• Hardware Platform (Jetson / GPU) GPU 3090
• DeepStream Version 7.1 DOCKER
in some python example use create_rtsp_server
i have create a media server use mediamtx
how the pipeline can link to the mediamtx
server
now is
source.link(pgie)
pgie.link(queue_tee)
queue_tee.link(tee)
tee.link(queue_msgconv)
queue_msgconv.link(msgconv)
msgconv.link(queue_msgbroker)
queue_msgbroker.link(msgbroker)
tee.link(queue_tiler)
queue_tiler.link(converter)
converter.link(nvtiler)
nvtiler.link(nvosd)
nvosd.link(nvvidconv_encoder)
nvvidconv_encoder.link(filter_encoder)
filter_encoder.link(encoder)
encoder.link(rtppay)
rtppay.link(rtsp_sink)
another question rtsp pipeline is too long, can i Simplify it?
cihn
November 30, 2024, 11:41am
4
rtspclientsink= Gst.ElementFactory.make(“rtspclientsink”, “rtspclientsink1”)
rtspclientsink.set_property(“location”, “rtsp://localhost:8554/mystream”)
push to mediamtx
rtppay.link(rtspclientsink)
Watch the video
or
http://mediamtx_ip:8888/mystream
or
http://mediamtx_ip:8889/mystream
I want to know, are there any elements that are not necessary?
As to the RTSP send out function, the following plugins are necessary
The other plugins are for source, decoding, batching, inferencing, OSD,… You need to judge whether they are necessary for your requirement.
if need to draw box in frame, and display by a RTSP , must set nvdsosd
? nvmultistreamtiler
Is also necessary?
Yes. nvdsosd is needed. And you need to choose one from “nvmultistreamtiler” and “nvstreamdemux” depends on how will you output the videos in batch. Please read the document Gst-nvmultistreamtiler — DeepStream documentation and Gst-nvstreamdemux — DeepStream documentation
in deepstream_test1_rtsp_in_rtsp_out.py
i found nvvideoconvert -> nvmultistreamtiler ->nvmultistreamtiler -> nvosd ->xxxxx->rtsp
has two nvvideoconvert
, Why do this?
if i use nvstreamdemux
in multi RTSP out, how dose the pipeline looks like?
sink_nvstreamdemux = nvstreamdemux.get_static_pad("sink")
tee_rtsp_pad.link(sink_nvstreamdemux)
for index, sensor in enumerate(args.sensors):
# creating queue
queue = make_element("queue", index)
# creating nvvidconv
nvvideoconvert = make_element("nvvideoconvert", index)
# creating nvosd
nvdsosd = make_element("nvdsosd", index)
nvdsosd.set_property('process-mode', args.osd_process_mode)
nvdsosd.set_property('display-text', args.osd_display_text)
nvdsosd.set_property('display-bbox', 1)
# connect nvstreamdemux -> queue
padname = "src_%u" % index
demuxsrcpad = nvstreamdemux.request_pad_simple(padname)
if not demuxsrcpad:
logger.error("Unable to create demux src pad \n")
queuesinkpad = queue.get_static_pad("sink")
if not queuesinkpad:
logger.error("Unable to create queue sink pad \n")
caps = make_element("capsfilter", index)
caps.set_property("caps", Gst.Caps.from_string("video/x-raw(memory:NVMM), format=I420"))
if args.encoder_codec == "H265":
encoder = make_element("nvv4l2h265enc", index)
elif args.encoder_codec == "H264":
encoder = make_element("nvv4l2h264enc", index)
encoder.set_property("bitrate", args.bitrate)
encoder.set_property('tuning-info-id', 2)
encoder.set_property('control-rate', 2)
rtppay = make_element("rtph264pay", index)
elif args.encoder_codec == "H265":
rtppay = make_element("rtph265pay", index)
rtspclientsink = make_element("rtspclientsink",index)
rtspclientsink.set_property("location", f"{sensor.url}/results")
pipeline.add(queue)
pipeline.add(nvvideoconvert)
pipeline.add(nvdsosd)
pipeline.add(caps)
pipeline.add(encoder)
pipeline.add(rtppay)
pipeline.add(rtspclientsink)
demuxsrcpad.link(queuesinkpad)
queue.link(nvvideoconvert)
nvvideoconvert.link(nvdsosd)
nvdsosd.link(caps)
caps.link(encoder)
this seems wrong, and no error log output
It is a legacy pipeline. For the very old DeepStream version, nvdsosd only support RGB format input, the first nvvideoconvert will help to convert the yuv to rgb and the second nvvideoconvert will help to convert the rgb to yuv for encoding. For the latest DeepStream, there is no such limitation, the nvvideoconvert will do nothing if the input format and resolution is just the same as the output format and resolution. It is OK.
For the usage of nvstreamdemux, please refer to the sample in Gst-nvstreamdemux — DeepStream documentation
Why did you put capsfilter after nvdsosd?
I wrote it based on this.
This is our code of deepstream_test1_rtsp_in_rtsp_out.py:
nvvidconv.link(nvosd)
nvosd.link(nvvidconv_postosd)
**nvvidconv_postosd.link(caps)**
caps.link(encoder)
rtppay.link(sink)
The capsfilter is after nvvideoconvert.
It is important for you to debug and check with your code before you send any topic in the forum. It is not efficient to develop your own app in this way.
We are not responsible for your own code. Please debug by yourself before you really identify the issue is caused by DeepStream SDK.
system
Closed
December 17, 2024, 10:17am
16
