I write a simple example, but a force that cannot satisfy the force balance was read.
Describe the bug
I set a ground plane and two cube. The first cube has size as (1.0, 1.0, 1.0) and init position as (0,0,1.5). The second cube has size as (0.8, 0.8, 0.8) and init position as (0,0,3.0). Then I let the simulation run.
Finally, when they all landed, the force to first cube is wrong.
Code
from omni.isaac.lab.app import AppLauncher
app_launcher = AppLauncher()
simulation = app_launcher.app
import omni.isaac.lab.sim as sim_utils
from omni.isaac.lab.assets import AssetBaseCfg, RigidObjectCfg
from omni.isaac.lab.scene import InteractiveScene, InteractiveSceneCfg
from omni.isaac.lab.utils import configclass
from omni.isaac.lab.sensors import ContactSensorCfg
@configclass
class SceneConfig(InteractiveSceneCfg):
light = AssetBaseCfg(prim_path="/World/Light",
spawn=sim_utils.DomeLightCfg(intensity=3000.0, color=(0.75, 0.75, 0.75)))
ground = AssetBaseCfg(prim_path="/World/defaultGroundPlane",
spawn=sim_utils.GroundPlaneCfg())
cube1 = AssetBaseCfg(prim_path="/World/cube1",
init_state=AssetBaseCfg.InitialStateCfg(pos=(0.0, 0.0, 1.5)),
# init_state=AssetBaseCfg.InitialStateCfg(pos=(0.0, 0.0, 0.5)),
spawn=sim_utils.MeshCuboidCfg(size=(1.0, 1.0, 1.0),
physics_material=sim_utils.materials.RigidBodyMaterialCfg(),
activate_contact_sensors=True,
rigid_props=sim_utils.RigidBodyPropertiesCfg(disable_gravity=False,
max_depenetration_velocity=5.0),
collision_props=sim_utils.CollisionPropertiesCfg(),
visual_material=sim_utils.PreviewSurfaceCfg(diffuse_color=(0.0, 0.0, 0.0))))
cube2 = AssetBaseCfg(prim_path="/World/cube2",
init_state=AssetBaseCfg.InitialStateCfg(pos=(0.0, 0.0, 3.0)),
# init_state=AssetBaseCfg.InitialStateCfg(pos=(0.0, 0.0, 1.25)),
spawn=sim_utils.MeshCuboidCfg(size=(0.8, 0.8, 0.8),
visual_material=sim_utils.PreviewSurfaceCfg(diffuse_color=(0.75, 0.75, 0.75))))
sensor1 = ContactSensorCfg(prim_path="/World/cube1",
update_period=0.0,
history_length=6,
track_pose=True,
debug_vis=True,
filter_prim_paths_expr=["/World/cube2"])
sensor11 = ContactSensorCfg(prim_path="/World/cube1",
update_period=0.0,
history_length=6,
track_pose=True,
debug_vis=True,
filter_prim_paths_expr=["/World/defaultGroundPlane/GroundPlane/CollisionPlane"])
sensor2 = ContactSensorCfg(prim_path="/World/cube2",
update_period=0.0,
history_length=6,
track_pose=True,
debug_vis=True,
filter_prim_paths_expr=["/World/cube1"])
sim_cfg = sim_utils.SimulationCfg()
sim = sim_utils.SimulationContext(sim_cfg)
sim.set_simulation_dt(1.0/120.0)
scene_cfg = SceneConfig(num_envs=1, env_spacing=2.0)
scene = InteractiveScene(scene_cfg)
sim.reset()
def output_data(data, name):
data = [round(f, 3) for f in data.tolist()]
print(f'{name}: {data}')
sim_dt = sim.get_physics_dt()
sensor1 = scene["sensor1"]
sensor11 = scene["sensor11"]
sensor2 = scene["sensor2"]
mass1 = sensor1.body_physx_view.get_masses()
mass2 = sensor2.body_physx_view.get_masses()
print(f'mass1: {mass1}')
print(f'mass2: {mass2}')
for i in range(100):
sim.step()
scene.update(sim_dt)
force1 = sensor1.data.net_forces_w[0][0]
force2 = sensor2.data.net_forces_w[0][0]
filted_force1 = sensor1.data.force_matrix_w[0][0][0]
filted_force11 = sensor11.data.force_matrix_w[0][0][0]
pos1 = sensor1.data.pos_w[0][0]
pos2 = sensor2.data.pos_w[0][0]
quat1 = sensor1.data.quat_w[0][0]
quat2 = sensor2.data.quat_w[0][0]
print('-'*64)
print(f'step {i+1}')
print(' -- '*16)
output_data(force1, 'force1')
output_data(force2, 'force2')
output_data(pos1, 'pos1')
output_data(pos2, 'pos2')
output_data(quat1, 'quat1')
output_data(quat2, 'quat2')
output_data(filted_force1, 'cube2->cube1')
output_data(filted_force11, 'ground->cube1')
print('-'*64)
Output
When the first cube landed, the force is corrct as:
force1: [0.001, 0.0, 9804.056]
force2: [0.0, 0.0, 0.0]
pos1: [-0.0, -0.0, 0.5]
pos2: [0.0, 0.0, 1.794]
quat1: [1.0, 0.0, 0.0, 0.0]
quat2: [1.0, 0.0, 0.0, 0.0]
cube2->cube1: [0.0, 0.0, 0.0]
ground->cube1: [0.001, 0.0, 9804.056]
When the first cube landed, the force is wrong as:
force1: [-0.004, -0.002, 1227.905]
force2: [0.005, 0.002, 5027.711]
pos2: [-0.0, -0.0, 1.4]
quat1: [1.0, -0.0, 0.0, 0.0]
quat2: [1.0, -0.0, 0.0, -0.0]
cube2->cube1: [-0.005, -0.002, -5027.711]
ground->cube1: [0.001, 0.0, 6255.616]
To cube1, the gravity is 10000*9.8=-9800, force from cube2 is -5027.711, force from ground is 6255.616, the force of cube1 is serious imbalance, right?
System Info
- Isaac Sim Version: 4.2.9
- OS: Ubuntu 22.04
- GPU: RTX 2080Ti
- CUDA: 12.1
- GPU Driver: 535.183.01
