TLDR: yes, but with some efforts.
There is a long thread talking about options in this forum: Has anyone tried an alternative Linux distro?
You can also find some semi-official (preview) support, like this one: Building a custom Red Hat Enterprise Linux kernel for NVIDIA DGX Spark. Of course, since DGX OS is based on Ubuntu, you can use Ubuntu as well.
Theoretically, you can choose whatever Linux distro you’d like (or even Windows, if Nvidia doesn’t gatekeep the WoA for RTX Spark). It comes with several caveats, though:
- No matter which distro you choose, it’s better to use the Nvidia-maintained kernels, meaning that you need to compile kernels yourself (or rely on others to do it for you).
- Since you will be using a custom kernel, when trying to install the Nvidia driver, you are highly unlikely to be able to depend on your distro’s package maintainer.
- Some distros ship newer toolchains as their default, which may make the CUDA stack unhappy. This usually is not a big problem if your distro provides older toolchains for compatibility, which most do.
I’m currently running Fedora 44 on both of my GX10:
$ fastfetch
.',;::::;,'. hiroshiya@GX10-00
.';:cccccccccccc:;,. -----------------
.;cccccccccccccccccccccc;. OS: Fedora Linux 44 (Forty Four) aarch64
.:cccccccccccccccccccccccccc:. Host: GX10 (5.36_GX10DGX)
.;ccccccccccccc;.:dddl:.;ccccccc;. Kernel: Linux 7.0.12-nv-1016.16
.:ccccccccccccc;OWMKOOXMWd;ccccccc:. Uptime: 2 days, 1 hour, 45 mins
.:ccccccccccccc;KMMc;cc;xMMc;ccccccc:. Packages: 1315 (rpm)
,cccccccccccccc;MMM.;cc;;WW:;cccccccc, Shell: bash 5.3.9
:cccccccccccccc;MMM.;cccccccccccccccc: Display: 2560x1440 in 27", 144 Hz [External]
:ccccccc;oxOOOo;MMM000k.;cccccccccccc: Terminal: /dev/pts/0 10.2p1
cccccc;0MMKxdd:;MMMkddc.;cccccccccccc; CPU: Cortex-A725+Cortex-X925+Cortex-A725+Cortex-X925 (10+10) @ 3.90 GHz
ccccc;XMO';cccc;MMM.;cccccccccccccccc' GPU: NVIDIA GB10
ccccc;MMo;ccccc;MMW.;ccccccccccccccc; Memory: 3.90 GiB / 121.63 GiB (3%)
ccccc;0MNc.ccc.xMMd;ccccccccccccccc; Swap: 0 B / 24.00 GiB (0%)
cccccc;dNMWXXXWM0:;cccccccccccccc:, Disk (/): 85.88 GiB / 930.51 GiB (9%) - btrfs
cccccccc;.:odl:.;cccccccccccccc:,. Locale: en_US.UTF-8
ccccccccccccccccccccccccccccc:'.
:ccccccccccccccccccccccc:;,..
':cccccccccccccccc::;,.
$ nvidia-smi
| NVIDIA-SMI 595.84 Driver Version: 595.84 CUDA Version: 13.2 |
| GPU Name Persistence-M | Bus-Id Disp.A | Volatile Uncorr. ECC |
| | | MIG M. |
| 0 NVIDIA GB10 On | 0000000F:01:00.0 On | N/A |
| N/A 43C P8 3W / N/A | Not Supported | 0% Default |
| | | N/A |
| Processes: |
| ID ID Usage |
| No running processes found |
It actually took me quite a few days to get the system working properly, because I have never compiled a Linux kernel before. Besides, I had to use the Runfiles to install both the driver and the CUDA stack. Nonetheless, I learned a lot during the process, and I was able to get NCCL working properly - even submitted a small patch for nccl-tests to make it seamlessly compile on Fedora.
Speaking of the driver, you can just download it from the official website. GB10 is not listed there, but it doesn’t really matter - the driver is basically universal. Just choose a same-generation product (e.g. “RTX Pro 6000”), and make sure to select “Linux aarch64” as the architecture.
If you want to be 100% sure about compatibility, you can also click “View” to go to the detail page of the driver, click the “Additional Information” tab, find the “README”, and find the “Supported NVIDIA GPU Products” section to confirm the compatibility. Here is an example from the 595.91.07 driver, where you can see GB10 is listed.
You will also need to manually install CUDA as well. Here is the guide for that. You will likely need to perform the “Runfile Installation” for CUDA as well.
