Cannot detect the 2nd NVMe SSD on Jetson AGX Orin 32 Jetpack 6.1
I have recently flashed our Jetson AGX Orin to JP6.1 but the system only detect 1 of the 2 NVMe SSD (2tb each). Below is my system info:
uname -a
Linux orin 5.15.148-tegra #1 SMP PREEMPT Mon Nov 11 12:45:39 +03 2024 aarch64 aarch64 aarch64 GNU/Linux
jetson@orin:~$ sudo cat /sys/kernel/debug/bpmp/debug/uphy/config
[sudo] password for jetson:
0x00000000
jetson@orin:~$ lsblk
NAME         MAJ:MIN RM   SIZE RO TYPE MOUNTPOINTS
loop0          7:0    0     4K  1 loop /snap/bare/5
loop1          7:1    0 174.6M  1 loop /snap/chromium/2998
loop2          7:2    0 174.6M  1 loop /snap/chromium/3004
loop3          7:3    0  68.8M  1 loop /snap/core22/1666
loop4          7:4    0  68.8M  1 loop /snap/core22/1720
loop5          7:5    0  64.7M  1 loop /snap/cups/1069
loop6          7:6    0 251.1M  1 loop /snap/firefox/5360
loop7          7:7    0 483.3M  1 loop /snap/gnome-42-2204/178
loop8          7:8    0  91.7M  1 loop /snap/gtk-common-themes/1535
loop9          7:9    0  33.7M  1 loop /snap/snapd/21761
loop10         7:10   0  38.6M  1 loop /snap/snapd/23259
loop11         7:11   0    16M  1 loop
mmcblk0      179:0    0  59.3G  0 disk
├─mmcblk0p1  179:1    0  57.8G  0 part /media/jetson/5a68f905-5eae-490a-89fe-9a93c6cec226
├─mmcblk0p2  179:2    0   128M  0 part
├─mmcblk0p3  179:3    0   768K  0 part
├─mmcblk0p4  179:4    0  31.6M  0 part
├─mmcblk0p5  179:5    0   128M  0 part
├─mmcblk0p6  179:6    0   768K  0 part
├─mmcblk0p7  179:7    0  31.6M  0 part
├─mmcblk0p8  179:8    0    80M  0 part
├─mmcblk0p9  179:9    0   512K  0 part
├─mmcblk0p10 179:10   0    64M  0 part /boot/efi
├─mmcblk0p11 179:11   0    80M  0 part
├─mmcblk0p12 179:12   0   512K  0 part
├─mmcblk0p13 179:13   0    64M  0 part
├─mmcblk0p14 179:14   0   400M  0 part
└─mmcblk0p15 179:15   0 479.5M  0 part
mmcblk0boot0 179:32   0  31.5M  1 disk
mmcblk0boot1 179:64   0  31.5M  1 disk
zram0        252:0    0   1.9G  0 disk [SWAP]
zram1        252:1    0   1.9G  0 disk [SWAP]
zram2        252:2    0   1.9G  0 disk [SWAP]
zram3        252:3    0   1.9G  0 disk [SWAP]
zram4        252:4    0   1.9G  0 disk [SWAP]
zram5        252:5    0   1.9G  0 disk [SWAP]
zram6        252:6    0   1.9G  0 disk [SWAP]
zram7        252:7    0   1.9G  0 disk [SWAP]
nvme0n1      259:0    0   1.8T  0 disk
└─nvme0n1p1  259:1    0   1.8T  0 part /
jetson@orin:~$ lspci -vvv
0001:00:00.0 PCI bridge: NVIDIA Corporation Device 229e (rev a1) (prog-if 00 [Normal decode])
	Control: I/O+ Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR+ FastB2B- DisINTx-
	Status: Cap+ 66MHz- UDF- FastB2B- ParErr- DEVSEL=fast >TAbort- <TAbort- <MAbort- >SERR- <PERR- INTx-
	Latency: 0
	Interrupt: pin A routed to IRQ 193
	IOMMU group: 58
	Bus: primary=00, secondary=01, subordinate=ff, sec-latency=0
	I/O behind bridge: 00000000-00000fff [size=4K]
	Memory behind bridge: 40000000-400fffff [size=1M]
	Prefetchable memory behind bridge: 00000000fff00000-00000000000fffff [disabled]
	Secondary status: 66MHz- FastB2B- ParErr- DEVSEL=fast >TAbort- <TAbort- <MAbort- <SERR- <PERR-
	BridgeCtl: Parity- SERR+ NoISA- VGA- VGA16- MAbort- >Reset- FastB2B-
		PriDiscTmr- SecDiscTmr- DiscTmrStat- DiscTmrSERREn-
	Capabilities: <access denied>
	Kernel driver in use: pcieport
0001:01:00.0 Ethernet controller: Intel Corporation I210 Gigabit Network Connection (rev 03)
	Control: I/O- Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx+
	Latency: 0, Cache Line Size: 128 bytes
	IOMMU group: 58
	Region 0: Memory at 20a8000000 (32-bit, non-prefetchable) [size=512K]
	Region 2: I/O ports at 300000 [disabled] [size=32]
	Region 3: Memory at 20a8080000 (32-bit, non-prefetchable) [size=16K]
	Kernel driver in use: igb
0004:00:00.0 PCI bridge: NVIDIA Corporation Device 229c (rev a1) (prog-if 00 [Normal decode])
	Latency: 0
	Interrupt: pin A routed to IRQ 195
	IOMMU group: 59
	I/O behind bridge: 0000f000-00000fff [disabled]
	Kernel modules: tegra_pcie_dma_test
0004:01:00.0 Non-Volatile memory controller: KIOXIA Corporation Device 0018 (rev 01) (prog-if 02 [NVM Express])
	Subsystem: KIOXIA Corporation Device 0018
	Latency: 0
	IOMMU group: 59
	Region 0: Memory at 2428000000 (64-bit, non-prefetchable) [size=16K]
	Kernel driver in use: nvme
	Kernel modules: nvme
dmesg.txt (99.5 KB)
Custom board or Devkit?
Which PCIe controller are you using for that 2nd NVMe?
Yes, custom board from Connect Tech. It seems we have similar issue with the Ethernet ports: 2 10Gb and 2 1Gb but only one 1Gb is recognized after flashing to JP6.1
~$ sudo lshw -class network
*-network
description: Ethernet interface
product: I210 Gigabit Network Connection
vendor: Intel Corporation
physical id: 0
bus info: [pci@0001](mailto:pci@0001):01:00.0
logical name: enP1p1s0
version: 03
serial: 00:0c:8b:b8:46:17
capacity: 1Gbit/s
width: 32 bits
clock: 33MHz
capabilities: pm msi msix pciexpress bus_master cap_list ethernet physical tp 10bt 10bt-fd 100bt 100bt-fd 1000bt-fd autonegotiation
configuration: autonegotiation=on broadcast=yes driver=igb driverversion=5.15.148-tegra duplex=full firmware=0. 0-0 ip=10.0.3.109 latency=0 link=yes multicast=yes port=twisted pair speed=1Gbit/s
resources: irq:193 memory:20a8000000-20a807ffff ioport:300000(size=32) memory:20a8080000-20a8083fff
*-network:0
physical id: d
logical name: eth0
serial: 48:b0:2d:a8:b1:6a
capacity: 1Gbit/s
capabilities: ethernet physical tp mii 10bt 10bt-fd 100bt 100bt-fd 1000bt 1000bt-fd autonegotiation
configuration: autonegotiation=on broadcast=yes driver=nvethernet driverversion=5.15.148-tegra link=no multicast=yes port=twisted pair
*-network:1
physical id: e
logical name: usb0
serial: 46:d7:7f:2e:91:19
configuration: broadcast=yes driver=g_ether driverversion=29-May-2008 firmware=tegra-xudc link=no multicast=yes
[jetson@orin](mailto:jetson@orin):~$ lspci | grep -i eth
How did you flash this board?
I flashed it using SDK manager from a host computer connecting to Jetson by usb cable
Did ConnectTech tell you their board support sdkmanager ?
We have contacted them but haven’t got reply yet
Nothing I can help here. Sdkmanager didn’t guarantee to work with a custom board.
To be more precise I followed this instruction to flash: JetPack-6.x Installation for DSBOARD-AGX
It is a combination of SDKmanager and Script
Why are you flashing a ConnectTech board with a method from Forecr…?
Good question! Perhaps, I need to reflash with ConnecTech method
I confirm that using ConnectTech’s BSP for reflash JP6.1 solved the problem
