Hello Qi,
Many thanks for your inquiry on the Mellanox Community.
Based on the information provided, this question should be redirected to the SoftRoCE community as Mellanox only handles SoftRoCE related issues regarding their adapters.
The link to the SoftROCE Community is → https://github.com/SoftRoCE/rxe-dev/wiki/rxe-dev:-Home
But for now, I will assist you as much as I can.
In my lab, I had no issue configuring SoftRoCE on our Mellanox adapters. We disabled h/w RoCE for this test.
In your output, it looks like you did not created the SoftROCE device for your NIC, as the SoftROCE device should have the naming, rxe
Example output:
rxe_cfg -l
Name Link Driver Speed NMTU IPv4_addr RDEV RMTU
eno1 yes igb
ens1 yes mlx5_core rxe0 4096 (5)
SoftROCE device in our setup is rxe1 (Intel) and rxe0 (Intel)
Make sure you create your SoftROCE device first. Example output:
rxe_cfg add eno1
rxe_cfg -l
eno1 yes igb rxe1 1024 (3)
Then you can do the ib_send_bw test on the SoftROCE device. Example output:
Send BW Test
Dual-port : OFF Device : rxe0
Number of qps : 1 Transport type : IB
Connection type : RC Using SRQ : OFF
RX depth : 512
CQ Moderation : 100
Mtu : 4096[B]
Link type : Ethernet
GID index : 1
Max inline data : 0[B]
rdma_cm QPs : OFF
Data ex. method : Ethernet
local address: LID 0000 QPN 0x0011 PSN 0x33a36b
GID: 00:00:00:00:00:00:00:00:00:00:255:255:192:168:01:10
remote address: LID 0000 QPN 0x0011 PSN 0x8d44b1
GID: 00:00:00:00:00:00:00:00:00:00:255:255:192:168:01:25
#bytes #iterations BW peak[Gb/sec] BW average[Gb/sec] MsgRate[Mpps]
Conflicting CPU frequency values detected: 2401.069000 != 1535.646000. CPU Frequency is not max.
2 1000 0.000000 0.002896 0.180997
Conflicting CPU frequency values detected: 2400.899000 != 2318.806000. CPU Frequency is not max.
4 1000 0.000000 0.006505 0.203270
Conflicting CPU frequency values detected: 2400.977000 != 2331.040000. CPU Frequency is not max.
Many thanks,
~Mellanox Technical Support
