I have graphic card GT710 and I have installed driver 440. but still, I am getting an error when I am running the command nvidia-smi that GPU is not supported.
| NVIDIA-SMI 440.59 Driver Version: 440.59 CUDA Version: 10.2 |
| 0 GeForce GT 710 Off | 00000000:01:00.0 N/A | N/A |
| 43% 47C P0 N/A / N/A | 734MiB / 1998MiB | N/A Default |
| Processes: GPU Memory |
| GPU PID Type Process name Usage |
| 0 Not Supported |
Is the GPU working aside from that? I think “Not Supported” there is just referring to the process list and not the GPU itself.
No, I don’t think so that GPU is working aside from that. Also If the GPU is not supporting the processes then how my threads would work.
And if I am running any program related to GPU which uses GPU or which needs the GPU process then it gives me the error.
RuntimeError: CUDA error: no kernel image is available for execution on the device
RuntimeError: /job:localhost/replica:0/task:0/device:GPU:0 unknown device.
