Hi there:
I am trying to get xrandr detect Nvidia driver by default, on my macbook and ubuntu (debian).
$ lspci | grep VGA
00:02.0 VGA compatible controller [0300]: Intel Corporation 3rd Gen Core processor Graphics Controller [8086:0166] (rev 09) (prog-if 00 [VGA controller])
01:00.0 VGA compatible controller [0300]: NVIDIA Corporation GK107M [GeForce GT 650M Mac Edition] [10de:0fd5] (rev a1) (prog-if 00 [VGA controller])
I ran nvidia-detect and was told to install nvidia-legacy-390xx drivers along with smi and nvidia-setting-legacy
libegl-nvidia-legacy-390xx0/stable,now 390.144-1 amd64 [installed,automatic]
libgl1-nvidia-legacy-390xx-glvnd-glx/stable,now 390.144-1 amd64 [installed,automatic]
libglx-nvidia-legacy-390xx0/stable,now 390.144-1 amd64 [installed,automatic]
libnvidia-legacy-390xx-compiler/stable,now 390.144-1 amd64 [installed,automatic]
libnvidia-legacy-390xx-cuda1/stable,now 390.144-1 amd64 [installed,automatic]
libnvidia-legacy-390xx-eglcore/stable,now 390.144-1 amd64 [installed,automatic]
libnvidia-legacy-390xx-fatbinaryloader/stable,now 390.144-1 amd64 [installed,automatic]
libnvidia-legacy-390xx-glcore/stable,now 390.144-1 amd64 [installed,automatic]
libnvidia-legacy-390xx-ml1/stable,now 390.144-1 amd64 [installed,automatic]
libnvidia-legacy-390xx-ptxjitcompiler1/stable,now 390.144-1 amd64 [installed,automatic]
nvidia-legacy-390xx-alternative/stable,now 390.144-1 amd64 [installed,automatic]
nvidia-legacy-390xx-driver-bin/stable,now 390.144-1 amd64 [installed,automatic]
nvidia-legacy-390xx-driver-libs/stable,now 390.144-1 amd64 [installed,automatic]
nvidia-legacy-390xx-driver/stable,now 390.144-1 amd64 [installed]
nvidia-legacy-390xx-egl-icd/stable,now 390.144-1 amd64 [installed,automatic]
nvidia-legacy-390xx-kernel-dkms/stable,now 390.144-1 amd64 [installed,automatic]
nvidia-legacy-390xx-kernel-support/stable,now 390.144-1 amd64 [installed,automatic]
nvidia-legacy-390xx-opencl-icd/stable,now 390.144-1 amd64 [installed]
nvidia-legacy-390xx-smi/stable,now 390.144-1 amd64 [installed]
nvidia-legacy-390xx-vdpau-driver/stable,now 390.144-1 amd64 [installed,automatic]
nvidia-settings-legacy-390xx/stable,now 390.144-1 amd64 [installed]
volumeicon-alsa-legacy/bullseye,now 0.4.6-2.4 amd64 [installed]
xserver-xorg-video-nvidia-legacy-390xx/stable,now 390.144-1 amd64 [installed,automatic]
To check whether correct driver is installed (390.144)
$ inxi -Fxz
Graphics:  Device-1: Intel 3rd Gen Core processor Graphics vendor: Apple driver: N/A bus-ID: 00:02.0
           Device-2: NVIDIA GK107M [GeForce GT 650M Mac Edition] vendor: Apple driver: nvidia v: 390.144 bus-ID: 01:00.0
           Device-3: Apple FaceTime HD Camera (Built-in) type: USB driver: uvcvideo bus-ID: 1-1.1:3
           Display: server: X.Org 1.20.11 driver: loaded: nvidia note: n/a (using device driver) unloaded: fbdev
  =========  Symptoms  =========
1. I find for some reason my nvidia card is not working properly:
$ nvidia-smi
Wed May 25 05:20:51 2022
| NVIDIA-SMI 390.144                Driver Version: 390.144                   |
| GPU  Name        Persistence-M| Bus-Id        Disp.A | Volatile Uncorr. ECC |
| Fan  Temp  Perf  Pwr:Usage/Cap|         Memory-Usage | GPU-Util  Compute M. |
|   0  GeForce GT 650M     Off  | 00000000:01:00.0 N/A |                  N/A |
| N/A   54C    P0    N/A /  N/A |      0MiB /   981MiB |     N/A      Default |
| Processes:                                                       GPU Memory |
|  GPU       PID   Type   Process name                             Usage      |
|    0                    Not Supported                                       |
2. also my xrandr cannot detect nvidia as a provider
$ xrandr --listproviders
Providers: number : 0
I tried to walk through the following two posts and set up PRIME
- [Couldn't detect external monitor in ubuntu 18.04.5 with NVIDIA driver 455.38 - #5 by J.C.Au](Couldn't detect external monitor in ubuntu 18.04.5 with NVIDIA driver 455.38 - #5 by J.C.Au
- http://us.download.nvidia.com/XFree86/Linux-x86_64/455.45.01/README/randr14.html
With my new /etc/X11/xorg.conf (xorg.conf.new) and old one  **(xorg.conf.bak)**attached
xorg.conf.bak (523 Bytes)
xorg.conf.new (2.7 KB)
While the nvidia-xconfig --prime does not work because of the missing file libnvidia-cfg.so.1
# nvidia-xconfig --prime
Using X configuration file: "/etc/X11/xorg.conf".
WARNING: error opening libnvidia-cfg.so.1: libnvidia-cfg.so.1: cannot open shared object file: No such file or directory.
ERROR: Unable to find any GPUs in the system.
Backed up file '/etc/X11/xorg.conf' as '/etc/X11/xorg.conf.backup'
New X configuration file written to '/etc/X11/xorg.conf'
3. This might due to the persistent mode (https://forums.developer.nvidia.com/t/nvidia-persistenced-not-running/74338) becasue from my nvidia-smi output the persistent mode is off:
But when I tried the ENABLE persistent mode the suggested command from the documentation halts my screen : nvidia-smi -i 0 -pm ENABLED (https://docs.nvidia.com/deploy/driver-persistence/index.html)
Anyone knows how to verify whether my driver is installed property , what is persistent mode? how to setup PRIME xrandr?
