Can not stream more than one virtual channel simultaneously
Done, here is the log:
trace-gst-wait-boost.log (4.9 MB)
CHANSEL_SHORT_FRAME and looks like lost the FE of frame 2.
kworker/5:0-3622    [005] ....  6071.613471: rtcpu_vinotify_error: tstamp:190277126363 cch:2 vi:0 tag:CSIMUX_FRAME channel:0x01 frame:2 vi_tstamp:6088867943552 data:0x00000003000000a0
     kworker/5:0-3622    [005] ....  6071.613471: rtcpu_vinotify_event: tstamp:190277130488 cch:2 vi:0 tag:CSIMUX_FRAME channel:0x01 frame:2 vi_tstamp:6088867943552 data:0x00000003000000a0
     kworker/5:0-3622    [005] ....  6071.613471: rtcpu_vinotify_event: tstamp:190277130742 cch:2 vi:0 tag:CHANSEL_SHORT_FRAME channel:0x41 frame:2 vi_tstamp:6088867943552 data:0x001c000001000400
     kworker/5:0-3622    [005] ....  6071.613472: rtcpu_vinotify_event: tstamp:190277442438 cch:2 vi:0 tag:VIFALC_ACTIONLST channel:0x0a frame:2 vi_tstamp:6088867959136 data:0x0000000001020001
     kworker/5:0-3622    [005] ....  6071.613472: rtcpu_vinotify_event: tstamp:190277442690 cch:2 vi:0 tag:FS channel:0x01 frame:3 vi_tstamp:6088867943552 data:0x0000000300000010
     kworker/5:0-3622    [005] ....  6071.613472: rtcpu_vinotify_event: tstamp:190277442982 cch:2 vi:0 tag:ATOMP_FE channel:0x00 frame:2 vi_tstamp:6088867943584 data:0x0000000000000400
     kworker/5:0-3622    [005] ....  6071.613472: rtcpu_vinotify_event: tstamp:190277443232 cch:2 vi:0 tag:ATOMP_FS channel:0x00 frame:3 vi_tstamp:6088867943584 data:0x0000000000000400
     kworker/5:0-3622    [005] ....  6071.613472: rtcpu_vinotify_event: tstamp:190277443513 cch:2 vi:0 tag:CHANSEL_EMBED_SOF channel:0x0a frame:3 vi_tstamp:6088867981536 data:0x0000000000000004
     kworker/5:0-3622    [005] ....  6071.613472: rtcpu_vinotify_event: tstamp:190277443757 cch:2 vi:0 tag:CHANSEL_EMBED_EOF channel:0x0a frame:3 vi_tstamp:6088867987232 data:0x0000000000000008
     kworker/5:0-3622    [005] ....  6071.613473: rtcpu_vinotify_event: tstamp:190277444032 cch:2 vi:0 tag:ATOMP_EMB_DATA_DONE channel:0x0a frame:3 vi_tstamp:6088867988064 data:0x0000000000000000
     kworker/5:0-3622    [005] ....  6071.613473: rtcpu_vinotify_event: tstamp:190277444278 cch:2 vi:0 tag:VIFALC_ACTIONLST channel:0x0a frame:3 vi_tstamp:6088868004928 data:0x0000000003020002
     kworker/5:0-3622    [005] ....  6071.613473: rtcpu_vinotify_event: tstamp:190277444553 cch:2 vi:0 tag:CHANSEL_NOMATCH channel:0x41 frame:3 vi_tstamp:6088868013536 data:0x00000000000006e9
     kworker/5:0-3622    [005] ....  6071.613473: rtcpu_vinotify_event: tstamp:190277444798 cch:2 vi:0 tag:VIFALC_TDSTATE channel:0x0a frame:0 vi_tstamp:6088868171424 data:0x759cc20010000000
     kworker/5:0-3622    [005] ....  6071.613473: rtcpu_vinotify_event: tstamp:190277445069 cch:2 vi:0 tag:VIFALC_TDSTATE channel:0x0a frame:0 vi_tstamp:6088868181440 data:0x0000000031000003
     kworker/5:0-3622    [005] ....  6071.613474: rtcpu_vinotify_event: tstamp:190277445309 cch:2 vi:0 tag:CHANSEL_PXL_SOF channel:0x0a frame:3 vi_tstamp:6088868653536 data:0x0000000000000001
Any idea why CHANSEL_SHORT_FRAME only shows up, when using nvarguscamerasrc? I don’t see this error in the v4l2-ctl trace log.
It’s could be the sensor control function incorrect setting cause it.
You may modify those function as dummy function to verify it.
