#1. Boot up without hdmi plugged
#2. Use following command through ssh to turn off the X11
sudo service lightdm stop
#Replug the HDMI and check if the error about that WIN3 still occurred.
#Use ctrl + alt +f1~f6 to see if console mode works.
Our hardware guy has changed a little, now HDMI work well on latest kernel version. Thanks a lot for your support. Now I want to support ov10635 image sensor, do you have any recommendation.
please refer to the 28.10.1 Input Data Formats chapter of the Parker Series SoC Technical Reference Manual.
according to the parker TRM, OV10635 output 18-bit combined RAW is not supported.
you could also check the tegra capability to choose the suitable camera sensor. thanks
i had notice that ov10635 output interface 10-bit parallel DVP which is not supported by tegra.
you may connect a bridge to convert this signal to mipi signal or other video formats.
thanks
you should check the bridge specification to confirm the converted MIPI is supported by Tegra or not.
please file another new topic if you have further questions.
thanks
We are probably experiencing the same problem. With a TX1 on our board HDMI works fine, with a TX2 we only get console. When X11 is started we get the next errors:
