RTSP outputs contains bounding boxes drawings from all streams and Unable to draw text error
Jetson Orin
• DeepStream Version
6.1.1
5.0.2
• TensorRT Version
8.4.1-1+cuda11.4
Refering to this post:
I was struggling in getting the parent info from NvDsObjectMeta. I was able to accomplish it by doing the following as suggested:
I also had to move nvmsgconv and nvmsgbroker plugins before SGIE to be able to send detection throught kafka.
Everything works fine but when I open the RTSP output I noticed that all the bounding boxes from all the streams are being drawn in every RTSP output.
Thus, the RTSP output for stream 1, let’s call it RTSP_1 contains the bbox drawings from streams 1, 2, 3.
so RTSP_2 also contains the bbox drawings from streams 1, 2, 3 and RTSP_3 also contains the bbox drawings from streams 1, 2, 3. How can I fix this?
Additionally, sometimes I keep getting the errors below:
I say sometimes because when I run the application again it works fine. How can I fix this?
What’s your pipeline like? How did you separate the stream?
There maybe some memory problems in your code. Could you attach all your demo code?
@yuweiw I am attaching the main function.
I separate the stream Using nvstreamdemux
My code is based on deepstream-imagedata-multistream-redaction.py
def main(uri_inputs,codec,bitrate ):
    # Check input arguments
    number_sources = len(uri_inputs)
    global NUM_STREAMS
    NUM_STREAMS = len(uri_inputs)
    global perf_data
    perf_data = PERF_DATA(number_sources)
    global folder_name
    folder_name = "out_crops"
    # if path.exists(folder_name):
    #     sys.stderr.write("The output folder %s already exists. Please remove it first.\n" % folder_name)
    #     sys.exit(1)
    # os.mkdir(folder_name)
    # print("Frames will be saved in ", folder_name)
    # Standard GStreamer initialization
    Gst.init(None)
    # Create gstreamer elements */
    # Create Pipeline element that will form a connection of other elements
    print("Creating Pipeline \n ")
    pipeline = Gst.Pipeline()
    is_live = False
    if not pipeline:
        sys.stderr.write(" Unable to create Pipeline \n")
    print("Creating streamux \n ")
    # Create nvstreammux instance to form batches from one or more sources.
    streammux = Gst.ElementFactory.make("nvstreammux", "Stream-muxer")
    if not streammux:
        sys.stderr.write(" Unable to create NvStreamMux \n")
    pipeline.add(streammux)
    for i in range(number_sources):
        #os.mkdir(folder_name + "/stream_" + str(i))
        frame_count["stream_" + str(i)] = 0
        saved_count["stream_" + str(i)] = 0
        print("Creating source_bin ", i, " \n ")
        uri_name = uri_inputs[i]
        if uri_name.find("rtsp://") == 0:
            is_live = True
        source_bin = create_source_bin(i, uri_name)
        if not source_bin:
            sys.stderr.write("Unable to create source bin \n")
        pipeline.add(source_bin)
        padname = "sink_%u" % i
        sinkpad = streammux.get_request_pad(padname)
        if not sinkpad:
            sys.stderr.write("Unable to create sink pad bin \n")
        srcpad = source_bin.get_static_pad("src")
        if not srcpad:
            sys.stderr.write("Unable to create src pad bin \n")
        srcpad.link(sinkpad)
    q = Gst.ElementFactory.make("queue", "queue1")
    # Primary detector
    print("Creating Pgie \n ")
    pgie = Gst.ElementFactory.make("nvinfer", "primary-inference")
    if not pgie:
        sys.stderr.write(" Unable to create pgie \n")
    # creating tracker
    tracker = Gst.ElementFactory.make("nvtracker", "tracker")
    if not tracker:
        sys.stderr.write(" Unable to create tracker \n")
    # Secondary detector
    sgie1 = Gst.ElementFactory.make("nvinfer", "secondary1-nvinference-engine")
    if not sgie1:
        sys.stderr.write(" Unable to make sgie1 \n")
    # Third Detector
    sgie2 = Gst.ElementFactory.make("nvinfer", "secondary2-nvinference-engine")
    if not sgie2:
        sys.stderr.write(" Unable to make sgie2 \n")
    print("Creating nvstreamdemux \n ")
    nvstreamdemux = Gst.ElementFactory.make("nvstreamdemux", "nvstreamdemux")
    if not nvstreamdemux:
        sys.stderr.write(" Unable to create nvstreamdemux \n")
    if is_live:
        print("Atleast one of the sources is live")
        streammux.set_property("live-source", 1)
    #print("Creating tiler \n ")
    # tiler = Gst.ElementFactory.make("nvmultistreamtiler", "nvtiler")
    # if not tiler:
    #     sys.stderr.write(" Unable to create tiler \n")
    # fake sink
    # sink = Gst.ElementFactory.make("fakesink", "nvvideo-renderer")
    # if not sink:
    #    sys.stderr.write("ERROR: Unable to create FAKE sink\n")
    #    sys.exit(1)
    # sink.set_property("sync", 0)
    print("Playing file {} ".format(uri_inputs))
    streammux.set_property('width', 1920)
    streammux.set_property('height', 1080)
    streammux.set_property('batch-size', number_sources)
    streammux.set_property('batched-push-timeout', 4000000)
    pgie.set_property('config-file-path', "config_infer_primary.txt")
    sgie1.set_property('config-file-path', "config_infer_secondary.txt")
    sgie2.set_property('config-file-path', "config_infer_third.txt")
    pgie_batch_size = pgie.get_property("batch-size")
    if (pgie_batch_size != number_sources):
        print("WARNING: Overriding infer-config batch-size", pgie_batch_size, " with number of sources ",
              number_sources, " \n")
        pgie.set_property("batch-size", number_sources)
    # tiler_rows = int(math.sqrt(number_sources))
    # tiler_columns = int(math.ceil((1.0 * number_sources) / tiler_rows))
    # tiler.set_property("rows", tiler_rows)
    # tiler.set_property("columns", tiler_columns)
    # tiler.set_property("width", TILED_OUTPUT_WIDTH)
    # tiler.set_property("height", TILED_OUTPUT_HEIGHT)
    #Set properties of tracker
    config = configparser.ConfigParser()
    config.read('dstest_tracker_config.txt')
    config.sections()
    for key in config['tracker']:
        if key == 'tracker-width' :
            tracker_width = config.getint('tracker', key)
            tracker.set_property('tracker-width', tracker_width)
        if key == 'tracker-height' :
            tracker_height = config.getint('tracker', key)
            tracker.set_property('tracker-height', tracker_height)
        if key == 'gpu-id' :
            tracker_gpu_id = config.getint('tracker', key)
            tracker.set_property('gpu_id', tracker_gpu_id)
        if key == 'll-lib-file' :
            tracker_ll_lib_file = config.get('tracker', key)
            tracker.set_property('ll-lib-file', tracker_ll_lib_file)
        if key == 'll-config-file' :
            tracker_ll_config_file = config.get('tracker', key)
            tracker.set_property('ll-config-file', tracker_ll_config_file)
        if key == 'enable-batch-process' :
            tracker_enable_batch_process = config.getint('tracker', key)
            tracker.set_property('enable_batch_process', tracker_enable_batch_process)
        if key == 'enable-past-frame' :
            tracker_enable_past_frame = config.getint('tracker', key)
            tracker.set_property('enable_past_frame', tracker_enable_past_frame)
    if not is_aarch64():
        # Use CUDA unified memory in the pipeline so frames
        # can be easily accessed on CPU in Python.
        mem_type = int(pyds.NVBUF_MEM_CUDA_UNIFIED)
        streammux.set_property("nvbuf-memory-type", mem_type)
        # nvvidconv.set_property("nvbuf-memory-type", mem_type)
        # nvvidconv1.set_property("nvbuf-memory-type", mem_type)
        #tiler.set_property("nvbuf-memory-type", mem_type)
    print("Creating nvvidconv1 \n ")
    #nvvidconv1 = Gst.ElementFactory.make("nvvideoconvert", "convertor1")
    nvvidconvert_pre = Gst.ElementFactory.make("nvvideoconvert", "nvvidconvert_pre")
    if not nvvidconvert_pre:
        sys.stderr.write(" Unable to create nvvidconvert_pre \n")
    print("Creating pre filter1 \n ")
    caps1_pre  = Gst.Caps.from_string("video/x-raw(memory:NVMM), format=RGBA")
    #filter1 = Gst.ElementFactory.make("capsfilter", "filter1")
    filter1_pre  = Gst.ElementFactory.make("capsfilter", "filter1_pre")
    if not filter1_pre:
        sys.stderr.write(" Unable to get the caps filter1_pre \n")
    filter1_pre.set_property("caps", caps1_pre)
    queue1 = Gst.ElementFactory.make("queue", "nvtee-que1")
    #queue1 = make_element("queue", "queue1"+str(i))
    if not queue1:
        sys.stderr.write(" Unable to create queue1 \n")
    queue2 = Gst.ElementFactory.make("queue", "nvtee-que2")
    #queue2 = make_element("queue", "queue2"+str(i))
    if not queue2:
        sys.stderr.write(" Unable to create queue2 \n")
    msgconv = Gst.ElementFactory.make("nvmsgconv", "nvmsg-converter")
    #msgconv = make_element("nvmsgconv", i)
    if not msgconv:
        sys.stderr.write(" Unable to create msgconv \n")
    msgbroker = Gst.ElementFactory.make("nvmsgbroker", "nvmsg-broker")
    #msgbroker = make_element("nvmsgbroker", i)
    if not msgbroker:
        sys.stderr.write(" Unable to create msgbroker \n")
    global MSCONV_CONFIG_FILE
    msgconv.set_property('config', MSCONV_CONFIG_FILE)
    global schema_type
    msgconv.set_property('payload-type', schema_type)
    global proto_lib
    msgbroker.set_property('proto-lib', proto_lib)
    global conn_str
    msgbroker.set_property('conn-str', conn_str)
    # if cfg_file is not None:
    #     msgbroker.set_property('config', cfg_file)
    # if topic is not None:
    #     msgbroker.set_property('topic', topic)
    msgbroker.set_property('sync', False)
    tee = Gst.ElementFactory.make("tee", "nvsink-tee")
    #tee = make_element("tee", i)
    if not tee:
        sys.stderr.write(" Unable to create tee \n")
    print("Adding elements to Pipeline \n")
    pipeline.add(q)
    pipeline.add(pgie)
    pipeline.add(tracker)
    pipeline.add(sgie1)
    pipeline.add(sgie2)
    pipeline.add(nvstreamdemux)
    pipeline.add(nvvidconvert_pre)
    pipeline.add(filter1_pre)
    pipeline.add(queue1)
    pipeline.add(queue2)
    pipeline.add(tee)
    pipeline.add(msgconv)
    pipeline.add(msgbroker)
    #streammux.link(pgie)
    streammux.link(q)
    q.link(pgie)
    # pgie.link(nvvidconv1)
    pgie.link(tracker)
    tracker.link(nvvidconvert_pre)
    nvvidconvert_pre.link(filter1_pre)
    filter1_pre.link(sgie1)
    sgie1.link(sgie2)
    sgie2.link(tee)
    queue1.link(msgconv)
    msgconv.link(msgbroker)
    queue2.link(nvstreamdemux)
            # Make the UDP sink
        port = "540"+str(i)
        updsink_port_num = int(port)
        #sink = Gst.ElementFactory.make("udpsink", "udpsink")
        sink = make_element("udpsink", i)
        if not sink:
            sys.stderr.write(" Unable to create udpsink")
        sink.set_property('host', '224.224.255.255')
        sink.set_property('port', updsink_port_num)
        sink.set_property('async', False)
        sink.set_property('sync', 0)
        #pipeline.add(sink)
        # creating queue
        queue = make_element("queue", i)
        pipeline.add(queue)
        # Add nvvidconv1 and filter1 to convert the frames to RGBA
        # which is easier to work with in Python.
        nvvidconv1 = make_element("nvvideoconvert", "nvvideoconvert"+str(i))
        if not nvvidconv1:
            sys.stderr.write(" Unable to create nvvidconv1 \n")
        print("Creating nvvidconv \n ")
        #nvvidconv = Gst.ElementFactory.make("nvvideoconvert", "convertor")
        nvvidconv = make_element("nvvideoconvert", "nvvidconv"+str(i))
        if not nvvidconv:
            sys.stderr.write(" Unable to create nvvidconv \n")
        #nvvidconv_postosd = Gst.ElementFactory.make("nvvideoconvert", "convertor_postosd")
        nvvidconv_postosd = make_element("nvvideoconvert", "nvvidconv_postosd"+str(i))
        if not nvvidconv_postosd:
            sys.stderr.write(" Unable to create nvvidconv_postosd \n")
        print("Creating nvosd \n ")
        #nvosd = Gst.ElementFactory.make("nvdsosd", "onscreendisplay")
        nvosd = make_element("nvdsosd", "nvdsosd" + str(i))
        if not nvosd:
            sys.stderr.write(" Unable to create nvosd \n")
        nvosd.set_property("process-mode", OSD_PROCESS_MODE)
        #nvosd.set_property("display-text", OSD_DISPLAY_TEXT)
        nvosd.set_property("display-text", 0)
        nvosd.set_property("display-bbox", 0)
        # connect nvstreamdemux -> queue
        padname = "src_%u" % i
        demuxsrcpad = nvstreamdemux.get_request_pad(padname)
        if not demuxsrcpad:
            sys.stderr.write("Unable to create demux src pad \n")
        queuesinkpad = queue.get_static_pad("sink")
        if not queuesinkpad:
            sys.stderr.write("Unable to create queue sink pad \n")
        demuxsrcpad.link(queuesinkpad)
        print("Creating filter1 \n ")
        caps1 = Gst.Caps.from_string("video/x-raw(memory:NVMM), format=RGBA")
        filter1 = make_element("capsfilter", "filter1"+str(i))
        if not filter1:
            sys.stderr.write(" Unable to get the caps filter1 \n")
        filter1.set_property("caps", caps1)
        # Create a caps filter
        #caps = Gst.ElementFactory.make("capsfilter", "filter")
        caps = make_element("capsfilter", "caps"+str(i))
        caps.set_property("caps", Gst.Caps.from_string("video/x-raw(memory:NVMM), format=I420"))
        # Make the encoder
        if codec == "H264":
            #encoder = Gst.ElementFactory.make("nvv4l2h264enc", "encoder")
            encoder = make_element("nvv4l2h264enc", i)
            print("Creating H264 Encoder")
        elif codec == "H265":
            #encoder = Gst.ElementFactory.make("nvv4l2h265enc", "encoder")
            encoder = make_element("nvv4l2h265enc", i)
            print("Creating H265 Encoder")
        if not encoder:
            sys.stderr.write(" Unable to create encoder")
        encoder.set_property('bitrate', bitrate)
        if is_aarch64():
            encoder.set_property('preset-level', 1)
            encoder.set_property('insert-sps-pps', 1)
            #encoder.set_property('bufapi-version', 1)
        # Make the payload-encode video into RTP packets
        if codec == "H264":
            #rtppay = Gst.ElementFactory.make("rtph264pay", "rtppay")
            rtppay = make_element("rtph264pay", i)
            print("Creating H264 rtppay")
            #rtppay = Gst.ElementFactory.make("rtph265pay", "rtppay")
            rtppay = make_element("rtph265pay", i)
            print("Creating H265 rtppay")
        if not rtppay:
            sys.stderr.write(" Unable to create rtppay")
        pipeline.add(nvvidconv)
        pipeline.add(filter1)
        pipeline.add(nvvidconv1)
        pipeline.add(nvosd)
        pipeline.add(nvvidconv_postosd)
        pipeline.add(caps)
        pipeline.add(encoder)
        pipeline.add(rtppay)
        pipeline.add(sink)
        # linking elements
        queue.link(nvvidconv1)
        nvvidconv1.link(nvosd)
        # queue.link(nvvidconv1)
        # nvvidconv1.link(filter1)
        # filter1.link(nvvidconv)
        # nvvidconv.link(nvosd)
        nvosd.link(nvvidconv_postosd)
        nvvidconv_postosd.link(caps)
        caps.link(encoder)
        encoder.link(rtppay)
        rtppay.link(sink)
        sink.set_property("qos", 0)
        # Start streaming
        rtsp_port = "855"+str(i)
        rtsp_port_num = int(rtsp_port)
        server = GstRtspServer.RTSPServer.new()
        server.props.service = "%d" % rtsp_port_num
        server.attach(None)
        factory = GstRtspServer.RTSPMediaFactory.new()
        factory.set_launch( "( udpsrc name=pay0 port=%d buffer-size=524288 caps=\"application/x-rtp, media=video, clock-rate=90000, encoding-name=(string)%s, payload=96 \" )" % (updsink_port_num, codec))
        factory.set_shared(True)
        fac = "/ds-test" + str(i)
        server.get_mount_points().add_factory(fac, factory)
        print("\n *** DeepStream: Launched RTSP Streaming at rtsp://localhost:%d/%s ***\n\n" % (rtsp_port_num,str(fac)))
    sink_pad = queue1.get_static_pad("sink")
    tee_msg_pad = tee.get_request_pad('src_%u')
    tee_render_pad = tee.get_request_pad("src_%u")
    if not tee_msg_pad or not tee_render_pad:
        sys.stderr.write("Unable to get request pads\n")
    tee_msg_pad.link(sink_pad)
    sink_pad = queue2.get_static_pad("sink")
    tee_render_pad.link(sink_pad)
    print("Linking elements in the Pipeline \n")
    # create an event loop and feed gstreamer bus mesages to it
    loop = GLib.MainLoop()
    bus = pipeline.get_bus()
    bus.add_signal_watch()
    bus.connect("message", bus_call, loop)
    # nvosd_sink_pad = nvosd.get_static_pad("src")
    nvosd_sink_pad = sgie2.get_static_pad("src")
    if not nvosd_sink_pad:
        sys.stderr.write(" Unable to get sink pad \n")
    else:
        nvosd_sink_pad.add_probe(Gst.PadProbeType.BUFFER, osd_sink_pad_buffer_probe, 0)
        # perf callback function to print fps every 5 sec
        GLib.timeout_add(4000, perf_data.perf_print_callback)
    print("Starting pipeline \n")
    # start play back and listed to events
    pipeline.set_state(Gst.State.PLAYING)
    try:
        loop.run()
    except:
        pass
    # cleanup
    print("Exiting app\n")
    pyds.unset_callback_funcs()
    pipeline.set_state(Gst.State.NULL)
I cannot run your code in my env. But I tested this with the demo app: deepstream-app. It’s works fine. You can use the deepstream-app test it in your env and check if there is the same problem.
1.Modify the samples\configs\deepstream-app\source30_1080p_dec_infer-resnet_tiled_display_int8.txt config file.
Disable the [tiled-display]
Enable 3 [source<i>] tag with your 3 source
Enable 3 [sink<i>] tag with rtsp mode, like:
2.run: deepstream-app -c source30_1080p_dec_infer-resnet_tiled_display_int8.txt
I cannot run your app in my env. Could you narrow down the code and delete irrelevant dependencies such as common_functions? You can also provide us your stream source.
Also, you can put the file below in the path below and run it with deepstream-app -c source_demux_3_source_sink.txt
/opt/nvidia/deepstream/deepstream/samples/configs/deepstream-app/
source_demux_3_source_sink.txt (5.1 KB)
You can check the out1.mp4, out2.mp4, out3.mp4. The bbox is separate.
You can remove common_functions import. Not being used anywhere in the code.
But we didn’t have your config file, stream source, trained model, etc…
Could you use our demo to reproduce your problems?
And you can just run the cli that I attached to find out if there has problems in your env.
Also you can give us all your config files, model, stream source. If we can reproduce the problem in our env, we can anylize the problem faster.
@yuweiw I figured out what is causing the issue.
Referring back to this post:
Adding nvvideoconvert plugin before SGIE is causing the issue where all detections are drawn in all streams.
I compared my old code where I don’t have the nvvideoconvert plugin before SGIE so I added it and the issue appeared.
Below what I had:
  streammux.link(q)
  q.link(pgie)
  pgie.link(tracker)
  tracker.link(sgie1)
  sgie1.link(sgie2)
  sgie2.link(nvstreamdemux)
I added the following:
  if not filter1_pre:
streammux.link(q)
q.link(pgie)
pgie.link(tracker)
sgie1.link(sgie2)
Am I adding the nvvideoconvert plugin incorretly?
Could you try to add the nvvideoconvert to each source before the streammux?
How would I accomplish that? I get the following error
    if not streammux:
            is_live = True
        if not source_bin:
        nvvidconvert_pre = make_element("nvvideoconvert", i)
        filter1_pre  = make_element("capsfilter", i)
        if not filter1_pre:
        source_bin.link(nvvidconvert_pre)
        if not sinkpad:
        if not srcpad:
It’s a little complicated when link each nvvideoconvert to streammux.
We’ll repo your problem in our env and anylize it when add nvideoconvert between pgie and sgie. Could you just attach all your code that can run directly? Thanks
Hi @user133662 , I mean the whole project that can run in my environment. It contains the code, stream source, config files and models. Or you can repo this problem with our demo config files, streams and models. If you don’t want to make it public, just message me. Thanks
I will message you
Thanks. I can repro the problems when using our python deepstream-test2 config file and models and your code. We will analyze it as soon as possible.
Any updates?
Yes. We are analyzing the root cause of the problem, which may take some time.
Hi @yuweiw Any updates on this topic?
We are analyzing and verifying this issue. It will be fixed in the future version which may need a long time. Could you try to add the nvvideconvert before nvstreammux first and check whether it’s OK?
I am trying to run multiple streams and keep getting those errors
