Can I do this using CUDA?
Hi
I’m new to this forum. I have to develop a system that recognizes some objects and gestures.
I did a lot of reading in this forum but could not find information about this.
Is CUDA suitable for this? Is it a good choice for this kind of application?
If so, can anybody point me to the wright direction?
Or help me with getting the big picture, so that I can study the details?
For instance:
How do I get the video from a camera into the graphics card (preferable fireWire camera).
What tools do I need to develop a object/gesture recognition application?
Are there any examples for such an application?
Any help is very welcome!
Hi!
CUDA is well suited for image processing (because its parallel nature), so it’s a good idea looking around here too. But CUDA is essentially just a way for making things run faster, in exchange for a little more programming work. (Yes, it’s usually more complicated to do something on the GPU than it would be on one CPU core.)
I think what you eventually want can be best described as a form of computer vision. There are nice libraries for that, OpenCV is one of the more known ones, and some books too (the O’Reilly “Learning OpenCV” for example, but, as usually, Google is your friend.) There are a lot of unsolved problems in the field though, depends on what objects you want to recognize. (You certainly can recognize a big white square on a black background, telling a cat and a dog apart is more like the “still unsolved” category.)
And when you’ve got something that works but awfully slowly… that’s the point where CUDA helps. But only if you can divide your computation to hundreds of small parts which can be done separately… let’s say operating on 32x32 pixel image snippets, or things like that.
(By the way, OpenCV has got nice tools to grab video from cameras, if you can get your camera working in say… Skype, it will be able to use it too.)
I hope this helped a bit :)
Yes this helps a lot. Thanks.
I started looking at OpenCV
Is there something like OpenCV accelaration using CUDA?
That would be great.
