This topic is very similar to this one, however the affected file is different to the one which the proposed solution suggests modifying, causing me to be reluctant to modify other core files without certainty.
My issue is as follows: I can add other objects to the simulation through the code below, but whereas the only modification was to change the USD model from one (the tree in comments) to another (the rock in the line beneath the tree’s), said modification prevents the simulation from launching (see error message).
tree_cfg = RigidObjectCfg(
prim_path = f"/World/envs/env_.*/Obstacle_{ob_idx}",
spawn = sim_utils.UsdFileCfg(
#usd_path=f"/home/lunar5/robbinshel/robbins_docs/Tree3.usd",
usd_path=f"/home/lunar5/robbinshel/robbins_docs/Rock1.usd",
rigid_props=schemas.RigidBodyPropertiesCfg(kinematic_enabled = True),
#mass_props=schemas.MassPropertiesCfg(mass=1.0),
collision_props=schemas.CollisionPropertiesCfg(),
init_state=RigidObjectCfg.InitialStateCfg(pos=(current_obstacle[0], current_obstacle[1], 0)),
File "/home/lunar5/robbinshel/isaaclab_heloisa/source/standalone/workflows/sb3/train.py", line 139, in <module>
main()
File "/home/lunar5/robbinshel/isaaclab_heloisa/source/standalone/workflows/sb3/train.py", line 92, in main
env = gym.make(args_cli.task, cfg=env_cfg, render_mode="rgb_array" if args_cli.video else None)
File "/home/lunar5/anaconda3/envs/my_env/lib/python3.10/site-packages/gymnasium/envs/registration.py", line 802, in make
env = env_creator(**env_spec_kwargs)
File "/home/lunar5/robbinshel/isaaclab_heloisa/source/extensions/omni.isaac.lab_tasks/omni/isaac/lab_tasks/direct/adam_rover/adam_rover_env_validation.py", line 236, in __init__
super().__init__(cfg, render_mode, **kwargs)
File "/home/lunar5/robbinshel/isaaclab_heloisa/source/extensions/omni.isaac.lab/omni/isaac/lab/envs/direct_rl_env.py", line 102, in __init__
self._setup_scene()
File "/home/lunar5/robbinshel/isaaclab_heloisa/source/extensions/omni.isaac.lab_tasks/omni/isaac/lab_tasks/direct/adam_rover/adam_rover_env_validation.py", line 295, in _setup_scene
self.obstacles = [RigidObject(obs_cfg) for obs_cfg in self.cfg.obstacles_cfg]
File "/home/lunar5/robbinshel/isaaclab_heloisa/source/extensions/omni.isaac.lab_tasks/omni/isaac/lab_tasks/direct/adam_rover/adam_rover_env_validation.py", line 295, in <listcomp>
File "/home/lunar5/robbinshel/isaaclab_heloisa/source/extensions/omni.isaac.lab/omni/isaac/lab/assets/rigid_object/rigid_object.py", line 58, in __init__
super().__init__(cfg)
File "/home/lunar5/robbinshel/isaaclab_heloisa/source/extensions/omni.isaac.lab/omni/isaac/lab/assets/asset_base.py", line 75, in __init__
self.cfg.spawn.func(
File "/home/lunar5/robbinshel/isaaclab_heloisa/source/extensions/omni.isaac.lab/omni/isaac/lab/sim/utils.py", line 275, in wrapper
cloner.clone(prim_paths[0], prim_paths[1:], replicate_physics=False, copy_from_source=cfg.copy_from_source)
File "/home/lunar5/.local/share/ov/pkg/isaac-sim-4.0.0/exts/omni.isaac.cloner/omni/isaac/cloner/cloner.py", line 214, in clone
xform_op_rot.Set(current_orientation)
pxr.Tf.ErrorException:
Error in 'pxrInternal_v0_22__pxrReserved__::UsdStage::_SetValueImpl' at line 6189 in file /buildAgent/work/ac88d7d902b57417/USD/pxr/usd/usd/stage.cpp : 'Type mismatch for </World/envs/env_0/Obstacle_0.xformOp:orient>: expected 'GfQuatf', got 'GfQuatd''
