I am currently using a standalone python script with the Isaac Lab conda environment. I find it hard to re-simulate everything from scratch for every change I do with it. It takes so much time to load the app with AppLauncher and importing the libraries, only then you can see the changes you applied. Is it possible to use the conda environment for Isaac Lab in the script editor? I am using the Isaac Lab API for setting up a scene for reinforcement learning task with a custom robot arm. Here’s my code for the current scene:
import omni.isaac.lab.sim as sim_utils
from omni.isaac.lab.assets import RigidObject, RigidObjectCfg
from pxr import UsdGeom, Gf
import omni.usd
def create_table(size):
""" Creates a table in the scene. """
# add size argument
if args_cli.size:
size=args_cli.size
# configure the table object
cube_cfg = RigidObjectCfg(
prim_path="/World/Table",
# spawn a cube with rigid, mass, collision, and visual properties
spawn=sim_utils.CuboidCfg(
size=(size,size,size),
rigid_props=sim_utils.RigidBodyPropertiesCfg(),
mass_props=sim_utils.MassPropertiesCfg(mass=10.0),
collision_props=sim_utils.CollisionPropertiesCfg(),
visual_material=sim_utils.PreviewSurfaceCfg(diffuse_color=(0.5, 0.5, 0.5)),
# create the table object then return scene information
table = RigidObject(cfg=cube_cfg)
scene_entities = {"table": table}
return scene_entities
def create_glass():
""" Creates a glass in the scene. """
# configure the glass object
glass_cfg = RigidObjectCfg(
prim_path="/World/Glass",
size=(0.1, 0.1, 0.1),
mass_props=sim_utils.MassPropertiesCfg(mass=0.02),
visual_material=None,
# create the glass object then return scene information
glass = RigidObject(cfg=glass_cfg)
scene_entities = {"glass": glass}
def load_reference_prim(usd_file_path, prim_path, translation=(0.0, 0.0, 0.0)):
"""Loads a specific prim and its children from a USD file using Isaac Lab."""
prim = stage.DefinePrim(prim_path, "Xform")
prim.GetReferences().AddReference(usd_file_path)
xformable = UsdGeom.Xformable(prim)
for name in prim.GetPropertyNames():
if name == "xformOp:transform":
xformable.RemoveProperty(name)
if "xformOp:translate" in prim.GetPropertyNames():
xform_op_tranlsate = UsdGeom.XformOp(prim.GetAttribute("xformOp:translate"))
else:
xform_op_tranlsate = xformable.AddXformOp(UsdGeom.XformOp.TypeTranslate, UsdGeom.XformOp.PrecisionDouble, "")
xformable.SetXformOpOrder([xform_op_tranlsate])
xform_op_tranlsate.Set(Gf.Vec3d([translation[0], translation[1], translation[2]]))
def design_scene():
""" Initializes the scene. """
SIZE = 1.0
# ground plane
cfg = sim_utils.GroundPlaneCfg()
cfg.func("/World/defaultGroundPlane", cfg)
# lights
cfg = sim_utils.DomeLightCfg(intensity=2000.0, color=(0.8, 0.8, 0.8))
cfg.func("/World/Light", cfg)
# initialize scene entities
scene_entities = {}
# create a table in the scene
table_entity = create_table(size=SIZE)
glass_entity = create_glass()
# TODO: You can load other entities in the scenes here.
# load usd files
usd_file_path = os.path.join(cwd, "nabi/arctos.usd")
load_reference_prim(usd_file_path=usd_file_path,
prim_path="/World/arctos",
translation=(0.0, 0.0, SIZE))
# adding the table to the scene entities
scene_entities.update(table_entity)
scene_entities.update(glass_entity)
# TODO: You can update the scene entities with other entities here.
def run_simulator(sim: sim_utils.SimulationContext, entities: dict[str, RigidObject]):
""" Runs the simulator. """
# extract scene entities
table_object = entities["table"]
glass_object = entities["glass"]
# define simulation stepping
sim_dt = sim.get_physics_dt()
sim_time = 0.0
# simulate physics
while simulation_app.is_running():
table_object.write_data_to_sim()
glass_object.write_data_to_sim()
sim.step()
sim_time += sim_dt
table_object.update(sim_dt)
def main():
""" Main function. """
# load kit helper
sim_cfg = sim_utils.SimulationCfg(device=args_cli.device)
sim = sim_utils.SimulationContext(sim_cfg)
# set main camera
sim.set_camera_view(eye=[1.5, 0.0, 1.0], target=[0.0, 0.0, 0.0])
# design the scene
scene_entities = design_scene()
# play the simulator
sim.reset()
print("[INFO]: TO THE MOOON!!!")
# run the simulator
run_simulator(sim, scene_entities)
if __name__ == "__main__":
main()
simulation_app.close()
