I am using an Nvidia Jetson AGX Orin, I will be receiving CAN messages on Orin how can I extract data from CAN messgaes. Is there a specific way to extract CAN data. I am following this link CAN documentation
Are there any functions/modules to set the bus parameters/ configure can send and receive select ID’s to filter out specific messages.
I want to write this code in CPP.
I am using the Jetson AGX Orin Developer Kit (64GB)
Jetpack version is: Package: nvidia-jetpack Version: 5.1.2-b104
For example when I use kvaser device they have Canlib API’s which can be used in code, functions such as can_send(), can_receive(), caninitialize().
So is there anything similar which can be done with Orin to send/receive can data.
Suppose I am receiving 10 messages on a CAN bus, and I want speed data being sent on message 0x45. I would like to read message 0x45 specifically, do some calculation and then send it forward to another CAN bus.
Yes but I won’t be able to use those commands in a cpp code. When I run my cpp code and I want to send the data over CAN their must be some libraries/API which I can use for CAN send through code itself
Yes as an example if I want to receive the CAN packet with ID=0x45 how will I do that
