Hi everyone,
Can’i design pcie for Jetson nano as below:
how dose me modified dts and kernel?
Which device cannot work now?
The configuration is same as devkit so nothing needs to be modified.
Why do you connect PCIE1_TX/RX/CLK here? This is for ethernet on nano module and cannot be used.
Are you sure you follow the jetson nano design guide?
ok, i got it.
if i don’t need ethernet, can’i use pcie1? Just disable ethernet in dts?
Is Jetson Xavier NX have RJ45、Pcie 2 port(pcie0 x4,pcie1 x1)?
That cannot work. we don’t have pinout from module for pcie1.
As for the NX, please refer to the NX design guide.
Hi Wayne,
I have a question,pcie1 is used for ethernet on nano module, and i can’t use it, why draw it out on schematic diagram?
Which file are you referring to?
