Cannot add own usd object to scene in python
I want to add own usd object to the scene in Isaac sim with python. Here is sample of the code I use:
add_reference_to_stage(usd_path=path, prim_path=prim_path)
prim = XFormPrim(
    prim_path=prim_path, name=f"object_{self._object_count}",
    position=np.array([40, 0, 40])
self.get_world().scene.add(prim)
Where path is for example: "/home/user/my_object.usd" and prim_path: "/World/objects/object".
if path is a file in Isaac sim assets /Isaac/Props/Flip_Stack/screw_95_physics.usd it works, but if I try to load my own object, following error shows up:
[Error] [asyncio] [/home/filip/.local/share/ov/pkg/isaac_sim-2021.2.0/kit/python/lib/python3.7/asyncio/base_events.py:1619] Task exception was never retrieved
future: <Task finished coro=<BaseSampleExtension._on_load_world.<locals>._on_load_world_async() done, defined at /home/filip/.local/share/ov/pkg/isaac_sim-2021.2.0/exts/omni.isaac.examples/omni/isaac/examples/base_sample/base_sample_extension.py:161> exception=ErrorException(Error in 'pxrInternal_v0_20__pxrReserved__::UsdStage::_SetValueImpl' at line 6043 in file /buildAgent/work/ca6c508eae419cf8/USD/pxr/usd/usd/stage.cpp : 'Type mismatch for </World/objects/object_0.xformOp:orient>: expected 'GfQuatf', got 'GfQuatd'')>
  File "/home/filip/.local/share/ov/pkg/isaac_sim-2021.2.0/exts/omni.isaac.examples/omni/isaac/examples/base_sample/base_sample_extension.py", line 162, in _on_load_world_async
    await self._sample.load_world_async()
  File "/home/filip/.local/share/ov/pkg/isaac_sim-2021.2.0/exts/omni.isaac.examples/omni/isaac/examples/base_sample/base_sample.py", line 44, in load_world_async
    self.setup_scene()
  File "/home/filip/.local/share/ov/pkg/isaac_sim-2021.2.0/exts/omni.isaac.examples/omni/isaac/examples/user_examples/master_thesis.py", line 55, in setup_scene
    self.add_object()
  File "/home/filip/.local/share/ov/pkg/isaac_sim-2021.2.0/exts/omni.isaac.examples/omni/isaac/examples/user_examples/master_thesis.py", line 79, in add_object
  File "/home/filip/.local/share/ov/pkg/isaac_sim-2021.2.0/exts/omni.isaac.core/omni/isaac/core/prims/xform_prim.py", line 82, in __init__
    XFormPrim._set_xform_properties(self)
  File "/home/filip/.local/share/ov/pkg/isaac_sim-2021.2.0/exts/omni.isaac.core/omni/isaac/core/prims/xform_prim.py", line 160, in _set_xform_properties
    XFormPrim.set_world_pose(self, position=current_position, orientation=current_orientation)
  File "/home/filip/.local/share/ov/pkg/isaac_sim-2021.2.0/exts/omni.isaac.core/omni/isaac/core/prims/xform_prim.py", line 329, in set_world_pose
    self, translation=np.array(calculated_translation), orientation=gf_quatd_to_np_array(calculated_orientation)
  File "/home/filip/.local/share/ov/pkg/isaac_sim-2021.2.0/exts/omni.isaac.core/omni/isaac/core/prims/xform_prim.py", line 389, in set_local_pose
    xform_op.Set(rotq)
pxr.Tf.ErrorException:
Can somebody help me with this error?
Thank you.
lego_4x2_red_isaac.usd (327.5 KB) - my .usd file which doesn’t work.
screw_95_physics.usd (20.1 KB) - file from Isaac assets which works.
Thanks for reporting this issue!, we’re working on a proper for our bugfix release next month.
For now, if you can make the following change in
it should allow you to move forward.
Okay, thank you so much for such a quick answer.
EDIT: The text below describes error with Physics context, but now I found, if I change prim path of method _create_new_physics_scene() to "/World/physicsScene" (change capital P to small p) it works. Unfortunatelly, I don’t know why :D
It looks like it loaded the model to the scene, but after I load the model I want to start a simulation.
With /Isaac/Props/Flip_Stack/screw_95_physics.usd it works, but with my .usd file I get following error:
future: <Task finished coro=<BaseSampleExtension._on_load_world.<locals>._on_load_world_async() done, defined at /home/filip/.local/share/ov/pkg/isaac_sim-2021.2.0/exts/omni.isaac.examples/omni/isaac/examples/base_sample/base_sample_extension.py:161> exception=Exception("The Physics Context's physics scene path is invalid, you need to reinit Physics Context")>
    self.setup_scene()
  File "/home/filip/.local/share/ov/pkg/isaac_sim-2021.2.0/exts/omni.isaac.examples/omni/isaac/examples/user_examples/master_thesis.py", line 53, in setup_scene
    self.add_object()
  File "/home/filip/.local/share/ov/pkg/isaac_sim-2021.2.0/exts/omni.isaac.examples/omni/isaac/examples/user_examples/master_thesis.py", line 77, in add_object
    self._world.step(render=False)
  File "/home/filip/.local/share/ov/pkg/isaac_sim-2021.2.0/exts/omni.isaac.core/omni/isaac/core/world/world.py", line 286, in step
    SimulationContext.step(self, render=render)
  File "/home/filip/.local/share/ov/pkg/isaac_sim-2021.2.0/exts/omni.isaac.core/omni/isaac/core/simulation_context/simulation_context.py", line 434, in step
    self._physics_context._step(current_time=self.current_time)
  File "/home/filip/.local/share/ov/pkg/isaac_sim-2021.2.0/exts/omni.isaac.core/omni/isaac/core/physics_context/physics_context.py", line 340, in _step
    self._physx_interface.update_simulation(elapsedStep=self.get_physics_dt(), currentTime=current_time)
  File "/home/filip/.local/share/ov/pkg/isaac_sim-2021.2.0/exts/omni.isaac.core/omni/isaac/core/physics_context/physics_context.py", line 134, in get_physics_dt
    raise Exception("The Physics Context's physics scene path is invalid, you need to reinit Physics Context")
Exception: The Physics Context's physics scene path is invalid, you need to reinit Physics Context
here is the code I use to load and simulate objects physics (it’s based on Hello world example)
    def setup_scene(self):
        world_usd_file = "/path/to/scene.usd"
        omni.usd.get_context().open_stage(world_usd_file, None)
        self._world = self.get_world()
        self._world.reset()
        self._scene = self._world.scene
        self._world.get_physics_context()._create_new_physics_scene("/World/PhysicsScene")
        self._world.reset()
        self._world.clear_instance()
        spawn_count = 200
        for i in range(spawn_count):
            self.add_object()
        # stabilize objects after simulation
        for i in range(20):
        return
    def add_object(self):
        path = "/path/to/object.usd"
        prim_path = f"/World/objects/object_{self._object_count}"
        prim = XFormPrim(
        self._objects.append(
            self._scene.add(prim)
        self._object_count += 1
        # # simulate falling of an object
        for i in range(5):
