I connect a USB camera to jetson xavier nx and generate RGB mat from 8-bit bayer(RG) as below.
cv::VideoCapture cap = cv::VideoCapture(“v4l2src device=/dev/video0 !
video/x-bayer,format=rggb,width=1440,height=1080,framerate=2500000/10593
! bayer2rgb ! videoconvert ! appsink”);
Camera
Question
・Does this code use Jetson’s ISP to convert to RGB?
・Is there a way to get RGB mat from 8-bit bayer(RG) using nvarguscamerasrc?
nvarguscamerasrc only support bayer sensor types.
please also refer to Camera Architecture Stack, you can only enable v4l2src to access USB camera streams.
however, you may refer to [Multimedia API Sample Applications].
there’s sample, 12_camera_v4l2_cuda, which demonstrates image capture and share the image stream with CUDA engines.
thanks
