Understanding DGX Spark Operating System
I am using LLM agent scripting with the ollama python library. I do not understand the operating system that will be available on this new system. Will it be able to run everything that runs in Linux? Is there a restricted subset of programs, and if so, what sort of neural network programming environments will be available or usable? Are we stuck with a specific development stack, or do we have a wide variety of choices?
This looks like it’ll be running the Jetson series of Linux, so anything you could run on a Jetson AGX Orin, you should be able to run on the DGX Spark, except more of it and faster.
Given ARM CPU, you should be able to run Linux with ARM64 version.
And as @snarky says, Jetson drivers should work but you need to be careful with CUDA version since GB10 will be SM_120
DGX OS is only a specialized version of Ubuntu. Nothing more.
