Can I use Jetson Xavier Nx instead of -> 4 NVIDIA V100 GPUs (32G) with batch size 64
Can I use Jetson Xavier Nx instead of → 4 NVIDIA V100 GPUs (32G) with batch size 64.
Will the Jetson Xavier nx successfully works in place of the 4 NVIDIA V100 GPUs (32G) with batch size 64…
Is there any performance issue?
please do answer me as soon as possible.
I will be very thankful to you.
This depends on your use case.
If your task is training-related, please use V100 since Jetson is mainly designed for inference.
Rather than GPU power, it’s recommended to take memory/bandwidth/encoder… into account.
You can find the detailed specs of Xavier NX below.
