Can NOT install scipy via pip in virtualenv
When I try to install scipy in virtualenv:
pip install scipy
I meet this error (Before that, I have installed numpy in virtualenv via pip):
ERROR: Complete output from command /mnt/Datas_nvidia/.virtualenvs/startedNANO/bin/python3 /mnt/Datas_nvidia/.virtualenvs/startedNANO/lib/python3.6/site-packages/pip install --ignore-installed --no-user --prefix /tmp/pip-build-env-zwjrzhop/overlay --no-warn-script-location --no-binary :none: --only-binary :none: -i https://pypi.org/simple -- wheel setuptools 'Cython>=0.29.2' 'numpy==1.13.3; python_version=='"'"'3.5'"'"'' 'numpy==1.13.3; python_version=='"'"'3.6'"'"'' 'numpy==1.14.5; python_version>='"'"'3.7'"'"'':
  ERROR: Ignoring numpy: markers 'python_version == "3.5"' don't match your environment
  Ignoring numpy: markers 'python_version >= "3.7"' don't match your environment
  Collecting wheel
    Using cached https://files.pythonhosted.org/packages/bb/10/44230dd6bf3563b8f227dbf344c908d412ad2ff48066476672f3a72e174e/wheel-0.33.4-py2.py3-none-any.whl
  Collecting setuptools
    Using cached https://files.pythonhosted.org/packages/ec/51/f45cea425fd5cb0b0380f5b0f048ebc1da5b417e48d304838c02d6288a1e/setuptools-41.0.1-py2.py3-none-any.whl
  Collecting Cython>=0.29.2
  Collecting numpy==1.13.3
    Using cached https://files.pythonhosted.org/packages/bf/2d/005e45738ab07a26e621c9c12dc97381f372e06678adf7dc3356a69b5960/numpy-1.13.3.zip
  Building wheels for collected packages: numpy
    Building wheel for numpy (setup.py): started
    Building wheel for numpy (setup.py): still running...
    Building wheel for numpy (setup.py): finished with status 'error'
    ERROR: Complete output from command /mnt/Datas_nvidia/.virtualenvs/startedNANO/bin/python3 -u -c 'import setuptools, tokenize;__file__='"'"'/tmp/pip-install-pcwy4f04/numpy/setup.py'"'"';f=getattr(tokenize, '"'"'open'"'"', open)(__file__);code=f.read().replace('"'"'\r\n'"'"', '"'"'\n'"'"');f.close();exec(compile(code, __file__, '"'"'exec'"'"'))' bdist_wheel -d /tmp/pip-wheel-1lbv9xud --python-tag cp36:
    ERROR: Running from numpy source directory.
    blas_opt_info:
    blas_mkl_info:
      libraries mkl_rt not found in ['/mnt/Datas_nvidia/.virtualenvs/startedNANO/lib', '/usr/local/lib', '/usr/lib', '/usr/lib/aarch64-linux-gnu']
      NOT AVAILABLE
    blis_info:
      libraries blis not found in ['/mnt/Datas_nvidia/.virtualenvs/startedNANO/lib', '/usr/local/lib', '/usr/lib', '/usr/lib/aarch64-linux-gnu']
      NOT AVAILABLE
    openblas_info:
      libraries openblas not found in ['/mnt/Datas_nvidia/.virtualenvs/startedNANO/lib', '/usr/local/lib', '/usr/lib', '/usr/lib/aarch64-linux-gnu']
      NOT AVAILABLE
    atlas_3_10_blas_threads_info:
    Setting PTATLAS=ATLAS
      libraries tatlas not found in ['/mnt/Datas_nvidia/.virtualenvs/startedNANO/lib', '/usr/local/lib', '/usr/lib', '/usr/lib/aarch64-linux-gnu/atlas', '/usr/lib/aarch64-linux-gnu']
      NOT AVAILABLE
    atlas_3_10_blas_info:
      libraries satlas not found in ['/mnt/Datas_nvidia/.virtualenvs/startedNANO/lib', '/usr/local/lib', '/usr/lib', '/usr/lib/aarch64-linux-gnu/atlas', '/usr/lib/aarch64-linux-gnu']
      NOT AVAILABLE
    atlas_blas_threads_info:
      libraries ptf77blas,ptcblas,atlas not found in ['/mnt/Datas_nvidia/.virtualenvs/startedNANO/lib', '/usr/local/lib', '/usr/lib', '/usr/lib/aarch64-linux-gnu/atlas', '/usr/lib/aarch64-linux-gnu']
      NOT AVAILABLE
    atlas_blas_info:
    customize Gnu95FCompiler
    Found executable /usr/bin/gfortran
    customize Gnu95FCompiler using config
    compiling '_configtest.c':
    /* This file is generated from numpy/distutils/system_info.py */
    void ATL_buildinfo(void);
    int main(void) {
      ATL_buildinfo();
      return 0;
    C compiler: aarch64-linux-gnu-gcc -pthread -DNDEBUG -g -fwrapv -O2 -Wall -g -fstack-protector-strong -Wformat -Werror=format-security -Wdate-time -D_FORTIFY_SOURCE=2 -fPIC
    compile options: '-c'
    aarch64-linux-gnu-gcc: _configtest.c
    aarch64-linux-gnu-gcc -pthread _configtest.o -lf77blas -lcblas -latlas -o _configtest
    ATLAS version 3.10.3 built by buildd on Tue Sep 19 12:24:37 UTC 2017:
       UNAME    : Linux bos01-arm64-010 4.4.0-96-generic #119-Ubuntu SMP Tue Sep 12 15:00:28 UTC 2017 aarch64 aarch64 aarch64 GNU/Linux
       INSTFLG  : -1 0 -a 1 -l 1
       ARCHDEFS : -DATL_OS_Linux -DATL_ARCH_GENERIC -DATL_USE64BITS -DATL_GAS_ARM64
       F2CDEFS  : -DAdd_ -DF77_INTEGER=int -DStringSunStyle
       CACHEEDGE: 2097152
       F77      : /usr/bin/gfortran, version GNU Fortran (Ubuntu/Linaro 7.2.0-5ubuntu1) 7.2.0
       F77FLAGS : -g -O2 -fdebug-prefix-map=/build/atlas-_lkXfd/atlas-3.10.3=. -fstack-protector-strong -fPIC
       SMC      : /usr/bin/gcc, version gcc (Ubuntu/Linaro 7.2.0-5ubuntu1) 7.2.0
       SMCFLAGS : -Wdate-time -D_FORTIFY_SOURCE=2 -g -O2 -fdebug-prefix-map=/build/atlas-_lkXfd/atlas-3.10.3=. -fstack-protector-strong -fPIC
       SKC      : /usr/bin/gcc, version gcc (Ubuntu/Linaro 7.2.0-5ubuntu1) 7.2.0
       SKCFLAGS : -Wdate-time -D_FORTIFY_SOURCE=2 -g -O2 -fdebug-prefix-map=/build/atlas-_lkXfd/atlas-3.10.3=. -fstack-protector-strong -fPIC
    success!
    removing: _configtest.c _configtest.o _configtest
      FOUND:
        language = c
        define_macros = [('HAVE_CBLAS', None), ('ATLAS_INFO', '"\"3.10.3\""')]
        libraries = ['f77blas', 'cblas', 'atlas', 'f77blas', 'cblas']
        library_dirs = ['/usr/lib/aarch64-linux-gnu']
      FOUND:
        language = c
    /bin/sh: 1: svnversion: not found
    non-existing path in 'numpy/distutils': 'site.cfg'
    F2PY Version 2
    lapack_opt_info:
    lapack_mkl_info:
      NOT AVAILABLE
    openblas_lapack_info:
      NOT AVAILABLE
    atlas_3_10_threads_info:
      libraries tatlas,tatlas not found in /mnt/Datas_nvidia/.virtualenvs/startedNANO/lib
      libraries lapack_atlas not found in /mnt/Datas_nvidia/.virtualenvs/startedNANO/lib
      libraries tatlas,tatlas not found in /usr/local/lib
      libraries lapack_atlas not found in /usr/local/lib
      libraries tatlas,tatlas not found in /usr/lib
      libraries lapack_atlas not found in /usr/lib
      libraries tatlas,tatlas not found in /usr/lib/aarch64-linux-gnu/atlas
      libraries lapack_atlas not found in /usr/lib/aarch64-linux-gnu/atlas
    <class 'numpy.distutils.system_info.atlas_3_10_threads_info'>
      NOT AVAILABLE
    atlas_3_10_info:
      libraries satlas,satlas not found in /mnt/Datas_nvidia/.virtualenvs/startedNANO/lib
      libraries satlas,satlas not found in /usr/local/lib
      libraries satlas,satlas not found in /usr/lib
      libraries satlas,satlas not found in /usr/lib/aarch64-linux-gnu/atlas
    <class 'numpy.distutils.system_info.atlas_3_10_info'>
      NOT AVAILABLE
    atlas_threads_info:
      libraries ptf77blas,ptcblas,atlas not found in /mnt/Datas_nvidia/.virtualenvs/startedNANO/lib
      libraries ptf77blas,ptcblas,atlas not found in /usr/local/lib
      libraries ptf77blas,ptcblas,atlas not found in /usr/lib
      libraries ptf77blas,ptcblas,atlas not found in /usr/lib/aarch64-linux-gnu/atlas
    <class 'numpy.distutils.system_info.atlas_threads_info'>
      NOT AVAILABLE
    atlas_info:
      libraries f77blas,cblas,atlas not found in /mnt/Datas_nvidia/.virtualenvs/startedNANO/lib
      libraries f77blas,cblas,atlas not found in /usr/local/lib
      libraries f77blas,cblas,atlas not found in /usr/lib
      libraries f77blas,cblas,atlas not found in /usr/lib/aarch64-linux-gnu/atlas
    <class 'numpy.distutils.system_info.atlas_info'>
      FOUND:
        language = f77
        libraries = ['lapack', 'f77blas', 'cblas', 'atlas', 'f77blas', 'cblas']
        define_macros = [('ATLAS_INFO', '"\"3.10.3\""')]
      FOUND:
        language = f77
    /usr/lib/python3.6/distutils/dist.py:261: UserWarning: Unknown distribution option: 'define_macros'
      warnings.warn(msg)
    running bdist_wheel
    running build
    running config_cc
    unifing config_cc, config, build_clib, build_ext, build commands --compiler options
    running config_fc
    unifing config_fc, config, build_clib, build_ext, build commands --fcompiler options
    running build_src
    build_src
    building py_modules sources
    creating build
    creating build/src.linux-aarch64-3.6
    creating build/src.linux-aarch64-3.6/numpy
    creating build/src.linux-aarch64-3.6/numpy/distutils
    building library "npymath" sources
    compile options: '-Inumpy/core/src/private -Inumpy/core/src -Inumpy/core -Inumpy/core/src/npymath -Inumpy/core/src/multiarray -Inumpy/core/src/umath -Inumpy/core/src/npysort -I/usr/include/python3.6m -I/mnt/Datas_nvidia/.virtualenvs/startedNANO/include/python3.6m -c'
    aarch64-linux-gnu-gcc -pthread _configtest.o -o _configtest
    success!
    _configtest.c:1:5: warning: conflicting types for built-in function ‘exp’ [-Wbuiltin-declaration-mismatch]
     int exp (void);
    _configtest.o: In function `main':
    /tmp/pip-install-pcwy4f04/numpy/_configtest.c:6: undefined reference to `exp'
    collect2: error: ld returned 1 exit status
    failure.
     int exp (void);
    aarch64-linux-gnu-gcc -pthread _configtest.o -lm -o _configtest
    success!
    creating build/src.linux-aarch64-3.6/numpy/core
    creating build/src.linux-aarch64-3.6/numpy/core/src
    creating build/src.linux-aarch64-3.6/numpy/core/src/npymath
    conv_template:> build/src.linux-aarch64-3.6/numpy/core/src/npymath/npy_math_internal.h
      adding 'build/src.linux-aarch64-3.6/numpy/core/src/npymath' to include_dirs.
    conv_template:> build/src.linux-aarch64-3.6/numpy/core/src/npymath/ieee754.c
    conv_template:> build/src.linux-aarch64-3.6/numpy/core/src/npymath/npy_math_complex.c
    None - nothing done with h_files = ['build/src.linux-aarch64-3.6/numpy/core/src/npymath/npy_math_internal.h']
    building library "npysort" sources
    creating build/src.linux-aarch64-3.6/numpy/core/src/npysort
    conv_template:> build/src.linux-aarch64-3.6/numpy/core/src/npysort/quicksort.c
    conv_template:> build/src.linux-aarch64-3.6/numpy/core/src/npysort/mergesort.c
    conv_template:> build/src.linux-aarch64-3.6/numpy/core/src/npysort/heapsort.c
    creating build/src.linux-aarch64-3.6/numpy/core/src/private
    conv_template:> build/src.linux-aarch64-3.6/numpy/core/src/private/npy_partition.h
      adding 'build/src.linux-aarch64-3.6/numpy/core/src/private' to include_dirs.
    conv_template:> build/src.linux-aarch64-3.6/numpy/core/src/npysort/selection.c
    conv_template:> build/src.linux-aarch64-3.6/numpy/core/src/private/npy_binsearch.h
    conv_template:> build/src.linux-aarch64-3.6/numpy/core/src/npysort/binsearch.c
    None - nothing done with h_files = ['build/src.linux-aarch64-3.6/numpy/core/src/private/npy_partition.h', 'build/src.linux-aarch64-3.6/numpy/core/src/private/npy_binsearch.h']
    building extension "numpy.core._dummy" sources
    Generating build/src.linux-aarch64-3.6/numpy/core/include/numpy/config.h
    success!
    success!
    _configtest.c:1:10: fatal error: sys/endian.h: No such file or directory
     #include <sys/endian.h>
    compilation terminated.
    failure.
    success!
    success!
    success!
    success!
    _configtest.c: In function ‘main’:
    _configtest.c:5:16: warning: variable ‘test_array’ set but not used [-Wunused-but-set-variable]
         static int test_array [1 - 2 * !(((long) (sizeof (npy_check_sizeof_type))) >= 0)];
         static int test_array [1 - 2 * !(((long) (sizeof (npy_check_sizeof_type))) == 4)];
         static int test_array [1 - 2 * !(((long) (sizeof (npy_check_sizeof_type))) == 8)];
    success!
         static int test_array [1 - 2 * !(((long) (sizeof (npy_check_sizeof_type))) == 16)];
    _configtest.c:7:12: error: ‘SIZEOF_LONGDOUBLE’ undeclared (first use in this function); did you mean ‘SIZEOF_LONG_DOUBLE’?
         (void) SIZEOF_LONGDOUBLE;
                SIZEOF_LONG_DOUBLE
    _configtest.c:7:12: note: each undeclared identifier is reported only once for each function it appears in
                SIZEOF_LONG_DOUBLE
    failure.
         static int test_array [1 - 2 * !(((long) (sizeof (npy_check_sizeof_type))) == 32)];
    _configtest.c:7:16: warning: variable ‘test_array’ set but not used [-Wunused-but-set-variable]
    success!
    success!
     int exp (void);
    failure.
     int exp (void);
    success!
    _configtest.c:1:5: warning: conflicting types for built-in function ‘sin’ [-Wbuiltin-declaration-mismatch]
     int sin (void);
    _configtest.c:2:5: warning: conflicting types for built-in function ‘cos’ [-Wbuiltin-declaration-mismatch]
     int cos (void);
    _configtest.c:3:5: warning: conflicting types for built-in function ‘tan’ [-Wbuiltin-declaration-mismatch]
     int tan (void);
    _configtest.c:4:5: warning: conflicting types for built-in function ‘sinh’ [-Wbuiltin-declaration-mismatch]
     int sinh (void);
    _configtest.c:5:5: warning: conflicting types for built-in function ‘cosh’ [-Wbuiltin-declaration-mismatch]
     int cosh (void);
    _configtest.c:6:5: warning: conflicting types for built-in function ‘tanh’ [-Wbuiltin-declaration-mismatch]
     int tanh (void);
    _configtest.c:7:5: warning: conflicting types for built-in function ‘fabs’ [-Wbuiltin-declaration-mismatch]
     int fabs (void);
    _configtest.c:8:5: warning: conflicting types for built-in function ‘floor’ [-Wbuiltin-declaration-mismatch]
     int floor (void);
    _configtest.c:9:5: warning: conflicting types for built-in function ‘ceil’ [-Wbuiltin-declaration-mismatch]
     int ceil (void);
    _configtest.c:10:5: warning: conflicting types for built-in function ‘sqrt’ [-Wbuiltin-declaration-mismatch]
     int sqrt (void);
    _configtest.c:11:5: warning: conflicting types for built-in function ‘log10’ [-Wbuiltin-declaration-mismatch]
     int log10 (void);
    _configtest.c:12:5: warning: conflicting types for built-in function ‘log’ [-Wbuiltin-declaration-mismatch]
     int log (void);
    _configtest.c:13:5: warning: conflicting types for built-in function ‘exp’ [-Wbuiltin-declaration-mismatch]
     int exp (void);
    _configtest.c:14:5: warning: conflicting types for built-in function ‘asin’ [-Wbuiltin-declaration-mismatch]
     int asin (void);
    _configtest.c:15:5: warning: conflicting types for built-in function ‘acos’ [-Wbuiltin-declaration-mismatch]
     int acos (void);
    _configtest.c:16:5: warning: conflicting types for built-in function ‘atan’ [-Wbuiltin-declaration-mismatch]
     int atan (void);
    _configtest.c:17:5: warning: conflicting types for built-in function ‘fmod’ [-Wbuiltin-declaration-mismatch]
     int fmod (void);
    _configtest.c:18:5: warning: conflicting types for built-in function ‘modf’ [-Wbuiltin-declaration-mismatch]
     int modf (void);
    _configtest.c:19:5: warning: conflicting types for built-in function ‘frexp’ [-Wbuiltin-declaration-mismatch]
     int frexp (void);
    _configtest.c:20:5: warning: conflicting types for built-in function ‘ldexp’ [-Wbuiltin-declaration-mismatch]
     int ldexp (void);
    success!
    success!
    success!
    success!
    success!
    success!
    success!
    success!
    success!
    success!
    _configtest.c:1:5: warning: conflicting types for built-in function ‘rint’ [-Wbuiltin-declaration-mismatch]
     int rint (void);
    _configtest.c:2:5: warning: conflicting types for built-in function ‘trunc’ [-Wbuiltin-declaration-mismatch]
     int trunc (void);
    _configtest.c:3:5: warning: conflicting types for built-in function ‘exp2’ [-Wbuiltin-declaration-mismatch]
     int exp2 (void);
    _configtest.c:4:5: warning: conflicting types for built-in function ‘log2’ [-Wbuiltin-declaration-mismatch]
     int log2 (void);
    _configtest.c:5:5: warning: conflicting types for built-in function ‘atan2’ [-Wbuiltin-declaration-mismatch]
     int atan2 (void);
    _configtest.c:6:5: warning: conflicting types for built-in function ‘pow’ [-Wbuiltin-declaration-mismatch]
     int pow (void);
    _configtest.c:7:5: warning: conflicting types for built-in function ‘nextafter’ [-Wbuiltin-declaration-mismatch]
     int nextafter (void);
    _configtest.c:10:5: warning: conflicting types for built-in function ‘cbrt’ [-Wbuiltin-declaration-mismatch]
     int cbrt (void);
    success!
    _configtest.c:1:10: fatal error: xmmintrin.h: No such file or directory
     #include <xmmintrin.h>
    failure.
    _configtest.c:1:10: fatal error: emmintrin.h: No such file or directory
     #include <emmintrin.h>
    failure.
    success!
    _configtest.c:1:10: fatal error: xlocale.h: No such file or directory
     #include <xlocale.h>
    failure.
    success!
    _configtest.c:5:3: warning: statement with no effect [-Wunused-value]
       __builtin_isnan(5.);
    success!
       __builtin_isinf(5.);
    success!
       __builtin_isfinite(5.);
    success!
       __builtin_bswap32(5u);
    success!
       __builtin_bswap64(5u);
    success!
       __builtin_expect(5, 0);
    success!
    success!
    _configtest.c:7:20: warning: implicit declaration of function ‘__builtin_cpu_supports’; did you mean ‘__builtin_isupper’? [-Wimplicit-function-declaration]
       volatile int r = __builtin_cpu_supports("sse");
                        __builtin_isupper
    _configtest.c:7:16: warning: unused variable ‘r’ [-Wunused-variable]
    /tmp/pip-install-pcwy4f04/numpy/_configtest.c:7: undefined reference to `__builtin_cpu_supports'
    failure.
    failure.
    failure.
    failure.
err.txt (158 KB)
continue
    failure.
    success!
    /tmp/ccnhtWvM.s: Assembler messages:
    /tmp/ccnhtWvM.s:19: Error: unknown mnemonic `vpand' -- `vpand %xmm1,%xmm2,%xmm3'
    failure.
    /tmp/ccujdS15.s: Assembler messages:
    /tmp/ccujdS15.s:19: Error: unknown mnemonic `vpand' -- `vpand %ymm1,%ymm2,%ymm3'
    failure.
    _configtest.c:3:0: warning: ignoring #pragma clang diagnostic [-Wunknown-pragmas]
     #pragma clang diagnostic error "-Wattributes"
    success!
    success!
    success!
    _configtest.c:5:1: error: target attribute ‘avx’ is invalid
     int __attribute__((target ("avx"))) attribute_target_avx(void*);
    failure.
    _configtest.c:5:1: error: target attribute ‘avx2’ is invalid
     int __attribute__((target ("avx2"))) attribute_target_avx2(void*);
    failure.
    success!
    _configtest.c: In function ‘__declspec’:
    _configtest.c:5:24: error: expected declaration specifiers before ‘foo’
     int __declspec(thread) foo;
    _configtest.c:9:1: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘{’ token
    _configtest.c:5:5: warning: type of ‘thread’ defaults to ‘int’ [-Wimplicit-int]
    _configtest.c:11:1: error: expected ‘{’ at end of input
    _configtest.c:11:1: warning: control reaches end of non-void function [-Wreturn-type]
    failure.
    _configtest.c:1:5: warning: conflicting types for built-in function ‘sinf’ [-Wbuiltin-declaration-mismatch]
     int sinf (void);
    _configtest.c:2:5: warning: conflicting types for built-in function ‘cosf’ [-Wbuiltin-declaration-mismatch]
     int cosf (void);
    _configtest.c:3:5: warning: conflicting types for built-in function ‘tanf’ [-Wbuiltin-declaration-mismatch]
     int tanf (void);
    _configtest.c:4:5: warning: conflicting types for built-in function ‘sinhf’ [-Wbuiltin-declaration-mismatch]
     int sinhf (void);
    _configtest.c:5:5: warning: conflicting types for built-in function ‘coshf’ [-Wbuiltin-declaration-mismatch]
     int coshf (void);
    _configtest.c:6:5: warning: conflicting types for built-in function ‘tanhf’ [-Wbuiltin-declaration-mismatch]
     int tanhf (void);
    _configtest.c:7:5: warning: conflicting types for built-in function ‘fabsf’ [-Wbuiltin-declaration-mismatch]
     int fabsf (void);
    _configtest.c:8:5: warning: conflicting types for built-in function ‘floorf’ [-Wbuiltin-declaration-mismatch]
     int floorf (void);
    _configtest.c:9:5: warning: conflicting types for built-in function ‘ceilf’ [-Wbuiltin-declaration-mismatch]
     int ceilf (void);
    _configtest.c:10:5: warning: conflicting types for built-in function ‘rintf’ [-Wbuiltin-declaration-mismatch]
     int rintf (void);
    _configtest.c:11:5: warning: conflicting types for built-in function ‘truncf’ [-Wbuiltin-declaration-mismatch]
     int truncf (void);
    _configtest.c:12:5: warning: conflicting types for built-in function ‘sqrtf’ [-Wbuiltin-declaration-mismatch]
     int sqrtf (void);
    _configtest.c:13:5: warning: conflicting types for built-in function ‘log10f’ [-Wbuiltin-declaration-mismatch]
     int log10f (void);
    _configtest.c:14:5: warning: conflicting types for built-in function ‘logf’ [-Wbuiltin-declaration-mismatch]
     int logf (void);
    _configtest.c:15:5: warning: conflicting types for built-in function ‘log1pf’ [-Wbuiltin-declaration-mismatch]
     int log1pf (void);
    _configtest.c:16:5: warning: conflicting types for built-in function ‘expf’ [-Wbuiltin-declaration-mismatch]
     int expf (void);
    _configtest.c:17:5: warning: conflicting types for built-in function ‘expm1f’ [-Wbuiltin-declaration-mismatch]
     int expm1f (void);
    _configtest.c:18:5: warning: conflicting types for built-in function ‘asinf’ [-Wbuiltin-declaration-mismatch]
     int asinf (void);
    _configtest.c:19:5: warning: conflicting types for built-in function ‘acosf’ [-Wbuiltin-declaration-mismatch]
     int acosf (void);
    _configtest.c:20:5: warning: conflicting types for built-in function ‘atanf’ [-Wbuiltin-declaration-mismatch]
     int atanf (void);
    _configtest.c:21:5: warning: conflicting types for built-in function ‘asinhf’ [-Wbuiltin-declaration-mismatch]
     int asinhf (void);
    _configtest.c:22:5: warning: conflicting types for built-in function ‘acoshf’ [-Wbuiltin-declaration-mismatch]
     int acoshf (void);
    _configtest.c:23:5: warning: conflicting types for built-in function ‘atanhf’ [-Wbuiltin-declaration-mismatch]
     int atanhf (void);
    _configtest.c:24:5: warning: conflicting types for built-in function ‘hypotf’ [-Wbuiltin-declaration-mismatch]
     int hypotf (void);
    _configtest.c:25:5: warning: conflicting types for built-in function ‘atan2f’ [-Wbuiltin-declaration-mismatch]
     int atan2f (void);
    _configtest.c:26:5: warning: conflicting types for built-in function ‘powf’ [-Wbuiltin-declaration-mismatch]
     int powf (void);
    _configtest.c:27:5: warning: conflicting types for built-in function ‘fmodf’ [-Wbuiltin-declaration-mismatch]
     int fmodf (void);
    _configtest.c:28:5: warning: conflicting types for built-in function ‘modff’ [-Wbuiltin-declaration-mismatch]
     int modff (void);
    _configtest.c:29:5: warning: conflicting types for built-in function ‘frexpf’ [-Wbuiltin-declaration-mismatch]
     int frexpf (void);
    _configtest.c:30:5: warning: conflicting types for built-in function ‘ldexpf’ [-Wbuiltin-declaration-mismatch]
     int ldexpf (void);
    _configtest.c:31:5: warning: conflicting types for built-in function ‘exp2f’ [-Wbuiltin-declaration-mismatch]
     int exp2f (void);
    _configtest.c:32:5: warning: conflicting types for built-in function ‘log2f’ [-Wbuiltin-declaration-mismatch]
     int log2f (void);
    _configtest.c:33:5: warning: conflicting types for built-in function ‘copysignf’ [-Wbuiltin-declaration-mismatch]
     int copysignf (void);
    _configtest.c:34:5: warning: conflicting types for built-in function ‘nextafterf’ [-Wbuiltin-declaration-mismatch]
     int nextafterf (void);
    _configtest.c:35:5: warning: conflicting types for built-in function ‘cbrtf’ [-Wbuiltin-declaration-mismatch]
     int cbrtf (void);
    success!
    _configtest.c:1:5: warning: conflicting types for built-in function ‘sinl’ [-Wbuiltin-declaration-mismatch]
     int sinl (void);
    _configtest.c:2:5: warning: conflicting types for built-in function ‘cosl’ [-Wbuiltin-declaration-mismatch]
     int cosl (void);
    _configtest.c:3:5: warning: conflicting types for built-in function ‘tanl’ [-Wbuiltin-declaration-mismatch]
     int tanl (void);
    _configtest.c:4:5: warning: conflicting types for built-in function ‘sinhl’ [-Wbuiltin-declaration-mismatch]
     int sinhl (void);
    _configtest.c:5:5: warning: conflicting types for built-in function ‘coshl’ [-Wbuiltin-declaration-mismatch]
     int coshl (void);
    _configtest.c:6:5: warning: conflicting types for built-in function ‘tanhl’ [-Wbuiltin-declaration-mismatch]
     int tanhl (void);
    _configtest.c:7:5: warning: conflicting types for built-in function ‘fabsl’ [-Wbuiltin-declaration-mismatch]
     int fabsl (void);
    _configtest.c:8:5: warning: conflicting types for built-in function ‘floorl’ [-Wbuiltin-declaration-mismatch]
     int floorl (void);
    _configtest.c:9:5: warning: conflicting types for built-in function ‘ceill’ [-Wbuiltin-declaration-mismatch]
     int ceill (void);
    _configtest.c:10:5: warning: conflicting types for built-in function ‘rintl’ [-Wbuiltin-declaration-mismatch]
     int rintl (void);
    _configtest.c:11:5: warning: conflicting types for built-in function ‘truncl’ [-Wbuiltin-declaration-mismatch]
     int truncl (void);
    _configtest.c:12:5: warning: conflicting types for built-in function ‘sqrtl’ [-Wbuiltin-declaration-mismatch]
     int sqrtl (void);
    _configtest.c:13:5: warning: conflicting types for built-in function ‘log10l’ [-Wbuiltin-declaration-mismatch]
     int log10l (void);
    _configtest.c:14:5: warning: conflicting types for built-in function ‘logl’ [-Wbuiltin-declaration-mismatch]
     int logl (void);
    _configtest.c:15:5: warning: conflicting types for built-in function ‘log1pl’ [-Wbuiltin-declaration-mismatch]
     int log1pl (void);
    _configtest.c:16:5: warning: conflicting types for built-in function ‘expl’ [-Wbuiltin-declaration-mismatch]
     int expl (void);
    _configtest.c:17:5: warning: conflicting types for built-in function ‘expm1l’ [-Wbuiltin-declaration-mismatch]
     int expm1l (void);
    _configtest.c:18:5: warning: conflicting types for built-in function ‘asinl’ [-Wbuiltin-declaration-mismatch]
     int asinl (void);
    _configtest.c:19:5: warning: conflicting types for built-in function ‘acosl’ [-Wbuiltin-declaration-mismatch]
     int acosl (void);
    _configtest.c:20:5: warning: conflicting types for built-in function ‘atanl’ [-Wbuiltin-declaration-mismatch]
     int atanl (void);
    _configtest.c:21:5: warning: conflicting types for built-in function ‘asinhl’ [-Wbuiltin-declaration-mismatch]
     int asinhl (void);
    _configtest.c:22:5: warning: conflicting types for built-in function ‘acoshl’ [-Wbuiltin-declaration-mismatch]
     int acoshl (void);
    _configtest.c:23:5: warning: conflicting types for built-in function ‘atanhl’ [-Wbuiltin-declaration-mismatch]
     int atanhl (void);
    _configtest.c:24:5: warning: conflicting types for built-in function ‘hypotl’ [-Wbuiltin-declaration-mismatch]
     int hypotl (void);
    _configtest.c:25:5: warning: conflicting types for built-in function ‘atan2l’ [-Wbuiltin-declaration-mismatch]
     int atan2l (void);
    _configtest.c:26:5: warning: conflicting types for built-in function ‘powl’ [-Wbuiltin-declaration-mismatch]
     int powl (void);
    _configtest.c:27:5: warning: conflicting types for built-in function ‘fmodl’ [-Wbuiltin-declaration-mismatch]
     int fmodl (void);
    _configtest.c:28:5: warning: conflicting types for built-in function ‘modfl’ [-Wbuiltin-declaration-mismatch]
     int modfl (void);
    _configtest.c:29:5: warning: conflicting types for built-in function ‘frexpl’ [-Wbuiltin-declaration-mismatch]
     int frexpl (void);
    _configtest.c:30:5: warning: conflicting types for built-in function ‘ldexpl’ [-Wbuiltin-declaration-mismatch]
     int ldexpl (void);
    _configtest.c:31:5: warning: conflicting types for built-in function ‘exp2l’ [-Wbuiltin-declaration-mismatch]
     int exp2l (void);
    _configtest.c:32:5: warning: conflicting types for built-in function ‘log2l’ [-Wbuiltin-declaration-mismatch]
     int log2l (void);
    _configtest.c:33:5: warning: conflicting types for built-in function ‘copysignl’ [-Wbuiltin-declaration-mismatch]
     int copysignl (void);
    _configtest.c:34:5: warning: conflicting types for built-in function ‘nextafterl’ [-Wbuiltin-declaration-mismatch]
     int nextafterl (void);
    _configtest.c:35:5: warning: conflicting types for built-in function ‘cbrtl’ [-Wbuiltin-declaration-mismatch]
     int cbrtl (void);
    success!
    success!
    success!
    success!
    success!
    _configtest.c:8:12: error: ‘HAVE_DECL_SIGNBIT’ undeclared (first use in this function); did you mean ‘HAVE_DECL_ISNAN’?
         (void) HAVE_DECL_SIGNBIT;
                HAVE_DECL_ISNAN
    _configtest.c:8:12: note: each undeclared identifier is reported only once for each function it appears in
                HAVE_DECL_ISNAN
    failure.
    success!
    success!
    success!
    success!
    _configtest.c:1:5: warning: conflicting types for built-in function ‘cabs’ [-Wbuiltin-declaration-mismatch]
     int cabs (void);
    _configtest.c:2:5: warning: conflicting types for built-in function ‘cacos’ [-Wbuiltin-declaration-mismatch]
     int cacos (void);
    _configtest.c:3:5: warning: conflicting types for built-in function ‘cacosh’ [-Wbuiltin-declaration-mismatch]
     int cacosh (void);
    _configtest.c:4:5: warning: conflicting types for built-in function ‘carg’ [-Wbuiltin-declaration-mismatch]
     int carg (void);
    _configtest.c:5:5: warning: conflicting types for built-in function ‘casin’ [-Wbuiltin-declaration-mismatch]
     int casin (void);
    _configtest.c:6:5: warning: conflicting types for built-in function ‘casinh’ [-Wbuiltin-declaration-mismatch]
     int casinh (void);
    _configtest.c:7:5: warning: conflicting types for built-in function ‘catan’ [-Wbuiltin-declaration-mismatch]
     int catan (void);
    _configtest.c:8:5: warning: conflicting types for built-in function ‘catanh’ [-Wbuiltin-declaration-mismatch]
     int catanh (void);
    _configtest.c:9:5: warning: conflicting types for built-in function ‘ccos’ [-Wbuiltin-declaration-mismatch]
     int ccos (void);
    _configtest.c:10:5: warning: conflicting types for built-in function ‘ccosh’ [-Wbuiltin-declaration-mismatch]
     int ccosh (void);
    _configtest.c:11:5: warning: conflicting types for built-in function ‘cexp’ [-Wbuiltin-declaration-mismatch]
     int cexp (void);
    _configtest.c:12:5: warning: conflicting types for built-in function ‘cimag’ [-Wbuiltin-declaration-mismatch]
     int cimag (void);
    _configtest.c:13:5: warning: conflicting types for built-in function ‘clog’ [-Wbuiltin-declaration-mismatch]
     int clog (void);
    _configtest.c:14:5: warning: conflicting types for built-in function ‘conj’ [-Wbuiltin-declaration-mismatch]
     int conj (void);
    _configtest.c:15:5: warning: conflicting types for built-in function ‘cpow’ [-Wbuiltin-declaration-mismatch]
     int cpow (void);
    _configtest.c:16:5: warning: conflicting types for built-in function ‘cproj’ [-Wbuiltin-declaration-mismatch]
     int cproj (void);
    _configtest.c:17:5: warning: conflicting types for built-in function ‘creal’ [-Wbuiltin-declaration-mismatch]
     int creal (void);
    _configtest.c:18:5: warning: conflicting types for built-in function ‘csin’ [-Wbuiltin-declaration-mismatch]
     int csin (void);
    _configtest.c:19:5: warning: conflicting types for built-in function ‘csinh’ [-Wbuiltin-declaration-mismatch]
     int csinh (void);
    _configtest.c:20:5: warning: conflicting types for built-in function ‘csqrt’ [-Wbuiltin-declaration-mismatch]
     int csqrt (void);
    _configtest.c:21:5: warning: conflicting types for built-in function ‘ctan’ [-Wbuiltin-declaration-mismatch]
     int ctan (void);
    _configtest.c:22:5: warning: conflicting types for built-in function ‘ctanh’ [-Wbuiltin-declaration-mismatch]
     int ctanh (void);
    success!
    _configtest.c:1:5: warning: conflicting types for built-in function ‘cabsf’ [-Wbuiltin-declaration-mismatch]
     int cabsf (void);
    _configtest.c:2:5: warning: conflicting types for built-in function ‘cacosf’ [-Wbuiltin-declaration-mismatch]
     int cacosf (void);
    _configtest.c:3:5: warning: conflicting types for built-in function ‘cacoshf’ [-Wbuiltin-declaration-mismatch]
     int cacoshf (void);
    _configtest.c:4:5: warning: conflicting types for built-in function ‘cargf’ [-Wbuiltin-declaration-mismatch]
     int cargf (void);
    _configtest.c:5:5: warning: conflicting types for built-in function ‘casinf’ [-Wbuiltin-declaration-mismatch]
     int casinf (void);
    _configtest.c:6:5: warning: conflicting types for built-in function ‘casinhf’ [-Wbuiltin-declaration-mismatch]
     int casinhf (void);
    _configtest.c:7:5: warning: conflicting types for built-in function ‘catanf’ [-Wbuiltin-declaration-mismatch]
     int catanf (void);
    _configtest.c:8:5: warning: conflicting types for built-in function ‘catanhf’ [-Wbuiltin-declaration-mismatch]
     int catanhf (void);
    _configtest.c:9:5: warning: conflicting types for built-in function ‘ccosf’ [-Wbuiltin-declaration-mismatch]
     int ccosf (void);
    _configtest.c:10:5: warning: conflicting types for built-in function ‘ccoshf’ [-Wbuiltin-declaration-mismatch]
     int ccoshf (void);
    _configtest.c:11:5: warning: conflicting types for built-in function ‘cexpf’ [-Wbuiltin-declaration-mismatch]
     int cexpf (void);
    _configtest.c:12:5: warning: conflicting types for built-in function ‘cimagf’ [-Wbuiltin-declaration-mismatch]
     int cimagf (void);
    _configtest.c:13:5: warning: conflicting types for built-in function ‘clogf’ [-Wbuiltin-declaration-mismatch]
     int clogf (void);
    _configtest.c:14:5: warning: conflicting types for built-in function ‘conjf’ [-Wbuiltin-declaration-mismatch]
     int conjf (void);
    _configtest.c:15:5: warning: conflicting types for built-in function ‘cpowf’ [-Wbuiltin-declaration-mismatch]
     int cpowf (void);
    _configtest.c:16:5: warning: conflicting types for built-in function ‘cprojf’ [-Wbuiltin-declaration-mismatch]
     int cprojf (void);
    _configtest.c:17:5: warning: conflicting types for built-in function ‘crealf’ [-Wbuiltin-declaration-mismatch]
     int crealf (void);
    _configtest.c:18:5: warning: conflicting types for built-in function ‘csinf’ [-Wbuiltin-declaration-mismatch]
     int csinf (void);
    _configtest.c:19:5: warning: conflicting types for built-in function ‘csinhf’ [-Wbuiltin-declaration-mismatch]
     int csinhf (void);
    _configtest.c:20:5: warning: conflicting types for built-in function ‘csqrtf’ [-Wbuiltin-declaration-mismatch]
     int csqrtf (void);
    _configtest.c:21:5: warning: conflicting types for built-in function ‘ctanf’ [-Wbuiltin-declaration-mismatch]
     int ctanf (void);
    _configtest.c:22:5: warning: conflicting types for built-in function ‘ctanhf’ [-Wbuiltin-declaration-mismatch]
     int ctanhf (void);
    success!
    _configtest.c:1:5: warning: conflicting types for built-in function ‘cabsl’ [-Wbuiltin-declaration-mismatch]
     int cabsl (void);
    _configtest.c:2:5: warning: conflicting types for built-in function ‘cacosl’ [-Wbuiltin-declaration-mismatch]
     int cacosl (void);
    _configtest.c:3:5: warning: conflicting types for built-in function ‘cacoshl’ [-Wbuiltin-declaration-mismatch]
     int cacoshl (void);
    _configtest.c:4:5: warning: conflicting types for built-in function ‘cargl’ [-Wbuiltin-declaration-mismatch]
     int cargl (void);
    _configtest.c:5:5: warning: conflicting types for built-in function ‘casinl’ [-Wbuiltin-declaration-mismatch]
     int casinl (void);
    _configtest.c:6:5: warning: conflicting types for built-in function ‘casinhl’ [-Wbuiltin-declaration-mismatch]
     int casinhl (void);
    _configtest.c:7:5: warning: conflicting types for built-in function ‘catanl’ [-Wbuiltin-declaration-mismatch]
     int catanl (void);
    _configtest.c:8:5: warning: conflicting types for built-in function ‘catanhl’ [-Wbuiltin-declaration-mismatch]
     int catanhl (void);
    _configtest.c:9:5: warning: conflicting types for built-in function ‘ccosl’ [-Wbuiltin-declaration-mismatch]
     int ccosl (void);
    _configtest.c:10:5: warning: conflicting types for built-in function ‘ccoshl’ [-Wbuiltin-declaration-mismatch]
     int ccoshl (void);
    _configtest.c:11:5: warning: conflicting types for built-in function ‘cexpl’ [-Wbuiltin-declaration-mismatch]
     int cexpl (void);
    _configtest.c:12:5: warning: conflicting types for built-in function ‘cimagl’ [-Wbuiltin-declaration-mismatch]
     int cimagl (void);
    _configtest.c:13:5: warning: conflicting types for built-in function ‘clogl’ [-Wbuiltin-declaration-mismatch]
     int clogl (void);
    _configtest.c:14:5: warning: conflicting types for built-in function ‘conjl’ [-Wbuiltin-declaration-mismatch]
     int conjl (void);
    _configtest.c:15:5: warning: conflicting types for built-in function ‘cpowl’ [-Wbuiltin-declaration-mismatch]
     int cpowl (void);
    _configtest.c:16:5: warning: conflicting types for built-in function ‘cprojl’ [-Wbuiltin-declaration-mismatch]
     int cprojl (void);
    _configtest.c:17:5: warning: conflicting types for built-in function ‘creall’ [-Wbuiltin-declaration-mismatch]
     int creall (void);
    _configtest.c:18:5: warning: conflicting types for built-in function ‘csinl’ [-Wbuiltin-declaration-mismatch]
     int csinl (void);
    _configtest.c:19:5: warning: conflicting types for built-in function ‘csinhl’ [-Wbuiltin-declaration-mismatch]
     int csinhl (void);
    _configtest.c:20:5: warning: conflicting types for built-in function ‘csqrtl’ [-Wbuiltin-declaration-mismatch]
     int csqrtl (void);
    _configtest.c:21:5: warning: conflicting types for built-in function ‘ctanl’ [-Wbuiltin-declaration-mismatch]
     int ctanl (void);
    _configtest.c:22:5: warning: conflicting types for built-in function ‘ctanhl’ [-Wbuiltin-declaration-mismatch]
     int ctanhl (void);
    success!
    _configtest.c:2:12: warning: ‘static_func’ defined but not used [-Wunused-function]
     static int static_func (char * restrict a)
    success!
    success!
    File: build/src.linux-aarch64-3.6/numpy/core/include/numpy/config.h
    #define HAVE_ENDIAN_H 1
    #define SIZEOF_PY_INTPTR_T 8
    #define SIZEOF_OFF_T 8
    #define SIZEOF_PY_LONG_LONG 8
    #define MATHLIB m
    #define HAVE_SIN 1
    #define HAVE_COS 1
    #define HAVE_TAN 1
    #define HAVE_SINH 1
    #define HAVE_COSH 1
    #define HAVE_TANH 1
    #define HAVE_FABS 1
    #define HAVE_FLOOR 1
    #define HAVE_CEIL 1
    #define HAVE_SQRT 1
    #define HAVE_LOG10 1
    #define HAVE_LOG 1
    #define HAVE_EXP 1
    #define HAVE_ASIN 1
    #define HAVE_ACOS 1
    #define HAVE_ATAN 1
    #define HAVE_FMOD 1
    #define HAVE_MODF 1
    #define HAVE_FREXP 1
    #define HAVE_LDEXP 1
    #define HAVE_RINT 1
    #define HAVE_TRUNC 1
    #define HAVE_EXP2 1
    #define HAVE_LOG2 1
    #define HAVE_ATAN2 1
    #define HAVE_POW 1
    #define HAVE_NEXTAFTER 1
    #define HAVE_STRTOLL 1
    #define HAVE_STRTOULL 1
    #define HAVE_CBRT 1
    #define HAVE_STRTOLD_L 1
    #define HAVE_FALLOCATE 1
    #define HAVE_BACKTRACE 1
    #define HAVE_FEATURES_H 1
    #define HAVE_DLFCN_H 1
    #define HAVE___BUILTIN_ISNAN 1
    #define HAVE___BUILTIN_ISINF 1
    #define HAVE___BUILTIN_ISFINITE 1
    #define HAVE___BUILTIN_BSWAP32 1
    #define HAVE___BUILTIN_BSWAP64 1
    #define HAVE___BUILTIN_EXPECT 1
    #define HAVE___BUILTIN_MUL_OVERFLOW 1
    #define HAVE___BUILTIN_PREFETCH 1
    #define HAVE_ATTRIBUTE_OPTIMIZE_UNROLL_LOOPS 1
    #define HAVE_ATTRIBUTE_OPTIMIZE_OPT_3 1
    #define HAVE_ATTRIBUTE_NONNULL 1
    #define HAVE___THREAD 1
    #define HAVE_SINF 1
    #define HAVE_COSF 1
    #define HAVE_TANF 1
    #define HAVE_SINHF 1
    #define HAVE_COSHF 1
    #define HAVE_TANHF 1
    #define HAVE_FABSF 1
    #define HAVE_FLOORF 1
    #define HAVE_CEILF 1
    #define HAVE_RINTF 1
    #define HAVE_TRUNCF 1
    #define HAVE_SQRTF 1
    #define HAVE_LOG10F 1
    #define HAVE_LOGF 1
    #define HAVE_LOG1PF 1
    #define HAVE_EXPF 1
    #define HAVE_EXPM1F 1
    #define HAVE_ASINF 1
    #define HAVE_ACOSF 1
    #define HAVE_ATANF 1
    #define HAVE_ASINHF 1
    #define HAVE_ACOSHF 1
    #define HAVE_ATANHF 1
    #define HAVE_HYPOTF 1
    #define HAVE_ATAN2F 1
    #define HAVE_POWF 1
    #define HAVE_FMODF 1
    #define HAVE_MODFF 1
    #define HAVE_FREXPF 1
    #define HAVE_LDEXPF 1
    #define HAVE_EXP2F 1
    #define HAVE_LOG2F 1
    #define HAVE_COPYSIGNF 1
    #define HAVE_NEXTAFTERF 1
    #define HAVE_CBRTF 1
    #define HAVE_SINL 1
    #define HAVE_COSL 1
    #define HAVE_TANL 1
    #define HAVE_SINHL 1
    #define HAVE_COSHL 1
    #define HAVE_TANHL 1
    #define HAVE_FABSL 1
    #define HAVE_FLOORL 1
    #define HAVE_CEILL 1
    #define HAVE_RINTL 1
    #define HAVE_TRUNCL 1
    #define HAVE_SQRTL 1
    #define HAVE_LOG10L 1
    #define HAVE_LOGL 1
    #define HAVE_LOG1PL 1
    #define HAVE_EXPL 1
    #define HAVE_EXPM1L 1
    #define HAVE_ASINL 1
    #define HAVE_ACOSL 1
    #define HAVE_ATANL 1
    #define HAVE_ASINHL 1
    #define HAVE_ACOSHL 1
    #define HAVE_ATANHL 1
    #define HAVE_HYPOTL 1
    #define HAVE_ATAN2L 1
    #define HAVE_POWL 1
    #define HAVE_FMODL 1
    #define HAVE_MODFL 1
    #define HAVE_FREXPL 1
    #define HAVE_LDEXPL 1
    #define HAVE_EXP2L 1
    #define HAVE_LOG2L 1
    #define HAVE_COPYSIGNL 1
    #define HAVE_NEXTAFTERL 1
    #define HAVE_CBRTL 1
    #define HAVE_DECL_SIGNBIT
    #define HAVE_COMPLEX_H 1
    #define HAVE_CABS 1
    #define HAVE_CACOS 1
    #define HAVE_CACOSH 1
    #define HAVE_CARG 1
    #define HAVE_CASIN 1
    #define HAVE_CASINH 1
    #define HAVE_CATAN 1
    #define HAVE_CATANH 1
    #define HAVE_CCOS 1
    #define HAVE_CCOSH 1
    #define HAVE_CEXP 1
    #define HAVE_CIMAG 1
    #define HAVE_CLOG 1
    #define HAVE_CONJ 1
    #define HAVE_CPOW 1
    #define HAVE_CPROJ 1
    #define HAVE_CREAL 1
    #define HAVE_CSIN 1
    #define HAVE_CSINH 1
    #define HAVE_CSQRT 1
    #define HAVE_CTAN 1
    #define HAVE_CTANH 1
    #define HAVE_CABSF 1
    #define HAVE_CACOSF 1
    #define HAVE_CACOSHF 1
    #define HAVE_CARGF 1
    #define HAVE_CASINF 1
    #define HAVE_CASINHF 1
    #define HAVE_CATANF 1
    #define HAVE_CATANHF 1
    #define HAVE_CCOSF 1
    #define HAVE_CCOSHF 1
    #define HAVE_CEXPF 1
    #define HAVE_CIMAGF 1
    #define HAVE_CLOGF 1
    #define HAVE_CONJF 1
    #define HAVE_CPOWF 1
    #define HAVE_CPROJF 1
    #define HAVE_CREALF 1
    #define HAVE_CSINF 1
    #define HAVE_CSINHF 1
    #define HAVE_CSQRTF 1
    #define HAVE_CTANF 1
    #define HAVE_CTANHF 1
    #define HAVE_CABSL 1
    #define HAVE_CACOSL 1
    #define HAVE_CACOSHL 1
    #define HAVE_CARGL 1
    #define HAVE_CASINL 1
    #define HAVE_CASINHL 1
    #define HAVE_CATANL 1
    #define HAVE_CATANHL 1
    #define HAVE_CCOSL 1
    #define HAVE_CCOSHL 1
    #define HAVE_CEXPL 1
    #define HAVE_CIMAGL 1
    #define HAVE_CLOGL 1
    #define HAVE_CONJL 1
    #define HAVE_CPOWL 1
    #define HAVE_CPROJL 1
end
#define HAVE_CREALL 1
    #define HAVE_CSINL 1
    #define HAVE_CSINHL 1
    #define HAVE_CSQRTL 1
    #define HAVE_CTANL 1
    #define HAVE_CTANHL 1
    #define NPY_RESTRICT restrict
    #define NPY_RELAXED_STRIDES_CHECKING 1
    #define HAVE_LDOUBLE_IEEE_QUAD_LE 1
    #define NPY_PY3K 1
    #ifndef __cplusplus
    /* #undef inline */
    #endif
    #ifndef _NPY_NPY_CONFIG_H_
    #error config.h should never be included directly, include npy_config.h instead
    #endif
    EOF
      adding 'build/src.linux-aarch64-3.6/numpy/core/include/numpy/config.h' to sources.
    Generating build/src.linux-aarch64-3.6/numpy/core/include/numpy/_numpyconfig.h
     int exp (void);
    failure.
     int exp (void);
    success!
    success!
    success!
    File: build/src.linux-aarch64-3.6/numpy/core/include/numpy/_numpyconfig.h
    #define NPY_HAVE_ENDIAN_H 1
    #define NPY_SIZEOF_SHORT SIZEOF_SHORT
    #define NPY_SIZEOF_INT SIZEOF_INT
    #define NPY_SIZEOF_LONG SIZEOF_LONG
    #define NPY_SIZEOF_FLOAT 4
    #define NPY_SIZEOF_COMPLEX_FLOAT 8
    #define NPY_SIZEOF_DOUBLE 8
    #define NPY_SIZEOF_COMPLEX_DOUBLE 16
    #define NPY_SIZEOF_LONGDOUBLE 16
    #define NPY_SIZEOF_COMPLEX_LONGDOUBLE 32
    #define NPY_SIZEOF_PY_INTPTR_T 8
    #define NPY_SIZEOF_OFF_T 8
    #define NPY_SIZEOF_PY_LONG_LONG 8
    #define NPY_SIZEOF_LONGLONG 8
    #define NPY_NO_SMP 0
    #define NPY_HAVE_DECL_ISNAN
    #define NPY_HAVE_DECL_ISINF
    #define NPY_HAVE_DECL_ISFINITE
    #define NPY_HAVE_DECL_SIGNBIT
    #define NPY_USE_C99_COMPLEX 1
    #define NPY_HAVE_COMPLEX_DOUBLE 1
    #define NPY_HAVE_COMPLEX_FLOAT 1
    #define NPY_HAVE_COMPLEX_LONG_DOUBLE 1
    #define NPY_USE_C99_FORMATS 1
    #define NPY_VISIBILITY_HIDDEN __attribute__((visibility("hidden")))
    #define NPY_ABI_VERSION 0x01000009
    #define NPY_API_VERSION 0x0000000B
    #ifndef __STDC_FORMAT_MACROS
    #define __STDC_FORMAT_MACROS 1
    #endif
    EOF
      adding 'build/src.linux-aarch64-3.6/numpy/core/include/numpy/_numpyconfig.h' to sources.
    executing numpy/core/code_generators/generate_numpy_api.py
      adding 'build/src.linux-aarch64-3.6/numpy/core/include/numpy/__multiarray_api.h' to sources.
    numpy.core - nothing done with h_files = ['build/src.linux-aarch64-3.6/numpy/core/include/numpy/config.h', 'build/src.linux-aarch64-3.6/numpy/core/include/numpy/_numpyconfig.h', 'build/src.linux-aarch64-3.6/numpy/core/include/numpy/__multiarray_api.h']
    building extension "numpy.core.multiarray" sources
    creating build/src.linux-aarch64-3.6/numpy/core/src/multiarray
    conv_template:> build/src.linux-aarch64-3.6/numpy/core/src/multiarray/arraytypes.c
    conv_template:> build/src.linux-aarch64-3.6/numpy/core/src/multiarray/einsum.c
    conv_template:> build/src.linux-aarch64-3.6/numpy/core/src/multiarray/lowlevel_strided_loops.c
    conv_template:> build/src.linux-aarch64-3.6/numpy/core/src/multiarray/nditer_templ.c
    conv_template:> build/src.linux-aarch64-3.6/numpy/core/src/multiarray/scalartypes.c
    conv_template:> build/src.linux-aarch64-3.6/numpy/core/src/private/templ_common.h
    numpy.core - nothing done with h_files = ['build/src.linux-aarch64-3.6/numpy/core/src/private/templ_common.h', 'build/src.linux-aarch64-3.6/numpy/core/include/numpy/config.h', 'build/src.linux-aarch64-3.6/numpy/core/include/numpy/_numpyconfig.h', 'build/src.linux-aarch64-3.6/numpy/core/include/numpy/__multiarray_api.h']
    building extension "numpy.core.umath" sources
    executing numpy/core/code_generators/generate_ufunc_api.py
      adding 'build/src.linux-aarch64-3.6/numpy/core/include/numpy/__ufunc_api.h' to sources.
    creating build/src.linux-aarch64-3.6/numpy/core/src/umath
    conv_template:> build/src.linux-aarch64-3.6/numpy/core/src/umath/funcs.inc
      adding 'build/src.linux-aarch64-3.6/numpy/core/src/umath' to include_dirs.
    conv_template:> build/src.linux-aarch64-3.6/numpy/core/src/umath/simd.inc
    conv_template:> build/src.linux-aarch64-3.6/numpy/core/src/umath/loops.h
    conv_template:> build/src.linux-aarch64-3.6/numpy/core/src/umath/loops.c
    conv_template:> build/src.linux-aarch64-3.6/numpy/core/src/umath/scalarmath.c
    numpy.core - nothing done with h_files = ['build/src.linux-aarch64-3.6/numpy/core/src/umath/funcs.inc', 'build/src.linux-aarch64-3.6/numpy/core/src/umath/simd.inc', 'build/src.linux-aarch64-3.6/numpy/core/src/umath/loops.h', 'build/src.linux-aarch64-3.6/numpy/core/include/numpy/config.h', 'build/src.linux-aarch64-3.6/numpy/core/include/numpy/_numpyconfig.h', 'build/src.linux-aarch64-3.6/numpy/core/include/numpy/__ufunc_api.h']
    building extension "numpy.core.umath_tests" sources
    conv_template:> build/src.linux-aarch64-3.6/numpy/core/src/umath/umath_tests.c
    building extension "numpy.core.test_rational" sources
    conv_template:> build/src.linux-aarch64-3.6/numpy/core/src/umath/test_rational.c
    building extension "numpy.core.struct_ufunc_test" sources
    conv_template:> build/src.linux-aarch64-3.6/numpy/core/src/umath/struct_ufunc_test.c
    building extension "numpy.core.multiarray_tests" sources
    conv_template:> build/src.linux-aarch64-3.6/numpy/core/src/multiarray/multiarray_tests.c
    building extension "numpy.core.operand_flag_tests" sources
    conv_template:> build/src.linux-aarch64-3.6/numpy/core/src/umath/operand_flag_tests.c
    building extension "numpy.fft.fftpack_lite" sources
    building extension "numpy.linalg.lapack_lite" sources
    creating build/src.linux-aarch64-3.6/numpy/linalg
      adding 'numpy/linalg/lapack_lite/python_xerbla.c' to sources.
    building extension "numpy.linalg._umath_linalg" sources
    conv_template:> build/src.linux-aarch64-3.6/numpy/linalg/umath_linalg.c
    building extension "numpy.random.mtrand" sources
    creating build/src.linux-aarch64-3.6/numpy/random
    building data_files sources
    build_src: building npy-pkg config files
    running build_py
    creating build/lib.linux-aarch64-3.6
    creating build/lib.linux-aarch64-3.6/numpy
    copying numpy/ctypeslib.py -> build/lib.linux-aarch64-3.6/numpy
    copying numpy/_distributor_init.py -> build/lib.linux-aarch64-3.6/numpy
    copying numpy/dual.py -> build/lib.linux-aarch64-3.6/numpy
    copying numpy/setup.py -> build/lib.linux-aarch64-3.6/numpy
    copying numpy/__init__.py -> build/lib.linux-aarch64-3.6/numpy
    copying numpy/version.py -> build/lib.linux-aarch64-3.6/numpy
    copying numpy/matlib.py -> build/lib.linux-aarch64-3.6/numpy
    copying numpy/add_newdocs.py -> build/lib.linux-aarch64-3.6/numpy
    copying numpy/_import_tools.py -> build/lib.linux-aarch64-3.6/numpy
    copying numpy/_globals.py -> build/lib.linux-aarch64-3.6/numpy
    copying build/src.linux-aarch64-3.6/numpy/__config__.py -> build/lib.linux-aarch64-3.6/numpy
    creating build/lib.linux-aarch64-3.6/numpy/compat
    copying numpy/compat/_inspect.py -> build/lib.linux-aarch64-3.6/numpy/compat
    copying numpy/compat/setup.py -> build/lib.linux-aarch64-3.6/numpy/compat
    copying numpy/compat/__init__.py -> build/lib.linux-aarch64-3.6/numpy/compat
    copying numpy/compat/py3k.py -> build/lib.linux-aarch64-3.6/numpy/compat
    creating build/lib.linux-aarch64-3.6/numpy/core
    copying numpy/core/defchararray.py -> build/lib.linux-aarch64-3.6/numpy/core
    copying numpy/core/info.py -> build/lib.linux-aarch64-3.6/numpy/core
    copying numpy/core/numerictypes.py -> build/lib.linux-aarch64-3.6/numpy/core
    copying numpy/core/_internal.py -> build/lib.linux-aarch64-3.6/numpy/core
    copying numpy/core/cversions.py -> build/lib.linux-aarch64-3.6/numpy/core
    copying numpy/core/getlimits.py -> build/lib.linux-aarch64-3.6/numpy/core
    copying numpy/core/machar.py -> build/lib.linux-aarch64-3.6/numpy/core
    copying numpy/core/function_base.py -> build/lib.linux-aarch64-3.6/numpy/core
    copying numpy/core/records.py -> build/lib.linux-aarch64-3.6/numpy/core
    copying numpy/core/arrayprint.py -> build/lib.linux-aarch64-3.6/numpy/core
    copying numpy/core/shape_base.py -> build/lib.linux-aarch64-3.6/numpy/core
    copying numpy/core/setup.py -> build/lib.linux-aarch64-3.6/numpy/core
    copying numpy/core/__init__.py -> build/lib.linux-aarch64-3.6/numpy/core
    copying numpy/core/fromnumeric.py -> build/lib.linux-aarch64-3.6/numpy/core
    copying numpy/core/numeric.py -> build/lib.linux-aarch64-3.6/numpy/core
    copying numpy/core/setup_common.py -> build/lib.linux-aarch64-3.6/numpy/core
    copying numpy/core/memmap.py -> build/lib.linux-aarch64-3.6/numpy/core
    copying numpy/core/_methods.py -> build/lib.linux-aarch64-3.6/numpy/core
    copying numpy/core/einsumfunc.py -> build/lib.linux-aarch64-3.6/numpy/core
    copying numpy/core/code_generators/generate_numpy_api.py -> build/lib.linux-aarch64-3.6/numpy/core
    creating build/lib.linux-aarch64-3.6/numpy/distutils
    copying numpy/distutils/environment.py -> build/lib.linux-aarch64-3.6/numpy/distutils
    copying numpy/distutils/info.py -> build/lib.linux-aarch64-3.6/numpy/distutils
    copying numpy/distutils/core.py -> build/lib.linux-aarch64-3.6/numpy/distutils
    copying numpy/distutils/ccompiler.py -> build/lib.linux-aarch64-3.6/numpy/distutils
    copying numpy/distutils/lib2def.py -> build/lib.linux-aarch64-3.6/numpy/distutils
    copying numpy/distutils/from_template.py -> build/lib.linux-aarch64-3.6/numpy/distutils
    copying numpy/distutils/numpy_distribution.py -> build/lib.linux-aarch64-3.6/numpy/distutils
    copying numpy/distutils/line_endings.py -> build/lib.linux-aarch64-3.6/numpy/distutils
    copying numpy/distutils/intelccompiler.py -> build/lib.linux-aarch64-3.6/numpy/distutils
    copying numpy/distutils/pathccompiler.py -> build/lib.linux-aarch64-3.6/numpy/distutils
    copying numpy/distutils/extension.py -> build/lib.linux-aarch64-3.6/numpy/distutils
    copying numpy/distutils/misc_util.py -> build/lib.linux-aarch64-3.6/numpy/distutils
    copying numpy/distutils/exec_command.py -> build/lib.linux-aarch64-3.6/numpy/distutils
    copying numpy/distutils/npy_pkg_config.py -> build/lib.linux-aarch64-3.6/numpy/distutils
    copying numpy/distutils/msvccompiler.py -> build/lib.linux-aarch64-3.6/numpy/distutils
    copying numpy/distutils/setup.py -> build/lib.linux-aarch64-3.6/numpy/distutils
    copying numpy/distutils/__init__.py -> build/lib.linux-aarch64-3.6/numpy/distutils
    copying numpy/distutils/unixccompiler.py -> build/lib.linux-aarch64-3.6/numpy/distutils
    copying numpy/distutils/compat.py -> build/lib.linux-aarch64-3.6/numpy/distutils
    copying numpy/distutils/conv_template.py -> build/lib.linux-aarch64-3.6/numpy/distutils
    copying numpy/distutils/log.py -> build/lib.linux-aarch64-3.6/numpy/distutils
    copying numpy/distutils/__version__.py -> build/lib.linux-aarch64-3.6/numpy/distutils
    copying numpy/distutils/mingw32ccompiler.py -> build/lib.linux-aarch64-3.6/numpy/distutils
    copying numpy/distutils/cpuinfo.py -> build/lib.linux-aarch64-3.6/numpy/distutils
    copying numpy/distutils/system_info.py -> build/lib.linux-aarch64-3.6/numpy/distutils
    copying numpy/distutils/msvc9compiler.py -> build/lib.linux-aarch64-3.6/numpy/distutils
    copying build/src.linux-aarch64-3.6/numpy/distutils/__config__.py -> build/lib.linux-aarch64-3.6/numpy/distutils
    creating build/lib.linux-aarch64-3.6/numpy/distutils/command
    copying numpy/distutils/command/bdist_rpm.py -> build/lib.linux-aarch64-3.6/numpy/distutils/command
    copying numpy/distutils/command/build_ext.py -> build/lib.linux-aarch64-3.6/numpy/distutils/command
    copying numpy/distutils/command/egg_info.py -> build/lib.linux-aarch64-3.6/numpy/distutils/command
    copying numpy/distutils/command/install_clib.py -> build/lib.linux-aarch64-3.6/numpy/distutils/command
    copying numpy/distutils/command/build_scripts.py -> build/lib.linux-aarch64-3.6/numpy/distutils/command
    copying numpy/distutils/command/install_headers.py -> build/lib.linux-aarch64-3.6/numpy/distutils/command
    copying numpy/distutils/command/autodist.py -> build/lib.linux-aarch64-3.6/numpy/distutils/command
    copying numpy/distutils/command/config_compiler.py -> build/lib.linux-aarch64-3.6/numpy/distutils/command
    copying numpy/distutils/command/build.py -> build/lib.linux-aarch64-3.6/numpy/distutils/command
    copying numpy/distutils/command/build_src.py -> build/lib.linux-aarch64-3.6/numpy/distutils/command
    copying numpy/distutils/command/__init__.py -> build/lib.linux-aarch64-3.6/numpy/distutils/command
    copying numpy/distutils/command/build_clib.py -> build/lib.linux-aarch64-3.6/numpy/distutils/command
    copying numpy/distutils/command/develop.py -> build/lib.linux-aarch64-3.6/numpy/distutils/command
    copying numpy/distutils/command/sdist.py -> build/lib.linux-aarch64-3.6/numpy/distutils/command
    copying numpy/distutils/command/build_py.py -> build/lib.linux-aarch64-3.6/numpy/distutils/command
    copying numpy/distutils/command/install.py -> build/lib.linux-aarch64-3.6/numpy/distutils/command
    copying numpy/distutils/command/install_data.py -> build/lib.linux-aarch64-3.6/numpy/distutils/command
    copying numpy/distutils/command/config.py -> build/lib.linux-aarch64-3.6/numpy/distutils/command
    creating build/lib.linux-aarch64-3.6/numpy/distutils/fcompiler
    copying numpy/distutils/fcompiler/compaq.py -> build/lib.linux-aarch64-3.6/numpy/distutils/fcompiler
    copying numpy/distutils/fcompiler/pathf95.py -> build/lib.linux-aarch64-3.6/numpy/distutils/fcompiler
    copying numpy/distutils/fcompiler/none.py -> build/lib.linux-aarch64-3.6/numpy/distutils/fcompiler
    copying numpy/distutils/fcompiler/intel.py -> build/lib.linux-aarch64-3.6/numpy/distutils/fcompiler
    copying numpy/distutils/fcompiler/nag.py -> build/lib.linux-aarch64-3.6/numpy/distutils/fcompiler
    copying numpy/distutils/fcompiler/sun.py -> build/lib.linux-aarch64-3.6/numpy/distutils/fcompiler
    copying numpy/distutils/fcompiler/gnu.py -> build/lib.linux-aarch64-3.6/numpy/distutils/fcompiler
    copying numpy/distutils/fcompiler/pg.py -> build/lib.linux-aarch64-3.6/numpy/distutils/fcompiler
    copying numpy/distutils/fcompiler/__init__.py -> build/lib.linux-aarch64-3.6/numpy/distutils/fcompiler
    copying numpy/distutils/fcompiler/absoft.py -> build/lib.linux-aarch64-3.6/numpy/distutils/fcompiler
    copying numpy/distutils/fcompiler/vast.py -> build/lib.linux-aarch64-3.6/numpy/distutils/fcompiler
    copying numpy/distutils/fcompiler/lahey.py -> build/lib.linux-aarch64-3.6/numpy/distutils/fcompiler
    copying numpy/distutils/fcompiler/g95.py -> build/lib.linux-aarch64-3.6/numpy/distutils/fcompiler
    copying numpy/distutils/fcompiler/hpux.py -> build/lib.linux-aarch64-3.6/numpy/distutils/fcompiler
    copying numpy/distutils/fcompiler/mips.py -> build/lib.linux-aarch64-3.6/numpy/distutils/fcompiler
    copying numpy/distutils/fcompiler/ibm.py -> build/lib.linux-aarch64-3.6/numpy/distutils/fcompiler
    creating build/lib.linux-aarch64-3.6/numpy/doc
    copying numpy/doc/ufuncs.py -> build/lib.linux-aarch64-3.6/numpy/doc
    copying numpy/doc/subclassing.py -> build/lib.linux-aarch64-3.6/numpy/doc
    copying numpy/doc/constants.py -> build/lib.linux-aarch64-3.6/numpy/doc
    copying numpy/doc/internals.py -> build/lib.linux-aarch64-3.6/numpy/doc
    copying numpy/doc/structured_arrays.py -> build/lib.linux-aarch64-3.6/numpy/doc
    copying numpy/doc/__init__.py -> build/lib.linux-aarch64-3.6/numpy/doc
    copying numpy/doc/byteswapping.py -> build/lib.linux-aarch64-3.6/numpy/doc
    copying numpy/doc/glossary.py -> build/lib.linux-aarch64-3.6/numpy/doc
    copying numpy/doc/basics.py -> build/lib.linux-aarch64-3.6/numpy/doc
    copying numpy/doc/indexing.py -> build/lib.linux-aarch64-3.6/numpy/doc
    copying numpy/doc/broadcasting.py -> build/lib.linux-aarch64-3.6/numpy/doc
    copying numpy/doc/misc.py -> build/lib.linux-aarch64-3.6/numpy/doc
    copying numpy/doc/creation.py -> build/lib.linux-aarch64-3.6/numpy/doc
    creating build/lib.linux-aarch64-3.6/numpy/f2py
    copying numpy/f2py/use_rules.py -> build/lib.linux-aarch64-3.6/numpy/f2py
    copying numpy/f2py/cb_rules.py -> build/lib.linux-aarch64-3.6/numpy/f2py
    copying numpy/f2py/func2subr.py -> build/lib.linux-aarch64-3.6/numpy/f2py
    copying numpy/f2py/info.py -> build/lib.linux-aarch64-3.6/numpy/f2py
    copying numpy/f2py/cfuncs.py -> build/lib.linux-aarch64-3.6/numpy/f2py
    copying numpy/f2py/f2py2e.py -> build/lib.linux-aarch64-3.6/numpy/f2py
    copying numpy/f2py/f90mod_rules.py -> build/lib.linux-aarch64-3.6/numpy/f2py
    copying numpy/f2py/diagnose.py -> build/lib.linux-aarch64-3.6/numpy/f2py
    copying numpy/f2py/setup.py -> build/lib.linux-aarch64-3.6/numpy/f2py
    copying numpy/f2py/__init__.py -> build/lib.linux-aarch64-3.6/numpy/f2py
    copying numpy/f2py/crackfortran.py -> build/lib.linux-aarch64-3.6/numpy/f2py
    copying numpy/f2py/f2py_testing.py -> build/lib.linux-aarch64-3.6/numpy/f2py
    copying numpy/f2py/auxfuncs.py -> build/lib.linux-aarch64-3.6/numpy/f2py
    copying numpy/f2py/rules.py -> build/lib.linux-aarch64-3.6/numpy/f2py
    copying numpy/f2py/__main__.py -> build/lib.linux-aarch64-3.6/numpy/f2py
    copying numpy/f2py/capi_maps.py -> build/lib.linux-aarch64-3.6/numpy/f2py
    copying numpy/f2py/__version__.py -> build/lib.linux-aarch64-3.6/numpy/f2py
    copying numpy/f2py/common_rules.py -> build/lib.linux-aarch64-3.6/numpy/f2py
    creating build/lib.linux-aarch64-3.6/numpy/fft
    copying numpy/fft/info.py -> build/lib.linux-aarch64-3.6/numpy/fft
    copying numpy/fft/setup.py -> build/lib.linux-aarch64-3.6/numpy/fft
    copying numpy/fft/__init__.py -> build/lib.linux-aarch64-3.6/numpy/fft
    copying numpy/fft/helper.py -> build/lib.linux-aarch64-3.6/numpy/fft
    copying numpy/fft/fftpack.py -> build/lib.linux-aarch64-3.6/numpy/fft
    creating build/lib.linux-aarch64-3.6/numpy/lib
    copying numpy/lib/arrayterator.py -> build/lib.linux-aarch64-3.6/numpy/lib
    copying numpy/lib/info.py -> build/lib.linux-aarch64-3.6/numpy/lib
    copying numpy/lib/_iotools.py -> build/lib.linux-aarch64-3.6/numpy/lib
    copying numpy/lib/utils.py -> build/lib.linux-aarch64-3.6/numpy/lib
    copying numpy/lib/_version.py -> build/lib.linux-aarch64-3.6/numpy/lib
    copying numpy/lib/arraysetops.py -> build/lib.linux-aarch64-3.6/numpy/lib
    copying numpy/lib/function_base.py -> build/lib.linux-aarch64-3.6/numpy/lib
    copying numpy/lib/nanfunctions.py -> build/lib.linux-aarch64-3.6/numpy/lib
    copying numpy/lib/_datasource.py -> build/lib.linux-aarch64-3.6/numpy/lib
    copying numpy/lib/stride_tricks.py -> build/lib.linux-aarch64-3.6/numpy/lib
    copying numpy/lib/ufunclike.py -> build/lib.linux-aarch64-3.6/numpy/lib
    copying numpy/lib/financial.py -> build/lib.linux-aarch64-3.6/numpy/lib
    copying numpy/lib/shape_base.py -> build/lib.linux-aarch64-3.6/numpy/lib
    copying numpy/lib/index_tricks.py -> build/lib.linux-aarch64-3.6/numpy/lib
    copying numpy/lib/polynomial.py -> build/lib.linux-aarch64-3.6/numpy/lib
    copying numpy/lib/setup.py -> build/lib.linux-aarch64-3.6/numpy/lib
    copying numpy/lib/user_array.py -> build/lib.linux-aarch64-3.6/numpy/lib
    copying numpy/lib/__init__.py -> build/lib.linux-aarch64-3.6/numpy/lib
    copying numpy/lib/format.py -> build/lib.linux-aarch64-3.6/numpy/lib
    copying numpy/lib/recfunctions.py -> build/lib.linux-aarch64-3.6/numpy/lib
    copying numpy/lib/mixins.py -> build/lib.linux-aarch64-3.6/numpy/lib
    copying numpy/lib/arraypad.py -> build/lib.linux-aarch64-3.6/numpy/lib
    copying numpy/lib/type_check.py -> build/lib.linux-aarch64-3.6/numpy/lib
    copying numpy/lib/scimath.py -> build/lib.linux-aarch64-3.6/numpy/lib
    copying numpy/lib/npyio.py -> build/lib.linux-aarch64-3.6/numpy/lib
    copying numpy/lib/twodim_base.py -> build/lib.linux-aarch64-3.6/numpy/lib
    creating build/lib.linux-aarch64-3.6/numpy/linalg
    copying numpy/linalg/info.py -> build/lib.linux-aarch64-3.6/numpy/linalg
    copying numpy/linalg/setup.py -> build/lib.linux-aarch64-3.6/numpy/linalg
    copying numpy/linalg/__init__.py -> build/lib.linux-aarch64-3.6/numpy/linalg
    copying numpy/linalg/linalg.py -> build/lib.linux-aarch64-3.6/numpy/linalg
    creating build/lib.linux-aarch64-3.6/numpy/ma
    copying numpy/ma/core.py -> build/lib.linux-aarch64-3.6/numpy/ma
    copying numpy/ma/testutils.py -> build/lib.linux-aarch64-3.6/numpy/ma
    copying numpy/ma/setup.py -> build/lib.linux-aarch64-3.6/numpy/ma
    copying numpy/ma/__init__.py -> build/lib.linux-aarch64-3.6/numpy/ma
    copying numpy/ma/version.py -> build/lib.linux-aarch64-3.6/numpy/ma
    copying numpy/ma/timer_comparison.py -> build/lib.linux-aarch64-3.6/numpy/ma
    copying numpy/ma/mrecords.py -> build/lib.linux-aarch64-3.6/numpy/ma
    copying numpy/ma/extras.py -> build/lib.linux-aarch64-3.6/numpy/ma
    copying numpy/ma/bench.py -> build/lib.linux-aarch64-3.6/numpy/ma
    creating build/lib.linux-aarch64-3.6/numpy/matrixlib
    copying numpy/matrixlib/defmatrix.py -> build/lib.linux-aarch64-3.6/numpy/matrixlib
    copying numpy/matrixlib/setup.py -> build/lib.linux-aarch64-3.6/numpy/matrixlib
    copying numpy/matrixlib/__init__.py -> build/lib.linux-aarch64-3.6/numpy/matrixlib
    creating build/lib.linux-aarch64-3.6/numpy/polynomial
    copying numpy/polynomial/legendre.py -> build/lib.linux-aarch64-3.6/numpy/polynomial
    copying numpy/polynomial/chebyshev.py -> build/lib.linux-aarch64-3.6/numpy/polynomial
    copying numpy/polynomial/hermite_e.py -> build/lib.linux-aarch64-3.6/numpy/polynomial
    copying numpy/polynomial/polyutils.py -> build/lib.linux-aarch64-3.6/numpy/polynomial
    copying numpy/polynomial/_polybase.py -> build/lib.linux-aarch64-3.6/numpy/polynomial
    copying numpy/polynomial/polynomial.py -> build/lib.linux-aarch64-3.6/numpy/polynomial
    copying numpy/polynomial/setup.py -> build/lib.linux-aarch64-3.6/numpy/polynomial
    copying numpy/polynomial/__init__.py -> build/lib.linux-aarch64-3.6/numpy/polynomial
    copying numpy/polynomial/laguerre.py -> build/lib.linux-aarch64-3.6/numpy/polynomial
    copying numpy/polynomial/hermite.py -> build/lib.linux-aarch64-3.6/numpy/polynomial
    creating build/lib.linux-aarch64-3.6/numpy/random
    copying numpy/random/info.py -> build/lib.linux-aarch64-3.6/numpy/random
    copying numpy/random/setup.py -> build/lib.linux-aarch64-3.6/numpy/random
    copying numpy/random/__init__.py -> build/lib.linux-aarch64-3.6/numpy/random
    creating build/lib.linux-aarch64-3.6/numpy/testing
    copying numpy/testing/utils.py -> build/lib.linux-aarch64-3.6/numpy/testing
    copying numpy/testing/print_coercion_tables.py -> build/lib.linux-aarch64-3.6/numpy/testing
    copying numpy/testing/nosetester.py -> build/lib.linux-aarch64-3.6/numpy/testing
    copying numpy/testing/decorators.py -> build/lib.linux-aarch64-3.6/numpy/testing
    copying numpy/testing/setup.py -> build/lib.linux-aarch64-3.6/numpy/testing
    copying numpy/testing/__init__.py -> build/lib.linux-aarch64-3.6/numpy/testing
    copying numpy/testing/noseclasses.py -> build/lib.linux-aarch64-3.6/numpy/testing
    running build_clib
    customize UnixCCompiler
    customize UnixCCompiler using build_clib
    building 'npymath' library
    compiling C sources
    creating build/temp.linux-aarch64-3.6
    creating build/temp.linux-aarch64-3.6/numpy
    creating build/temp.linux-aarch64-3.6/numpy/core
    creating build/temp.linux-aarch64-3.6/numpy/core/src
    creating build/temp.linux-aarch64-3.6/numpy/core/src/npymath
    creating build/temp.linux-aarch64-3.6/build
    creating build/temp.linux-aarch64-3.6/build/src.linux-aarch64-3.6
    creating build/temp.linux-aarch64-3.6/build/src.linux-aarch64-3.6/numpy
    creating build/temp.linux-aarch64-3.6/build/src.linux-aarch64-3.6/numpy/core
    creating build/temp.linux-aarch64-3.6/build/src.linux-aarch64-3.6/numpy/core/src
    creating build/temp.linux-aarch64-3.6/build/src.linux-aarch64-3.6/numpy/core/src/npymath
    compile options: '-Ibuild/src.linux-aarch64-3.6/numpy/core/src/npymath -Inumpy/core/include -Ibuild/src.linux-aarch64-3.6/numpy/core/include/numpy -Inumpy/core/src/private -Inumpy/core/src -Inumpy/core -Inumpy/core/src/npymath -Inumpy/core/src/multiarray -Inumpy/core/src/umath -Inumpy/core/src/npysort -I/usr/include/python3.6m -I/mnt/Datas_nvidia/.virtualenvs/startedNANO/include/python3.6m -Ibuild/src.linux-aarch64-3.6/numpy/core/src/private -Ibuild/src.linux-aarch64-3.6/numpy/core/src/npymath -Ibuild/src.linux-aarch64-3.6/numpy/core/src/private -Ibuild/src.linux-aarch64-3.6/numpy/core/src/npymath -Ibuild/src.linux-aarch64-3.6/numpy/core/src/private -Ibuild/src.linux-aarch64-3.6/numpy/core/src/npymath -c'
    aarch64-linux-gnu-gcc: numpy/core/src/npymath/npy_math.c
    aarch64-linux-gnu-gcc: build/src.linux-aarch64-3.6/numpy/core/src/npymath/ieee754.c
    aarch64-linux-gnu-gcc: build/src.linux-aarch64-3.6/numpy/core/src/npymath/npy_math_complex.c
    aarch64-linux-gnu-gcc: numpy/core/src/npymath/halffloat.c
    aarch64-linux-gnu-ar: adding 4 object files to build/temp.linux-aarch64-3.6/libnpymath.a
    error: Command "aarch64-linux-gnu-ar rcs build/temp.linux-aarch64-3.6/libnpymath.a build/temp.linux-aarch64-3.6/numpy/core/src/npymath/npy_math.o build/temp.linux-aarch64-3.6/build/src.linux-aarch64-3.6/numpy/core/src/npymath/ieee754.o build/temp.linux-aarch64-3.6/build/src.linux-aarch64-3.6/numpy/core/src/npymath/npy_math_complex.o build/temp.linux-aarch64-3.6/numpy/core/src/npymath/halffloat.o" failed with exit status -11
    ERROR: Failed building wheel for numpy
    Running setup.py clean for numpy
    ERROR: Complete output from command /mnt/Datas_nvidia/.virtualenvs/startedNANO/bin/python3 -u -c 'import setuptools, tokenize;__file__='"'"'/tmp/pip-install-pcwy4f04/numpy/setup.py'"'"';f=getattr(tokenize, '"'"'open'"'"', open)(__file__);code=f.read().replace('"'"'\r\n'"'"', '"'"'\n'"'"');f.close();exec(compile(code, __file__, '"'"'exec'"'"'))' clean --all:
    ERROR: Running from numpy source directory.
    `setup.py clean` is not supported, use one of the following instead:
      - `git clean -xdf` (cleans all files)
      - `git clean -Xdf` (cleans all versioned files, doesn't touch
                          files that aren't checked into the git repo)
    Add `--force` to your command to use it anyway if you must (unsupported).
    ERROR: Failed cleaning build dir for numpy
  Failed to build numpy
  Installing collected packages: wheel, setuptools, Cython, numpy
    Running setup.py install for numpy: started
      Running setup.py install for numpy: finished with status 'error'
      ERROR: Complete output from command /mnt/Datas_nvidia/.virtualenvs/startedNANO/bin/python3 -u -c 'import setuptools, tokenize;__file__='"'"'/tmp/pip-install-pcwy4f04/numpy/setup.py'"'"';f=getattr(tokenize, '"'"'open'"'"', open)(__file__);code=f.read().replace('"'"'\r\n'"'"', '"'"'\n'"'"');f.close();exec(compile(code, __file__, '"'"'exec'"'"'))' install --record /tmp/pip-record-hpjlfc4c/install-record.txt --single-version-externally-managed --prefix /tmp/pip-build-env-zwjrzhop/overlay --compile --install-headers /mnt/Datas_nvidia/.virtualenvs/startedNANO/include/site/python3.6/numpy:
      Note: if you need reliable uninstall behavior, then install
      with pip instead of using `setup.py install`:
        - `pip install .`       (from a git repo or downloaded source
                                 release)
        - `pip install numpy`   (last NumPy release on PyPi)
blas_opt_info:
      blas_mkl_info:
        libraries mkl_rt not found in ['/mnt/Datas_nvidia/.virtualenvs/startedNANO/lib', '/usr/local/lib', '/usr/lib', '/usr/lib/aarch64-linux-gnu']
        NOT AVAILABLE
      blis_info:
        libraries blis not found in ['/mnt/Datas_nvidia/.virtualenvs/startedNANO/lib', '/usr/local/lib', '/usr/lib', '/usr/lib/aarch64-linux-gnu']
        NOT AVAILABLE
      openblas_info:
        libraries openblas not found in ['/mnt/Datas_nvidia/.virtualenvs/startedNANO/lib', '/usr/local/lib', '/usr/lib', '/usr/lib/aarch64-linux-gnu']
        NOT AVAILABLE
      atlas_3_10_blas_threads_info:
      Setting PTATLAS=ATLAS
        libraries tatlas not found in ['/mnt/Datas_nvidia/.virtualenvs/startedNANO/lib', '/usr/local/lib', '/usr/lib', '/usr/lib/aarch64-linux-gnu/atlas', '/usr/lib/aarch64-linux-gnu']
        NOT AVAILABLE
      atlas_3_10_blas_info:
        libraries satlas not found in ['/mnt/Datas_nvidia/.virtualenvs/startedNANO/lib', '/usr/local/lib', '/usr/lib', '/usr/lib/aarch64-linux-gnu/atlas', '/usr/lib/aarch64-linux-gnu']
        NOT AVAILABLE
      atlas_blas_threads_info:
        libraries ptf77blas,ptcblas,atlas not found in ['/mnt/Datas_nvidia/.virtualenvs/startedNANO/lib', '/usr/local/lib', '/usr/lib', '/usr/lib/aarch64-linux-gnu/atlas', '/usr/lib/aarch64-linux-gnu']
        NOT AVAILABLE
      atlas_blas_info:
      customize Gnu95FCompiler
      Found executable /usr/bin/gfortran
      customize Gnu95FCompiler using config
      compiling '_configtest.c':
      /* This file is generated from numpy/distutils/system_info.py */
      void ATL_buildinfo(void);
      int main(void) {
        ATL_buildinfo();
        return 0;
      C compiler: aarch64-linux-gnu-gcc -pthread -DNDEBUG -g -fwrapv -O2 -Wall -g -fstack-protector-strong -Wformat -Werror=format-security -Wdate-time -D_FORTIFY_SOURCE=2 -fPIC
      compile options: '-c'
      aarch64-linux-gnu-gcc: _configtest.c
      aarch64-linux-gnu-gcc -pthread _configtest.o -lf77blas -lcblas -latlas -o _configtest
      ATLAS version 3.10.3 built by buildd on Tue Sep 19 12:24:37 UTC 2017:
         UNAME    : Linux bos01-arm64-010 4.4.0-96-generic #119-Ubuntu SMP Tue Sep 12 15:00:28 UTC 2017 aarch64 aarch64 aarch64 GNU/Linux
         INSTFLG  : -1 0 -a 1 -l 1
         ARCHDEFS : -DATL_OS_Linux -DATL_ARCH_GENERIC -DATL_USE64BITS -DATL_GAS_ARM64
         F2CDEFS  : -DAdd_ -DF77_INTEGER=int -DStringSunStyle
         CACHEEDGE: 2097152
         F77      : /usr/bin/gfortran, version GNU Fortran (Ubuntu/Linaro 7.2.0-5ubuntu1) 7.2.0
         F77FLAGS : -g -O2 -fdebug-prefix-map=/build/atlas-_lkXfd/atlas-3.10.3=. -fstack-protector-strong -fPIC
         SMC      : /usr/bin/gcc, version gcc (Ubuntu/Linaro 7.2.0-5ubuntu1) 7.2.0
         SMCFLAGS : -Wdate-time -D_FORTIFY_SOURCE=2 -g -O2 -fdebug-prefix-map=/build/atlas-_lkXfd/atlas-3.10.3=. -fstack-protector-strong -fPIC
         SKC      : /usr/bin/gcc, version gcc (Ubuntu/Linaro 7.2.0-5ubuntu1) 7.2.0
         SKCFLAGS : -Wdate-time -D_FORTIFY_SOURCE=2 -g -O2 -fdebug-prefix-map=/build/atlas-_lkXfd/atlas-3.10.3=. -fstack-protector-strong -fPIC
      success!
      removing: _configtest.c _configtest.o _configtest
        FOUND:
          language = c
          define_macros = [('HAVE_CBLAS', None), ('ATLAS_INFO', '"\"3.10.3\""')]
          libraries = ['f77blas', 'cblas', 'atlas', 'f77blas', 'cblas']
          library_dirs = ['/usr/lib/aarch64-linux-gnu']
        FOUND:
          language = c
      /bin/sh: 1: svnversion: not found
      non-existing path in 'numpy/distutils': 'site.cfg'
      F2PY Version 2
      lapack_opt_info:
      lapack_mkl_info:
        NOT AVAILABLE
      openblas_lapack_info:
        NOT AVAILABLE
      atlas_3_10_threads_info:
        libraries tatlas,tatlas not found in /mnt/Datas_nvidia/.virtualenvs/startedNANO/lib
        libraries lapack_atlas not found in /mnt/Datas_nvidia/.virtualenvs/startedNANO/lib
        libraries tatlas,tatlas not found in /usr/local/lib
        libraries lapack_atlas not found in /usr/local/lib
        libraries tatlas,tatlas not found in /usr/lib
        libraries lapack_atlas not found in /usr/lib
        libraries tatlas,tatlas not found in /usr/lib/aarch64-linux-gnu/atlas
        libraries lapack_atlas not found in /usr/lib/aarch64-linux-gnu/atlas
      <class 'numpy.distutils.system_info.atlas_3_10_threads_info'>
        NOT AVAILABLE
      atlas_3_10_info:
        libraries satlas,satlas not found in /mnt/Datas_nvidia/.virtualenvs/startedNANO/lib
        libraries satlas,satlas not found in /usr/local/lib
        libraries satlas,satlas not found in /usr/lib
        libraries satlas,satlas not found in /usr/lib/aarch64-linux-gnu/atlas
      <class 'numpy.distutils.system_info.atlas_3_10_info'>
        NOT AVAILABLE
      atlas_threads_info:
        libraries ptf77blas,ptcblas,atlas not found in /mnt/Datas_nvidia/.virtualenvs/startedNANO/lib
        libraries ptf77blas,ptcblas,atlas not found in /usr/local/lib
        libraries ptf77blas,ptcblas,atlas not found in /usr/lib
        libraries ptf77blas,ptcblas,atlas not found in /usr/lib/aarch64-linux-gnu/atlas
      <class 'numpy.distutils.system_info.atlas_threads_info'>
        NOT AVAILABLE
      atlas_info:
        libraries f77blas,cblas,atlas not found in /mnt/Datas_nvidia/.virtualenvs/startedNANO/lib
        libraries f77blas,cblas,atlas not found in /usr/local/lib
        libraries f77blas,cblas,atlas not found in /usr/lib
        libraries f77blas,cblas,atlas not found in /usr/lib/aarch64-linux-gnu/atlas
      <class 'numpy.distutils.system_info.atlas_info'>
        FOUND:
          language = f77
          libraries = ['lapack', 'f77blas', 'cblas', 'atlas', 'f77blas', 'cblas']
          define_macros = [('ATLAS_INFO', '"\"3.10.3\""')]
        FOUND:
          language = f77
      /usr/lib/python3.6/distutils/dist.py:261: UserWarning: Unknown distribution option: 'define_macros'
        warnings.warn(msg)
      running install
      running build
      running config_cc
      unifing config_cc, config, build_clib, build_ext, build commands --compiler options
      running config_fc
      unifing config_fc, config, build_clib, build_ext, build commands --fcompiler options
      running build_src
      build_src
      building py_modules sources
      building library "npymath" sources
      compile options: '-Inumpy/core/src/private -Inumpy/core/src -Inumpy/core -Inumpy/core/src/npymath -Inumpy/core/src/multiarray -Inumpy/core/src/umath -Inumpy/core/src/npysort -I/usr/include/python3.6m -I/mnt/Datas_nvidia/.virtualenvs/startedNANO/include/python3.6m -c'
      aarch64-linux-gnu-gcc -pthread _configtest.o -o _configtest
      success!
      _configtest.c:1:5: warning: conflicting types for built-in function ‘exp’ [-Wbuiltin-declaration-mismatch]
       int exp (void);
      _configtest.o: In function `main':
      /tmp/pip-install-pcwy4f04/numpy/_configtest.c:6: undefined reference to `exp'
      collect2: error: ld returned 1 exit status
      failure.
       int exp (void);
      aarch64-linux-gnu-gcc -pthread _configtest.o -lm -o _configtest
      success!
        adding 'build/src.linux-aarch64-3.6/numpy/core/src/npymath' to include_dirs.
      None - nothing done with h_files = ['build/src.linux-aarch64-3.6/numpy/core/src/npymath/npy_math_internal.h']
      building library "npysort" sources
        adding 'build/src.linux-aarch64-3.6/numpy/core/src/private' to include_dirs.
      None - nothing done with h_files = ['build/src.linux-aarch64-3.6/numpy/core/src/private/npy_partition.h', 'build/src.linux-aarch64-3.6/numpy/core/src/private/npy_binsearch.h']
      building extension "numpy.core._dummy" sources
      running build_py
      running build_clib
      compiling C sources
  ERROR: Command "/mnt/Datas_nvidia/.virtualenvs/startedNANO/bin/python3 -u -c 'import setuptools, tokenize;__file__='"'"'/tmp/pip-install-pcwy4f04/numpy/setup.py'"'"';f=getattr(tokenize, '"'"'open'"'"', open)(__file__);code=f.read().replace('"'"'\r\n'"'"', '"'"'\n'"'"');f.close();exec(compile(code, __file__, '"'"'exec'"'"'))' install --record /tmp/pip-record-hpjlfc4c/install-record.txt --single-version-externally-managed --prefix /tmp/pip-build-env-zwjrzhop/overlay --compile --install-headers /mnt/Datas_nvidia/.virtualenvs/startedNANO/include/site/python3.6/numpy" failed with error code 1 in /tmp/pip-install-pcwy4f04/numpy/
ERROR: Command "/mnt/Datas_nvidia/.virtualenvs/startedNANO/bin/python3 /mnt/Datas_nvidia/.virtualenvs/startedNANO/lib/python3.6/site-packages/pip install --ignore-installed --no-user --prefix /tmp/pip-build-env-zwjrzhop/overlay --no-warn-script-location --no-binary :none: --only-binary :none: -i https://pypi.org/simple -- wheel setuptools 'Cython>=0.29.2' 'numpy==1.13.3; python_version=='"'"'3.5'"'"'' 'numpy==1.13.3; python_version=='"'"'3.6'"'"'' 'numpy==1.14.5; python_version>='"'"'3.7'"'"''" failed with error code 1 in None
Hi dchuanav,
Due to issue happened on virtualenv, that’s not suggested, I can’t answer that, but you may try if can help:
Sudo apt-get -y install python3-scipy
Hi kayccc,
Thank you for your quick reply!
I want to use an environment manager in order to isolate programming environment for Python. So, I had searched conda (or miniconda), module venv of python3 and virtualvenv.
For now, official version of conda does not support aarch64 architecture of Jetson NANO, but I found that [url]https://devtalk.nvidia.com/default/topic/1051415/jetson-nano/anaconda-for-jetson-nano/[/url] with a branch of packages that support ARM platform. However, it has few packages at this time. So, I decided to use virtualenv and pip to install packages for Python.
If I go the wrong way, I think it is not the issue of virtualenv, but compilation. I checked a scipy installation via pip outside virtualenv but I’m stuck in the same problem.
