Can the GPIO on Orin Nano output a 30kHz square wave signal?
Thanks for visiting the NVIDIA Developer forums.
Your topic will be best served in the Jetson category, I have moved this post for better visibility.
Cheers,
Tom
Generating a square wave on a GPIO through appropriate SW routines should be possible. You will need to test this out and see if it meets your application requirements. Please refer to previus forum topic generate 40kHz squarewave signal - Jetson & Embedded Systems / Jetson Nano - NVIDIA Developer Forums
