I implemented your suggestion. But samething still wrong. No display and no file save.
Create display sink
sink0 = Gst.ElementFactory.make("nveglglessink", "nvvideo-renderer")
sink0.set_property("qos",0)
sink0.set_property("sync",1)
pipeline.add(sink0)
# Create file sink
sink1 = Gst.ElementFactory.make("filesink", "nvvideo-renderer1")
sink1.set_property('location', output_file)
sink1.set_property("sync",1)
pipeline.add(sink1)
Link elements:
print("Linking elements in the Pipeline \n")
streammux.link(pgie)
pgie.link(tracker)
tracker.link(nvanalytics)
nvanalytics.link(tiler)
tiler.link(nvvidconv)
nvvidconv.link(nvosd)
nvosd.link(nvvidconv2)
nvvidconv2.link(encoder)
encoder.link(parser1)
parser1.link(mux)
mux.link(sink0)
sink0.link(sink1)
#Here is the full Python code
nvdsanalytics.txt (22.7 KB)
#Below is console result:
python3 nvdsanalytics_peoplenet_opencv.py file:///home/eduardo/Devel/Video_dataset/02_0164.mp4
Creating Pipeline
Creating streamux
Creating source_bin 0
Creating source bin
source-bin-00
Creating Pgie
Creating nvtracker
Creating nvdsanalytics
Unknown value ‘loosue’ in for key ‘mode’ using ‘loose’
Creating tiler
Creating nvvidconv
Creating nvosd
Creating nvvidconv
Creating nvv4l2h264enc
Creating qtmux
Creating h264parse
Creating FileSink
Adding elements to Pipeline
Now playing…
1 : file:///home/eduardo/Devel/Video_dataset/02_0164.mp4
Starting pipeline
libEGL warning: DRI3: Screen seems not DRI3 capable
libEGL warning: DRI2: failed to authenticate
gstnvtracker: Loading low-level lib at /opt/nvidia/deepstream/deepstream/lib/libnvds_nvmultiobjecttracker.so
[NvMultiObjectTracker] Initialized
0:00:04.725713454 32307 0x563de69cf780 INFO nvinfer gstnvinfer.cpp:682:gst_nvinfer_logger: NvDsInferContext[UID 1]: Info from NvDsInferContextImpl::deserializeEngineAndBackend() <nvdsinfer_context_impl.cpp:2095> [UID = 1]: deserialized trt engine from :/home/eduardo/Downloads/deepstream_tao_apps/models/peoplenet/resnet34_peoplenet_int8.onnx_b1_gpu0_int8.engine
WARNING: [TRT]: The getMaxBatchSize() function should not be used with an engine built from a network created with NetworkDefinitionCreationFlag::kEXPLICIT_BATCH flag. This function will always return 1.
INFO: …/nvdsinfer/nvdsinfer_model_builder.cpp:612 [Implicit Engine Info]: layers num: 3
0 INPUT kFLOAT input_1:0 3x544x960
1 OUTPUT kFLOAT output_cov/Sigmoid:0 3x34x60
2 OUTPUT kFLOAT output_bbox/BiasAdd:0 12x34x60
0:00:04.848379607 32307 0x563de69cf780 INFO nvinfer gstnvinfer.cpp:682:gst_nvinfer_logger: NvDsInferContext[UID 1]: Info from NvDsInferContextImpl::generateBackendContext() <nvdsinfer_context_impl.cpp:2198> [UID = 1]: Use deserialized engine model: /home/eduardo/Downloads/deepstream_tao_apps/models/peoplenet/resnet34_peoplenet_int8.onnx_b1_gpu0_int8.engine
0:00:04.852607718 32307 0x563de69cf780 INFO nvinfer gstnvinfer_impl.cpp:343:notifyLoadModelStatus: [UID 1]: Load new model:/home/eduardo/Downloads/deepstream_tao_apps/configs/nvinfer/peoplenet_tao/config_infer_primary_peoplenet.txt sucessfully
Decodebin child added: source
Decodebin child added: decodebin0
Decodebin child added: qtdemux0
Decodebin child added: multiqueue0
Decodebin child added: h264parse0
Decodebin child added: capsfilter0
Decodebin child added: nvv4l2decoder0
In cb_newpad
gstname= video/x-raw
features= <Gst.CapsFeatures object at 0x7a3630ba4580 (GstCapsFeatures at 0x7a351430f540)>
**PERF: {‘stream0’: 0.0}
Objs in ROI: {‘RF’: 0}
Linecrossing Cumulative: {‘Exit’: 0, ‘Entry’: 0}
Linecrossing Current Frame: {‘Exit’: 0, ‘Entry’: 0}
Frame Number= 0 stream id= 0 Number of Objects= 0 PERSON_count= 0 BAG_count= 0 FACE_count= 0
Frame Number= 1 stream id= 0 Number of Objects= 0 PERSON_count= 0 BAG_count= 0 FACE_count= 0
Frame Number= 2 stream id= 0 Number of Objects= 0 PERSON_count= 0 BAG_count= 0 FACE_count= 0
Object 5 roi status: [‘RF’]
Object 3 roi status: [‘RF’]
Object 7 roi status: [‘RF’]
Objs in ROI: {‘RF’: 3}
Frame Number= 3 stream id= 0 Number of Objects= 9 PERSON_count= 6 BAG_count= 0 FACE_count= 3
Frame Number= 4 stream id= 0 Number of Objects= 10 PERSON_count= 7 BAG_count= 0 FACE_count= 3
Object 26 moving in direction: DIR:North
Linecrossing Cumulative: {‘Exit’: 4, ‘Entry’: 2}
Frame Number= 360 stream id= 0 Number of Objects= 12 PERSON_count= 10 BAG_count= 0 FACE_count= 2
nvstreammux: Successfully handled EOS for source_id=0
**PERF: {‘stream0’: 76.34}
