I’m currently working with Jetson AGX Xavier module with a camera which connects to an FPGA and goes through a GMSL serializer and deserializer. Here, we are attempting to test FPGA → Serializer → Deserializer → Xavier connection. FPGA is generating the test pattern at 1928x1208.
I am able to capture a YUV422 8-bit image, which is what the FPGA is sending over to the serializer. However, we have noticed that the image that is being captured using:
yavta -n 3 -c1 -f UYVY -s 1928x1208 -Ftest.yuv /dev/video0
does not contain the correct data sequence.
In this test image, we are sending UYVY packed with
U - 0, Y - 0, V - 0, Y_next - 0. Containing same data for 4 bytes which represent two pixels. Here is the screenshot with pixel data from the start of the image.
This was viewed using GitHub - IENT/YUView: The Free and Open Source Cross Platform YUV Viewer with an advanced analytics toolset with resolution set to 1928x1208 - which is the resolution FPGA is sending the test pattern. Interesting thing is that at the end of the image we are getting the following:
This is unexpected, as in our test pattern we are NOT resetting the count from 191 → 0, but rather it should go to 191->195 until the end of the line. 0 shall start from the next time. To summarize,
16 bytes of data from the line is missing, and is replaced by 16 bytes of data from the next line.
Another interesting thing that we observe is:
On line 4 we see that we count till 195 (which is what it should be), however we see that we are observing zeros on the data that is seemingly replaced in the previous row.
To summarize,
- We are missing 32 bytes of data from Line 1, 2 and 3.
- This appears at the end of line 4 where remaining pixels are set to zero.
- We are somehow seeing the full data in Line 4.
Question/Query:
How can one go about debugging this from Xavier perspective (yes we are actively trying to debug this from FPGA, serializer, deserializer)? What device tree settings shall we look? What kernel parameters shall be look at?
Thanks in advance!
