queue:0x0bcbb3a0
kworker/0:0-4 [000] .... 99.001885: rtos_queue_send_from_isr_failed: tstamp:3410769640 queue:0x0bcbc160
v4l2-ctl-8570 [003] .... 99.012673: tegra_channel_set_power: imx415 2-001a : 0x0
v4l2-ctl-8570 [003] .... 99.012702: camera_common_s_power: status : 0x0
v4l2-ctl-8570 [001] .... 99.022085: tegra_channel_set_power: 15a00000.nvcsi--1 : 0x0
v4l2-ctl-8570 [001] .... 99.022094: csi_s_power: enable : 0x0
kworker/0:0-4 [000] .... 99.057728: rtos_queue_peek_from_isr_failed: tstamp:3412311905 queue:0x0bcbcf78
kworker/0:0-4 [000] .... 99.225738: rtos_queue_peek_from_isr_failed: tstamp:3417311907 queue:0x0bcbcf78
kworker/0:0-4 [000] .... 99.393644: rtos_queue_peek_from_isr_failed: tstamp:3422311905 queue:0x0bcbcf78
kworker/0:0-4 [000] .... 99.561671: rtos_queue_peek_from_isr_failed: tstamp:3427311905 queue:0x0bcbcf78
kworker/0:0-4 [000] .... 99.729708: rtos_queue_peek_from_isr_failed: tstamp:3432311950 queue:0x0bcbcf78
kworker/0:0-4 [000] .... 99.897643: rtos_queue_peek_from_isr_failed: tstamp:3437311909 queue:0x0bcbcf78
kworker/0:0-4 [000] .... 100.065611: rtos_queue_peek_from_isr_failed: tstamp:3442311911 queue:0x0bcbcf78
I think it’s a timing problem, but I don’t know where to start.
thanks,
