My Jetson nano with MCP2515 has already sent data with my other devices, and i write a .py to use it, showing as followed
import os
import time
import can
os.system('sudo ip link set can0 type can bitrate 500000') # can0500K
os.system('sudo ifconfig can0 up') # can0 up
can0 = can.interface.Bus(channel = 'can0', bustype = 'socketcan_ctypes')# socketcan_native
# msg = can.Message(arbitration_id=0x601, data=[0x2F, 00, 20, 00, 01, 00, 00, 00])
# can0.send(msg)
DATA_LIST = [
[0x01, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00],
[0x02, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00]
for data in DATA_LIST:
msg = can.Message(arbitration_id=0x601, data=data)
can0.send(msg)
time.sleep(0.1)
os.system('sudo ifconfig can0 down')
But my device can only receive 1 data, and i don’t know why and how to deal with?
Any useful suggestions? Thanks a lot!
Hi 1030789164,
Are you using the devkit or custom board for Jetson Nano?
1030789164:
my device
Do you mean the “Jetson Nano” or your CAN device?
Is there any error showing in dmesg?
Hi KevinFFF
I’m using the Jetson NANO developer kit B01, Jetpack 4.6.1;
my device is a USB-CAN module, the left part of the picture I showed is the result;
you can see I only can receive one message; but my python code has two msgs in DATA_LIST;
I don’t know what’s the problem.
So could you give me some guide, Thank you~!
Hello KevinFFF
I update my python code, add the receive function
import os
import can
# can0 = can.interface.Bus(channel = 'can0', bustype = 'socketcan_ctypes')# socketcan_native
def send_message(bus, msg):
try:
bus.send(msg)
print(f"Sent: {msg}")
except can.CanError as e:
print(f"Error sending message: {e}")
def receive_messages(bus):
try:
while True:
msg = bus.recv(1.0)
if msg is not None:
print(f"Received: {msg}")
except KeyboardInterrupt:
pass
if __name__ == '__main__':
try:
msg = can.Message(arbitration_id=0x123, data=[0x11, 0x22, 0x33, 0x44])
msg1 = can.Message(arbitration_id=0x123, data=[0x55, 0x66, 0x77, 0x88])
send_message(can0, msg)
send_message(can0, msg1)
receive_messages(can0)
print(f"Error accessing CAN bus: {e}")
finally:
I find something new, when I run this .py above, my PC(USB2CAN, communicate with my NANO B01 kit) get 1 msg
And I let my PC send 1 msg (this case is 2F) to my NANO
I get the second msg!!
So I want to know if CAN in NANO must send 1 msg and receive 1 msg; then send 1, receive 1, send, receive…
Hope for your reply~! Thank you!
1030789164:
I don’t think so.
Could you use cangen can0 from your host to check if there’s similar behavior?
the loopback on mode
I check some blogs, maybe the reason is can buffer space? or the acknowledge/request mode?
Do you have some experience about debug the CAN-bus?
Or some advice about the .py code, thanks~!
How do you get the “write: No buffer space available ” issue?
Please share the result of the following command on your board.
$ sudo ip -d -s link show can0
