[Isaac Lab] Remove Objects during simulation
Isaac Sim Version
4.2.0
4.1.0
[0] 4.0.0
2023.1.1
2023.1.0-hotfix.1
Other (please specify):
Isaac Lab Version (if applicable)
1.2
[0] 1.1
1.0
Operating System
Ubuntu 22.04
[0] Ubuntu 20.04
Windows 11
Windows 10
GPU Information
  • Model:
  • Driver Version:
Topic Description
Detailed Description
(Describe the issue in detail, including what you were trying to do, what you expected to happen, and what actually happened)
I am currently working on a bin picking task where I want to spawn multiple cubes inside a rectangular bin. However, when I spawn the cubes, they collide with each other and some of them end up outside the bin. I would like to remove the cubes that fall outside the bin during the simulation, I tried but I haven’t been able to find a way to do this yet. Is there a method for removing these cubes during simulation?
CODE
class BinPickingSceneCfg(InteractiveSceneCfg):
    def __init__(self,args,*other_args, **kwargs):
        super().__init__(*other_args, **kwargs)
        # ground plane
        self.ground = AssetBaseCfg(
            prim_path = "/World/defaultGroundPlane",
            spawn=sim_utils.GroundPlaneCfg(),
            init_state = AssetBaseCfg.InitialStateCfg(pos=(0.0,0.0,0.0)),
        # lights
        self.dome_light = AssetBaseCfg(
            prim_path = "/World/Light", spawn=sim_utils.DomeLightCfg(intensity=3000.0, color=(0.75,0.75,0.75))
        self.table = RigidObjectCfg(
            prim_path="{ENV_REGEX_NS}/Table",
            spawn=sim_utils.CuboidCfg(
                size=(1.0, 1.0, 0.4),
                rigid_props=sim_utils.RigidBodyPropertiesCfg(max_depenetration_velocity=1.0, disable_gravity=True,
                                                            kinematic_enabled=True),
                mass_props=sim_utils.MassPropertiesCfg(mass=1.0),
                collision_props=sim_utils.CollisionPropertiesCfg(collision_enabled=True),
                physics_material=sim_utils.RigidBodyMaterialCfg(),
                visual_material=sim_utils.PreviewSurfaceCfg(diffuse_color=(0.3, 0.3, 0.3)),
                # visual_material=sim_utils.PreviewSurfaceCfg(diffuse_color=(0.5, 0.0, 0.0),opacity=0.8),
            init_state=RigidObjectCfg.InitialStateCfg(pos=(0.5, 0.0, 0.5 * 0.4)),
        self.plate1 = RigidObjectCfg(
            prim_path="/World/plate1",
                size=(1.0, 0.35, 0.0000001),
                visual_material=sim_utils.PreviewSurfaceCfg(diffuse_color=(0.6, 0.35, 0.05)),
            init_state=RigidObjectCfg.InitialStateCfg(pos=(0.5, -0.025, 0.4000001)),
        self.plate2 = RigidObjectCfg(
            prim_path="/World/plate2",
                visual_material=sim_utils.PreviewSurfaceCfg(diffuse_color=(0.1, 0.3, 0.8)),
            init_state=RigidObjectCfg.InitialStateCfg(pos=(0.5, 0.325, 0.4000001)),
        self.camera = CameraCfg(
            # prim_path="/World/Objects/Camera",
            prim_path="/World/Camera",
            # update_period=0,
            height=args.camera_resolution_height,
            width=args.camera_resolution_width,
            data_types=["rgb", "distance_to_image_plane", "semantic_segmentation", "instance_id_segmentation_fast",
                        "instance_segmentation_fast"],
            spawn=sim_utils.PinholeCameraCfg(
                focal_length=15.0, focus_distance=400.0, horizontal_aperture=20.63, clipping_range=(0.1, 1.0e5),
                visible=True
            # w, x, y, z
            offset=CameraCfg.OffsetCfg(pos=(1.5, 0.0, 0.55), rot=(-0.5, 0.5, 0.5, -0.5), convention="ros")
        self.bin = RigidObjectCfg(
            prim_path = "/World/Bin",
            spawn = sim_utils.UsdFileCfg(usd_path=f"./assets/bin.usd",
                                        semantic_tags=[("class", "bin")],
                                        visual_material_path=None),
            init_state=RigidObjectCfg.InitialStateCfg(pos=(0.55, -0.3, 0.4)),
        self.create_cubes(num_cubes=50)
            # articulation
        if args.robot == "franka_panda":
            self.robot = FRANKA_PANDA_HIGH_PD_CFG.replace(prim_path="{ENV_REGEX_NS}/Robot")
        elif args.robot == "ur10":
            self.robot = UR10_CFG.replace(prim_path="{ENV_REGEX_NS}/Robot")
        elif args.robot == "kionva_gen3lite":
            self.robot = KINOVA_GEN3LITE_CFG.replace(prim_path="{ENV_REGEX_NS}/Robot")
        else:
            raise ValueError(f"Robot {args.robot} is not supported. Valid: franka_panda, ur10")
    def create_cubes(self, num_cubes):
        base_position = np.array([0.5, -0.3, 0.62])
        for i in range(num_cubes):
            position = base_position + np.array([np.random.uniform(-0.05, 0.05), np.random.uniform(-0.03, 0.03), (i//5)*np.random.uniform(0, 0.1)])
            cube_name = f"cube{i}"
            setattr(self, cube_name, RigidObjectCfg(
                prim_path=f"/World/Objects/Cube{i}",
                    size=(0.045, 0.045, 0.045),
                    rigid_props=sim_utils.RigidBodyPropertiesCfg(max_depenetration_velocity=1.0, disable_gravity=False),
                    mass_props=sim_utils.MassPropertiesCfg(mass=0.01),
                        collision_enabled=True,
                        # contact_offset=0.000001,
                        # rest_offset=0.0,
                    # physics_material=sim_utils.RigidBodyMaterialCfg(),
                        # static_friction=0.8,
                        # dynamic_friction=0.6,
                        restitution=0.000001
                    visual_material=sim_utils.PreviewSurfaceCfg(diffuse_color=(0.8, 0.3, 0.0)),
                # init_state=RigidObjectCfg.InitialStateCfg(pos=tuple(position)),
                    pos=tuple(position),
                    rot=(1.0, 0.0, 0.0, 0.0)
def run_simulator(sim: sim_utils.SimulationContext, scene: InteractiveScene):
    camera_target_position = [0.5,-0.35,0.4]
    camera_pos = [0.5,-0.15,0.6]
    camera_target_position= torch.tensor(camera_target_position,dtype=torch.float,device=sim.device).repeat((args.num_envs,1))
    camera_pos = torch.tensor(camera_pos,dtype=torch.float, device=sim.device).repeat((args.num_envs,1))
    camera.set_world_poses_from_view(camera_pos,camera_target_position)
    camera.reset()
    sim_dt = sim.get_physics_dt()
    bin_center = np.array([0.55,-0.3,0.4])
    bin_size = np.array([0.4,0.2,0.1])
    stability_counter = 0
    check_stability_after = 200
    print(dir(scene))
    while simulation_app.is_running():
        count += 1
        if count > check_stability_after:
            cubes_to_remove = []
            for i in range(50):
                cube = scene[cube_name]
                if cube is not None:
                    cube_pos = cube.data.body_state_w[0, 0, 0:3].cpu().numpy()
                    outside_bin = (
                        abs(cube_pos[0] - bin_center[0]) > bin_size[0] or
                        abs(cube_pos[1] - bin_center[1]) > bin_size[1]
                    if outside_bin:
                        cubes_to_remove.append(cube_name)
            print(len(cubes_to_remove))
            for cube_name in cubes_to_remove:
                prim_path = f"/World/Objects/Cube{cube_name[4:]}"
                # prim_utils.delete_prim(prim_path)
                stage = stage_utils.get_current_stage()
                cube_prim = stage.GetPrimAtPath(prim_path)
                if cube_prim:
                    try:
                        stage.RemovePrim(prim_path)
                        scene.update(sim_dt)
                    except Exception as e:
                        print(f"Error removing prim {prim_path}: {e}")
                del scene[cube_name]
Error Messages
(If applicable, copy and paste any error messages you received)
File “/home/airlab/Robot_team/IsaacLab1.1/source/catkin_binpicking/src/binpicking/src/bin_picking_class.py”, line 764, in
main()
File “/home/airlab/Robot_team/IsaacLab1.1/source/catkin_binpicking/src/binpicking/src/bin_picking_class.py”, line 760, in main
run_simulator(sim, scene)
File “/home/airlab/Robot_team/IsaacLab1.1/source/catkin_binpicking/src/binpicking/src/bin_picking_class.py”, line 437, in run_simulator
TypeError: ‘InteractiveScene’ object does not support item deletion
Screenshots or Videos
(If applicable, add screenshots or links to videos that demonstrate the issue)
