Dear all:
1: Jetson nano software version: R32.4.3
2: In our custom board, Both ethernet and 4G connected to PCIE0, as following pcitures:
ethernet is connected to pcie0, at the same time 4G connected to pcie0;
3.1: when Image without 4G driver(just add some files), eth1 can work normally;
3.2: when Image with 4G driver(just add some files), eth1 was disappeared even if the 4G module is not yet plugged into the device.
4: Just one pcie controller pcie@1003000 for eth0, eth1 and 4G is exist.
But, eth1 related to pci@2.0 which exist in jetson nano modules.
- Finally: Are both ethernet and 4G connected to PCIE0 allowed?
If not allowed, eth1 can not work which build-in jetson nano modules, supposedly, the network port on the custom board is not working.
If allowed, here are some more suggestions for me?
Thank you for your kind help! Thank your very much.
