Cannot build docker container for deepstream-test3
• Hardware Platform (Jetson / GPU) GPU
• DeepStream Version nvcr.io/nvidia/deepstream:6.1.1-devel
• NVIDIA GPU Driver Version (valid for GPU only) 515
• Issue Type( questions, new requirements, bugs) Bug
• How to reproduce the issue ?
I want to deploy a graph to a server, and for this I want to build the docker image. So far, I am running the graph composer from the nvcr.io/nvidia/deepstream:6.1.1-devel container, and can successfully launch the samples, including the deepstream-test3 graph.
I have made some small changes to the deepstream-test3 graph (mainly just changing the input URIs to actual RTSP streams), and wanted to build the docker image so I can deploy it on a server with access to those RTSP streams.
However, I get several errors when building the docker image, see below:
root@desktop-ubuntu:/opt/nvidia/deepstream/deepstream-6.1/reference_graphs/deepstream-test3# container_builder -c ds_test3_container_builder_dgpu.yaml -d /opt/nvidia/graph-composer/config/target_x86_64.yaml
2022-10-28 13:43:54,946 - ContainerBuilder.container_builder.docker_manager.docker_manager - INFO - Auto selected base image: nvcr.io/nvidia/deepstream:6.1.1-samples
2022-10-28 13:43:54,947 - ContainerBuilder.container_builder.docker_manager.docker_manager - INFO - start building stage image deepstream_test3_dgpu
2022-10-28 13:43:54,964 - ContainerBuilder.container_builder.docker_templ.docker_templ_maker - INFO - writing docker content to /root/.cache/container_builder/.dockerfile_1743
2022-10-28 13:43:54,964 - ContainerBuilder.container_builder.docker_manager.docker_manager - INFO - docker file /root/.cache/container_builder/.dockerfile_1743 generated
2022-10-28 13:43:54,964 - ContainerBuilder.container_builder.docker_manager.docker_manager - INFO - start preparing work folder: /root/.cache/container_builder/.workfolder_1743
2022-10-28 13:43:54,964 - ContainerBuilder.container_builder.docker_manager.docker_workfolder - INFO - copying local files to work folder
2022-10-28 13:43:54,966 - ContainerBuilder.container_builder.docker_manager.docker_workfolder - INFO - Work folder: /root/.cache/container_builder/.workfolder_1743/final_image is ready
2022-10-28 13:43:56,736 - Registry - INFO - Installing graph ...
2022-10-28 13:43:56,762 - Registry - INFO -
Requested target configuration:
  arch: x86_64 os: linux distribution: ubuntu_20.04 cuda: 11.6 cudnn: 8.2.2.26 tensorrt: 8.2.3.0 deepstream: 6.1 vpi: 2.0.7
Selected extension variants:
StandardExtension
  Version: 2.0.0 Variant: arch: x86_64 os: linux distribution: ubuntu_20.04 cuda: 11.6
MultimediaExtension
NvDsInterfaceExt
  Version: 1.0.0 Variant: arch: x86_64 os: linux distribution: ubuntu_20.04 deepstream: 6.1
NvDsBaseExt
NvDsSourceExt
NvDsMuxDemuxExt
NvDsOutputSinkExt
NvDsVisualizationExt
  Version: 1.0.2 Variant: arch: x86_64 os: linux distribution: ubuntu_20.04 deepstream: 6.1.1
NvDsInferenceExt
NvDsSampleModelsExt
2022-10-28 13:46:00,738 - ContainerBuilder.container_builder.docker_manager.docker_manager - INFO - work folder: /root/.cache/container_builder/.workfolder_1743 is ready
2022-10-28 13:46:00,738 - ContainerBuilder.container_builder.docker_manager.docker_manager - INFO - start build docker file /root/.cache/container_builder/.dockerfile_1743
  File "urllib3/connectionpool.py", line 598, in urlopen
  File "urllib3/connectionpool.py", line 357, in _make_request
  File "http/client.py", line 1256, in request
  File "http/client.py", line 1302, in _send_request
  File "http/client.py", line 1251, in endheaders
  File "http/client.py", line 1011, in _send_output
  File "http/client.py", line 951, in send
  File "docker/transport/unixconn.py", line 30, in connect
FileNotFoundError: [Errno 2] No such file or directory
During handling of the above exception, another exception occurred:
  File "requests/adapters.py", line 430, in send
  File "urllib3/connectionpool.py", line 638, in urlopen
  File "urllib3/util/retry.py", line 357, in increment
  File "urllib3/packages/six.py", line 685, in reraise
urllib3.exceptions.ProtocolError: ('Connection aborted.', FileNotFoundError(2, 'No such file or directory'))
  File "docker/api/client.py", line 214, in _retrieve_server_version
  File "docker/api/daemon.py", line 181, in version
  File "docker/utils/decorators.py", line 46, in inner
  File "docker/api/client.py", line 237, in _get
  File "requests/sessions.py", line 521, in get
  File "requests/sessions.py", line 508, in request
  File "requests/sessions.py", line 618, in send
  File "requests/adapters.py", line 490, in send
requests.exceptions.ConnectionError: ('Connection aborted.', FileNotFoundError(2, 'No such file or directory'))
  File "container_builder/cli/cli.py", line 59, in <module>
  File "container_builder/cli/cli.py", line 53, in main
  File "container_builder/cli/container_builder_runtime.py", line 44, in build
  File "container_builder/docker_manager/docker_manager.py", line 457, in build_main_yaml
  File "container_builder/docker_manager/docker_manager.py", line 527, in build_stage_image
  File "container_builder/docker_manager/docker_builder.py", line 119, in build_from
  File "container_builder/docker_manager/docker_builder.py", line 67, in _internal_build
  File "container_builder/docker_manager/docker_builder.py", line 48, in _ensure_client
  File "container_builder/docker_manager/docker_builder.py", line 38, in _create_client
  File "docker/client.py", line 96, in from_env
  File "docker/client.py", line 45, in __init__
  File "docker/api/client.py", line 197, in __init__
  File "docker/api/client.py", line 221, in _retrieve_server_version
docker.errors.DockerException: Error while fetching server API version: ('Connection aborted.', FileNotFoundError(2, 'No such file or directory'))
[1743] Failed to execute script 'cli' due to unhandled exception!
Any idea what’s going on? I have tried multiple times, but the error persists.
Adding -v /var/run/docker.sock:/var/run/docker.sock to the docker command seems to have solved the issue. (makes sense, there is no docker daemon inside the docker container…)
