I’m trying to setup HDMI on a customized mother board with a Jetson TX2. Design is the same as the SDK.
For the moment I have a black screen when I connect the TX2 to the screen.
Hot plug is recognized.
I saw similar problems on the forum but no specifics information in documentation.
In these posts, there are saying to disable uart 1, to pull down uart1_tx and to pull up uart0_RTS.
My questions are:
- Why do we had to do this ? Are there any information in doc ? I use uart1 in my mother board.
- Can we let uart1_tx floating ?
Thank you for your response.
Here is the log when I plug the HDMI:
[ 47.037415] tegradc 15210000.nvdisplay: unblank
[ 47.042661] tegra_nvdisp_handle_pd_enable: Unpowergated Head0 pd
[ 47.043622] tegra_nvdisp_handle_pd_enable: Unpowergated Head1 pd
[ 47.044104] tegra_nvdisp_handle_pd_enable: Unpowergated Head2 pd
[ 47.056850] Parent Clock set for DC plld2
[ 47.061833] tegradc 15210000.nvdisplay: hdmi: tmds rate:148500K prod-setting:prod_c_hdmi_111m_223m
[ 47.063690] tegradc 15210000.nvdisplay: hdmi: get RGB quant from EDID.
[ 47.063700] tegradc 15210000.nvdisplay: hdmi: get YCC quant from EDID.
[ 47.101418] extcon-disp-state external-connection:disp-state: cable 47 state 1
[ 47.101427] Extcon AUX1(HDMI) enable
[ 47.166992] extcon-disp-state external-connection:disp-state: cable 40 state 1
[ 47.174244] Extcon HDMI: HPD enabled
[ 47.174299] tegradc 15210000.nvdisplay: hdmi: plugged
[ 47.473229] tegradc 15210000.nvdisplay: blank - powerdown
[ 47.497246] extcon-disp-state external-connection:disp-state: cable 47 state 0
[ 47.497249] Extcon AUX1(HDMI) disable
[ 47.519273] tegra_nvdisp_handle_pd_disable: Powergated Head2 pd
[ 47.519350] tegra_nvdisp_handle_pd_disable: Powergated Head1 pd
[ 47.519950] tegra_nvdisp_handle_pd_disable: Powergated Head0 pd
[ 47.554222] tegradc 15210000.nvdisplay: blank - powerdown
[ 47.559777] tegradc 15210000.nvdisplay: unblank
[ 47.559999] extcon-disp-state external-connection:disp-state: cable 40 state 0
[ 47.560004] Extcon HDMI: HPD disabled
[ 47.560111] tegradc 15210000.nvdisplay: hdmi: unplugged
[ 47.580546] tegradc 15210000.nvdisplay: unblank
[ 47.591597] tegradc 15210000.nvdisplay: blank - powerdown
[ 47.597017] tegradc 15210000.nvdisplay: unblank
[ 47.601589] tegradc 15210000.nvdisplay: unblank
[ 47.793388] tegradc 15210000.nvdisplay: blank - powerdown
[ 47.793691] tegradc 15210000.nvdisplay: unblank
[ 47.799082] tegra_nvdisp_handle_pd_enable: Unpowergated Head0 pd
[ 47.800074] tegra_nvdisp_handle_pd_enable: Unpowergated Head1 pd
[ 47.800625] tegra_nvdisp_handle_pd_enable: Unpowergated Head2 pd
[ 47.813245] Parent Clock set for DC plld2
[ 47.818171] tegradc 15210000.nvdisplay: hdmi: tmds rate:148500K prod-setting:prod_c_hdmi_111m_223m
[ 47.819855] tegradc 15210000.nvdisplay: hdmi: get RGB quant from EDID.
[ 47.819864] tegradc 15210000.nvdisplay: hdmi: get YCC quant from EDID.
[ 47.857754] extcon-disp-state external-connection:disp-state: cable 47 state 1
[ 47.857759] Extcon AUX1(HDMI) enable
[ 47.923194] extcon-disp-state external-connection:disp-state: cable 40 state 1
[ 47.930460] Extcon HDMI: HPD enabled
[ 47.930509] tegradc 15210000.nvdisplay: hdmi: plugged
[ 48.022930] tegradc 15210000.nvdisplay: blank - powerdown
[ 48.086743] extcon-disp-state external-connection:disp-state: cable 47 state 0
[ 48.086745] Extcon AUX1(HDMI) disable
[ 48.112516] tegra_nvdisp_handle_pd_disable: Powergated Head2 pd
[ 48.112607] tegra_nvdisp_handle_pd_disable: Powergated Head1 pd
[ 48.113224] tegra_nvdisp_handle_pd_disable: Powergated Head0 pd
[ 48.147638] tegradc 15210000.nvdisplay: unblank
[ 48.155415] tegra_nvdisp_handle_pd_enable: Unpowergated Head0 pd
[ 48.155517] tegra_nvdisp_handle_pd_enable: Unpowergated Head1 pd
[ 48.155603] tegra_nvdisp_handle_pd_enable: Unpowergated Head2 pd
[ 48.156967] Parent Clock set for DC plld2
[ 48.160147] tegradc 15210000.nvdisplay: hdmi: tmds rate:148500K prod-setting:prod_c_hdmi_111m_223m
[ 48.163550] tegradc 15210000.nvdisplay: hdmi: get RGB quant from EDID.
[ 48.163559] tegradc 15210000.nvdisplay: hdmi: get YCC quant from EDID.
[ 48.212097] extcon-disp-state external-connection:disp-state: cable 47 state 1
[ 48.212099] Extcon AUX1(HDMI) enable
[ 48.273663] tegradc 15210000.nvdisplay: unblank
[ 54.880562] extcon-disp-state external-connection:disp-state: cable 47 state 0
[ 54.887842] Extcon AUX1(HDMI) disable
[ 54.902817] tegra_nvdisp_handle_pd_disable: Powergated Head2 pd
[ 54.908830] tegra_nvdisp_handle_pd_disable: Powergated Head1 pd
[ 54.929053] tegra_nvdisp_handle_pd_disable: Powergated Head0 pd
[ 54.935383] tegradc 15210000.nvdisplay: blank - powerdown
[ 54.942330] extcon-disp-state external-connection:disp-state: cable 40 state 0
[ 54.950052] Extcon HDMI: HPD disabled
[ 54.955304] tegradc 15210000.nvdisplay: hdmi: unplugged
[ 54.964524] tegradc 15210000.nvdisplay: blank - powerdown
[ 54.969964] tegradc 15210000.nvdisplay: unblank
[ 54.974565] tegradc 15210000.nvdisplay: unblank
[ 55.180936] tegradc 15210000.nvdisplay: blank - powerdown
[ 55.181233] tegradc 15210000.nvdisplay: unblank
[ 55.187106] tegra_nvdisp_handle_pd_enable: Unpowergated Head0 pd
[ 55.188104] tegra_nvdisp_handle_pd_enable: Unpowergated Head1 pd
[ 55.188686] tegra_nvdisp_handle_pd_enable: Unpowergated Head2 pd
[ 55.201119] Parent Clock set for DC plld2
[ 55.205978] tegradc 15210000.nvdisplay: hdmi: tmds rate:148500K prod-setting:prod_c_hdmi_111m_223m
[ 55.207655] tegradc 15210000.nvdisplay: hdmi: get RGB quant from EDID.
[ 55.207667] tegradc 15210000.nvdisplay: hdmi: get YCC quant from EDID.
[ 55.245628] extcon-disp-state external-connection:disp-state: cable 47 state 1
[ 55.245636] Extcon AUX1(HDMI) enable
[ 55.317526] extcon-disp-state external-connection:disp-state: cable 40 state 1
[ 55.324787] Extcon HDMI: HPD enabled
[ 55.324831] tegradc 15210000.nvdisplay: hdmi: plugged
[ 55.419087] tegradc 15210000.nvdisplay: blank - powerdown
[ 55.474548] extcon-disp-state external-connection:disp-state: cable 47 state 0
[ 55.474551] Extcon AUX1(HDMI) disable
[ 55.496499] tegra_nvdisp_handle_pd_disable: Powergated Head2 pd
[ 55.496579] tegra_nvdisp_handle_pd_disable: Powergated Head1 pd
[ 55.497181] tegra_nvdisp_handle_pd_disable: Powergated Head0 pd
[ 55.531469] tegradc 15210000.nvdisplay: unblank
[ 55.534888] tegra_nvdisp_handle_pd_enable: Unpowergated Head0 pd
[ 55.537775] tegra_nvdisp_handle_pd_enable: Unpowergated Head1 pd
[ 55.539879] tegra_nvdisp_handle_pd_enable: Unpowergated Head2 pd
[ 55.547919] Parent Clock set for DC plld2
[ 55.554965] tegradc 15210000.nvdisplay: hdmi: tmds rate:148500K prod-setting:prod_c_hdmi_111m_223m
[ 55.558052] tegradc 15210000.nvdisplay: hdmi: get RGB quant from EDID.
[ 55.558060] tegradc 15210000.nvdisplay: hdmi: get YCC quant from EDID.
[ 55.594473] extcon-disp-state external-connection:disp-state: cable 47 state 1
[ 55.594481] Extcon AUX1(HDMI) enable
[ 55.654755] tegradc 15210000.nvdisplay: unblank
[ 60.325132] extcon-disp-state external-connection:disp-state: cable 47 state 0
[ 60.332565] Extcon AUX1(HDMI) disable
[ 60.348012] tegra_nvdisp_handle_pd_disable: Powergated Head2 pd
[ 60.354060] tegra_nvdisp_handle_pd_disable: Powergated Head1 pd
[ 60.371940] tegra_nvdisp_handle_pd_disable: Powergated Head0 pd
[ 60.378369] tegradc 15210000.nvdisplay: blank - powerdown
[ 60.385211] extcon-disp-state external-connection:disp-state: cable 40 state 0
[ 60.393101] Extcon HDMI: HPD disabled
[ 60.397399] tegradc 15210000.nvdisplay: hdmi: unplugged
[ 60.406769] tegradc 15210000.nvdisplay: blank - powerdown
[ 60.412208] tegradc 15210000.nvdisplay: unblank
[ 60.416801] tegradc 15210000.nvdisplay: unblank
[ 60.631417] tegradc 15210000.nvdisplay: blank - powerdown
[ 60.631460] tegradc 15210000.nvdisplay: unblank
[ 60.632670] tegra_nvdisp_handle_pd_enable: Unpowergated Head0 pd
[ 60.632827] tegra_nvdisp_handle_pd_enable: Unpowergated Head1 pd
[ 60.632949] tegra_nvdisp_handle_pd_enable: Unpowergated Head2 pd
[ 60.641633] Parent Clock set for DC plld2
[ 60.646655] tegradc 15210000.nvdisplay: hdmi: tmds rate:148500K prod-setting:prod_c_hdmi_111m_223m
[ 60.648175] tegradc 15210000.nvdisplay: hdmi: get RGB quant from EDID.
[ 60.648197] tegradc 15210000.nvdisplay: hdmi: get YCC quant from EDID.
[ 60.684298] extcon-disp-state external-connection:disp-state: cable 47 state 1
[ 60.684305] Extcon AUX1(HDMI) enable
[ 60.749614] extcon-disp-state external-connection:disp-state: cable 40 state 1
[ 60.756886] Extcon HDMI: HPD enabled
[ 60.756936] tegradc 15210000.nvdisplay: hdmi: plugged
[ 60.843965] tegradc 15210000.nvdisplay: blank - powerdown
[ 60.898420] extcon-disp-state external-connection:disp-state: cable 47 state 0
[ 60.898422] Extcon AUX1(HDMI) disable
[ 60.920483] tegra_nvdisp_handle_pd_disable: Powergated Head2 pd
[ 60.920567] tegra_nvdisp_handle_pd_disable: Powergated Head1 pd
[ 60.921187] tegra_nvdisp_handle_pd_disable: Powergated Head0 pd
[ 60.955582] tegradc 15210000.nvdisplay: unblank
[ 60.958771] tegra_nvdisp_handle_pd_enable: Unpowergated Head0 pd
[ 60.958867] tegra_nvdisp_handle_pd_enable: Unpowergated Head1 pd
[ 60.958953] tegra_nvdisp_handle_pd_enable: Unpowergated Head2 pd
[ 60.960335] Parent Clock set for DC plld2
[ 60.965268] tegradc 15210000.nvdisplay: hdmi: tmds rate:148500K prod-setting:prod_c_hdmi_111m_223m
[ 60.966712] tegradc 15210000.nvdisplay: hdmi: get RGB quant from EDID.
[ 60.966718] tegradc 15210000.nvdisplay: hdmi: get YCC quant from EDID.
[ 61.008874] extcon-disp-state external-connection:disp-state: cable 47 state 1
[ 61.008876] Extcon AUX1(HDMI) enable
[ 61.068698] tegradc 15210000.nvdisplay: unblank
[ 64.200847] extcon-disp-state external-connection:disp-state: cable 47 state 0
[ 64.208194] Extcon AUX1(HDMI) disable
[ 64.222663] tegra_nvdisp_handle_pd_disable: Powergated Head2 pd
[ 64.232397] tegra_nvdisp_handle_pd_disable: Powergated Head1 pd
[ 64.251481] tegra_nvdisp_handle_pd_disable: Powergated Head0 pd
[ 64.263135] tegradc 15210000.nvdisplay: blank - powerdown
[ 64.268679] extcon-disp-state external-connection:disp-state: cable 40 state 0
[ 64.275967] Extcon HDMI: HPD disabled
[ 64.276029] tegradc 15210000.nvdisplay: hdmi: unplugged
[ 64.277135] tegradc 15210000.nvdisplay: blank - powerdown
[ 64.291552] tegradc 15210000.nvdisplay: unblank
[ 64.296139] tegradc 15210000.nvdisplay: unblank
